FFCars.com : Factory Five Racing Discussion Forum - View Single Post - 2015 Donor Mk4 Roadster w/IRS, First Build - Input Welcome, Many Questions.
post #284 of (permalink) Old 08-11-2019, 11:46 PM Thread Starter
IsaacW
First Time Builder
IsaacW's Avatar
Originally Posted by edwardb View Post
Still not the same since the factory setup also includes a line to the top of the radiator with a one-way valve. That's part of how it keeps air out of the system. Mustangs (and our builds) have run millions of miles without blow-off caps when set up the way Ford designed. Controlling engine temp is a big deal. Altering a known working setup is risky IMO for no other reason than the aesthetics and perceived inconvenience (which it isn't) of the tank location. Good luck whatever you do.
Ahah... I must not have read enough to be aware of the one-way valve to the radiator .... Iíll re-visit that. I agree, I donít want to mess with the way Ford designed the ECU to control the engine temperature.
IsaacW is offline
