post #762 of (permalink) Old 07-02-2019, 08:47 AM Thread Starter
Paul L
Paul L's Avatar
Cockpit Panelling – Part 3
There was just one small job to do before the panels were finally fitted.
As I had found a small amount of gas sloshing around inside the float from the fuel gauge sender.
( When I was checking my fuelling problem. )
I ordered and fitted this new replacement float.
Before added a lick of paint to the area between the cockpit wall and the gas tank.
In order to fix the panels in place I had to use three different bits for my drill.
One to drill the hole in the alloy, one to drill a pilot hole in the plywood wall & one to fix the screw in place.
At some points, I was having to fix one screw at a time using all three bits as I hammered the panels before fitting.
So, I’ll spare you the highly repetitive nature of this work and cut to the chase…
I have extra screws matching the ones used on the rear wall access panel "somewhere", but can’t find them.
Rather than waste any time now, I simply 'borrowed' four from the rear panel to fit the side mirror bolt covers.
Which left some gaps in the rear panel that I will fix in the next few days when I track down the missing screws.
However, you can still get a pretty good idea of how it will look in the end.
Plus, here are the side panels.
Finally, some wider-angle shots.
I must confess that this has worked out much better than I ever could have expected.
Paul L is offline
