FFCars.com : Factory Five Racing Discussion Forum - View Single Post - Shark92651's MK4 Coyote Build #9327
post #17 of (permalink) Old 04-01-2018, 01:13 PM Thread Starter
shark92651
shark92651's Avatar
Hopefully my kit will be picked up this week, but no word on that yet. I didn't get a whole lot of work done this weekend because I couldn't get the engine on the stand. I couldn't source the grade 10.9 M10 x 1.5 x 100mm bolts locally so going to have to wait on a delivery from McMaster this week. I did manage to get a few things done, however.
As others have mentioned, I removed some material in the oil pan in the area that may cause interference with the dipstick. I used a rotary burr file on the angle grinder to get the bulk of the material off and finished it up with small sanding drums on the Dremel. Cleaning out all the bits of aluminum was a pain. I removed that top plate and then used hot water and Simple Green. I wiped it out with paper towels and then blew it out with my compressor. It took awhile but I finally got it all out.
I got my clutch in this week and of course the dowels had to be swapped so I took the flywheel back off. I flipped it upside down and laid it across a couple 2x4's and drove out the old dowels with a 1/4" punch.
To drive the new dowels in I used a cool tip I saw on Youtube. I took a large bolt and I drilled a 1/4" hole into the head just deep enough to set the dowels slightly recessed into the flywheel. I also ground off the raised identification letters on the head of the bolt so that it wouldn't stamp them into the flywheel. I have no idea if that would actually happen, but didn't want to take a chance. I also left the dowels in the freezer overnight, just a touch of oil, used my homemade starter punch, and they drove in very easily. Flywheel is now installed with new flywheel bolts, properly torqued to 177 in/lbs + 60 degrees.
I borrowed lift brackets from a friend so I was finally able to get the engine off the pallet. I may have to shorten those chains when I am putting it in the car to get enough height out of it. I put the motor on the fixed engine cradle I bought from https://www.stumpysfabworks.com/ so that I could drain the oil. Of course I then realized I bought the wrong cradle. It works great for the stock oil pan but it isn't going to clear the Moroso pan. I emailed Kurt asking if I could exchange it, hopefully that won't be an issue. For those looking for an engine cradle, the price and quality is right at Stumpy's. The model you want for the Coyote and the Moroso pan is the MOD-PAW - "W" for Wide.
MK4 Coyote Roadster #9327
shark92651 is offline
