FFCars.com : Factory Five Racing Discussion Forum - View Single Post - 33 LS1/T56 Build
Go Back   FFCars.com : Factory Five Racing Discussion Forum
Old 07-04-2017, 01:05 PM   #103 (permalink)
daveS53
Banned
If the frame tubes are 1/8" thick then you have adequate material to tap holes that are strong enough. I prefer fine threads in any given size, to coarse threads. I've demonstrated the strength of a tapped hole like this by picking up the whole front of my car with one 3/8" eye bolt, connected to my lift.
Try some Longacre toe plates to set toe-in. There is no way you can measure toe accurately with your method.
Longacre Toe Measurement Tools
I'd also recommend checking the wheelbase on both sides. If there's more than 1/8" difference, something's off. I made some 90 degree angle plates from MDF that were the same height as the tire radius, placed the angle against the tire and hooked the end of the tape measure behind the top edge of the angle. Run the tape to the front tire, with the wheel pointed straight ahead. Moving the tape measure reel slowly up and down near the center of the tire will reveal the shortest distance. If in doubt about the measurement, repeat 2-3 times to insure that the measurement is repeatable.
I used some home made turn plates, accurately marked with 20 degree lines and a digital level to measure caster. I cut a length of 1-1/2 aluminum angle to span across the front wheel, and taped the level to the angle, to measure both caster and camber. 4 degrees is usually considered to be a lot for a car with manual steering, but OK for a street car with power steering. As long as the steering effort doesn't seem excessive in a parking lot, it's not too much. A car like my Corvette has about 7 degrees.
daveS53 is offline   Reply With Quote
» Premium Vendor Showcase
» Recent Discussions
Highland Park , IL
08-14-2019 11:01 PM
Last post by jschallman
Today 04:38 AM
7 Replies, 196 Views
Factory Five Roadster
Yesterday 11:36 PM
Last post by Joe Campbell
Today 04:14 AM
1 Replies, 54 Views
Building Coupe 674 ( 1 2 3 4 5 )
01-15-2018 01:26 AM
by Gbeck
Last post by Gbeck
Yesterday 11:56 PM
125 Replies, 12,275 Views
SVTFreak's # 1002 build... ( 1 2 3 4 5 ... Last Page)
05-09-2017 07:31 PM
Last post by SVTFreak
Yesterday 10:46 PM
217 Replies, 22,714 Views
Alignment adjustment
Yesterday 04:24 PM
Last post by jhargrove
Yesterday 09:58 PM
7 Replies, 128 Views
Standing on its own 4...
Yesterday 07:21 PM
Yesterday 09:56 PM
3 Replies, 111 Views
Another AEM Infinity ECU... ( 1 2 3 4 5 ... Last Page)
09-16-2015 07:01 PM
Last post by TMScrogins
Yesterday 09:48 PM
441 Replies, 35,488 Views
Inspection - FAILED!
08-13-2019 09:09 PM
by dwleo
Last post by Norm B
Yesterday 09:00 PM
18 Replies, 1,236 Views
ignition system recs
07-09-2019 04:46 PM
by egchewy
Last post by sdonnel
Yesterday 04:38 PM
21 Replies, 548 Views
Any 2019 CT registration...
08-01-2019 06:32 PM
by RockOn
Last post by Carl Johnson
Yesterday 02:10 PM
6 Replies, 131 Views
Shark92651's MK4 Coyote... ( 1 2 3 4 5 ... Last Page)
03-17-2018 07:42 PM
Last post by shark92651
Yesterday 01:14 PM
202 Replies, 16,248 Views
Connectors
08-21-2019 08:41 PM
Last post by japomeroy
Yesterday 12:56 PM
2 Replies, 77 Views
VPM 3 link support...
08-12-2019 07:32 PM
Yesterday 12:20 PM
4 Replies, 106 Views
Moves under its own power
10-17-2018 03:53 AM
by 2FAST4U
Last post by 65 Cobra Dude
Yesterday 01:13 AM
15 Replies, 982 Views
Quick Jack...
Yesterday 01:03 AM
Last post by Pierre B.
Yesterday 01:03 AM
0 Replies, 47 Views
Stupid question: gas...
08-18-2019 04:57 PM
Yesterday 12:40 AM
14 Replies, 1,018 Views
Blue Ridge Parkway
08-12-2019 11:43 AM
by FFR3247
Last post by FFR3247
08-21-2019 09:55 PM
3 Replies, 82 Views
Car Cover
09-21-2018 11:25 PM
by dwleo
Last post by Brastic
08-21-2019 09:51 PM
13 Replies, 687 Views
Mark II in Seattle
08-21-2019 09:16 PM
Last post by Redshift
08-21-2019 09:16 PM
0 Replies, 71 Views
Edwardbťs Gen 3 Type 65... ( 1 2 3 4 5 ... Last Page)
12-02-2017 07:23 PM
by edwardb
Last post by edwardb
08-21-2019 08:01 PM
294 Replies, 47,504 Views
