FFCars.com : Factory Five Racing Discussion Forum - View Single Post - EdwardBťs Mk4 #8674 20th Anniversary Build
post #472 of (permalink) Old 07-03-2017, 12:20 PM Thread Starter
edwardb
Originally Posted by alexg View Post
Hi Paul,
I noticed you are using a oil low level switch on the Morso pan. Was this purchased separately?
My stock 2016 Coyote oil pan did not have a sensor port at all. I'm using a Canton pan, which has a spare port, but no sensor.
I've scoured the internet and cannot seem to find reference to this sensor. Do you know the part number?
Regards,
Alex
Hey Alex. I didn't buy anything extra. The low oil sensor and harness was part of my 2015 Coyote crate package. It went right into the Moroso pan port. There is some question whether this sensor is even active using the crate motor controls pack. I heard from several that it was not on the Gen 1 Coyote, but nothing definitive for my Gen 2. But it was just as easy to put the sensor in the pan as finding a plug for it, so I just went for it. If your newer Coyote crate doesn't have the sensor or accompanying harness, I would plug the port in the pan and be done with it. Sounds like Ford is doing something different now. You could call Ford Performance tech support and confirm there isn't a sensor or support for it in your PCM if you really wanted to.
and
edwardb is offline
