FFCars.com : Factory Five Racing Discussion Forum - View Single Post - EdwardBŁs Mk4 #8674 20th Anniversary Build
post #133 of (permalink) Old 01-03-2016, 08:57 AM
carlewms
carlewms's Avatar
EdwardB,
The KRC power system setup looks great. I really like the valve adjustment to change boost.
"Yesterday I checked the FF stock e-brake handle and the provided Wilwood cables. Looks like it's going to work OK, but I still just can't get used to routing the cables under the 4 inch chassis tube. I've managed to avoid that on my other builds. May not be so lucky this time."
I did not like the setup that puts the cables running under the 4 inch chassis tube and solved it by using a Lokar cable kit with a modified FFR e-brake mechanism.
Here is the drawing showing the difference between the supplied lever and the one I made.
In addition to the Lokar cables, I used the following Lokar parts ...
Here is the final assembly ... the bottom of the extended lever does not drop below the 4" round tube.
Carl
carlewms is offline
