FFCars.com : Factory Five Racing Discussion Forum - View Single Post - EdwardBťs Mk4 #8674 20th Anniversary Build
post #66 of (permalink) Old 10-19-2015, 02:29 PM
chrisarella
chrisarella's Avatar
Originally Posted by edwardb View Post
When I was ready to click the button to purchase last week, the first place I went said “Ford Coyote M-6007-M50 no longer available, replaced with M-6007-M50A.” ...It’s rated at 430 HP and just over 400 torque. ...Some of the changes to the 2015-2016 engine are bigger heads and valves. ...A revised crankshaft, connecting rods, pistons, and a couple internal changes to the block. A major addition is charge motion control valves (CMCV) added to the intake manifold. This was something used before on 3V mod motors, as I understand, and one of the first performance modifications was to remove them. Ford claims these were done right on the Coyote, and get totally out of the way when open. They are supposed to provide better low-end torque without affecting high rpm power.
You are correct except the motor has 435 horsepower (not 430) @ 6500 rpm and 400 ft/lb of torque @ 4250 rpm (with premium fuel).
Here is the breakdown:
NEW Ford Performance Mustang Coyote 5.0L 435HP Crate Engine M-6007-M50A
Coyote Control Pack M-6017-504V Recommended
Detailed Specs and Notes:
  • 435 Horsepower, 400 ft/lbs Torque
  • 11.0:1 Compression ratio
  • Lightweight aluminum block features cross-bolted main bearing caps and thick bulkheads for bottom-end strength
  • Piston cooling jets and optimized oil drainback and windage control to improve high-rpm performance
  • Large sump oil pan with 8qt capacity
  • Tuned composite intake manifold provides efficient air delivery and weight savings
  • 80 mm single bore drive by wire throttle body
  • Four-valve-per-cylinder aluminum heads with roller-finger followers reduce friction
  • Includes Mustang GT 409 stainless-steel tubular exhaust manifold on the RIGHT SIDE ONLY
  • Includes manual transmission engine harness and flywheel
  • Vehicle harness and PCM not included
  • Use Control Pack M-6017-A504V designed for street rod/project car installation
  • Does not include alternator for alternator kit see M-8600-M50ALT
  • 5.0L Mustang engine cover kit available see M-9680-M50A
  • Remote Mount Filter Adapter M-6881-M50 available for applications requiring oil filter relocation
  • Engine mount bosses and bellhousing mount pattern common to 4.6L modular engines
  • Photo and specs may vary as production is ongoing
  • Engine weight: 444 lbs
OUTGOING Ford Performance Mustang Coyote 5.0L 420HP Crate Engine M-6007-M50
Coyote Control Pack M-6017-A504V Recommended
  • 420 Horsepower, 390 ft/lbs Torque
  • Photo and specs may vary. These features apply for engine code EG-397-AA. Engines are this build code or newer while supplies last.
Honestly you probably won't notice the difference in power, but I suspect the revisions were more about longevity.
Then I found they have released a brand new control pack M-6017-504V for the 2015-2016 engine, which is mandatory. The 2011-2014 engine won’t work with the new control pack and the 2015-2016 won’t work the old control pack.
Correct again.
NEW FORD RACING 5.0L COYOTE ENGINE CONTROL PACK — M-6017-504V
Designed to run:
  • M-6007-M50A 4 Valve crate engines
Ford Performance Instructions
OUTGOING FORD RACING 5.0L COYOTE ENGINE CONTROL PACK — M-6017-A504V
Designed to run:
  • M-6007-M50 4 Valve crate engines
  • M-6007-A50NA 5.0L 4V crate engines
  • M-6007-A50SC
  • M-6007-A50XS 5.0L 4V Aluminator XS crate engines
  • Salvage motors from 2011-2014 Mustang GT.
  • Salvage motors from 2012-2013 Boss 302 with aftermarket custom software tuning.
  • Salvage motors from 2012-2013 F150 with aftermarket custom software tuning.
Sadly I've already purchased the older control pack. I just looked on the box of my control pack and the number says M-6017-A504V. The "A" is the difference in the part numbers. So I will be on the hunt for the older motor.
Chris
Coyote 5.0, T56, IRS, Torsen Diff, PS, Wilwoods, Hydraboost PB + ABS, & tons more extras.
Arrived 12/18/2011. More info, full parts list, financials, and progress-tracking on my
chrisarella is offline
