post #149 of (permalink) Old 04-10-2014, 10:56 AM Thread Starter
Paul L
Paul L's Avatar
Electrical Odds & Ends:
The new lugs for the ends of the earth leads that will attach to the battery cut off switch arrived.
So I will need to remove the ends that were too small and fit these at some point.
Working on the wiring loom had also got me thinking about my headlight rims.
I'd order two second hand ones for my kit, as the Spitfire 1500 used a different headlight fitting altogether.
But one came with a hole for a fixing screw and one didn't and it wasn't clear to me which was correct.
But a quick check on the Rimmer Brothers website showed I was actually missing the retaining clip in this photo.
Now it all made sense, so I ordered a pair of these.
And at some point I will drill a hole in the headlight rim that doesn't have one.
I also started work on the wiring for the rear lights.
After I'd realised I'd made yet another school boy error when I ordered the connecting blocks.
I'd been thinking about the wires required in the main loom for these lights on each side:
- Stop
- Tail
- Indicator
- Common earth
That is why I ordered a 4 pin connecting block, but the problem was that would permanently join the two lights together!
What I should have ordered was separate 3 pin and 2 pin blocks for each light.
So I ordered some extra "double" connectors from ebay.
But to avoid waste, I will now use the 4 pin block for the 3 stop/tail light wires.
And the new two blade connectors for the indicators.
I like producing these summary reports/updates as it is clear to see that I am actually making progress.
I am trying not to worry about the pace of this progress, or the mountain of work that lies ahead.
Instead, I will just continue to chip away at the jobs required to reach the "Go Kart" stage.
So until next time, take care, Paul.
Last edited by Paul L; 02-15-2018 at 06:33 AM. Reason: Replacing PhotoBucket Images
Paul L is offline
