post #146 of (permalink) Old 04-10-2014, 10:50 AM Thread Starter
Paul L
Paul L's Avatar
A long day - Part 4:
Having dragged some of my tools and the welder from the bottom of the garden I wanted to make good use of them.
So I decided to weld in some box section across the door opening in the framework while I was on a roll.
But before I started on that I needed to take some more out of the door openings in the bodywork.
Otherwise the body would not sit back on the modified frame work.
Note:
All of this door opening section will be removed when I come to seal up the doors.
But I wanted to fix the outer door skins in place first before I completely removed it.
After another blast with the jigsaw.
Then I cut two lengths of box section (obviously the two openings in the framework are different sizes ).
Then welded them in.
Frame back on the chassis.
Then bodywork back on the frame.
Note:
Until I cut the bodywork to fit around the bulkhead, it will still point upwards at the front.
Whilst the body work does now clear the door rail, there will be a limit on how far this can be lowered.
Mind you, there is so much bodywork to do, I'm trying not to think about it.
Although I did find myself looking at how much I might need to widen the cockpit to have plenty of room for my seats.
Still on the subject of bodywork, I need to bridge a gap of around 9 cms to cover the Spitfire bulkhead & dash.
Paul L is offline
