post #139 of (permalink) Old 04-02-2014, 01:43 PM Thread Starter
Paul L
Paul L's Avatar
Wiring Loom - Part 5:
When I first thinned the loom out, I cut one wire in error from the connection block that goes to the indicator/horn switch.
Rather than attempt to fix the mess I'd made of the original connecting block, I simply added an extra connection.
However, for this to work, I had to wrap a "bend" in the rest of the wires to create some slack.
( As my previous butchery had left the wires too short. )
Whilst this is clearly not as tidy as the original set up, it will work well enough for me.
I continued working my way along the loom until I got to the section of wires near the fuses.
This included the other mistake that I'd made when thinning out the loom the first time.
I'd cut out a green & black wire in error (shown below on the left with tape on), but is was now too short to rejoin at the fuse box.
In addition, there was a "stray" earth lead that wasn't going to fold up/tuck away neatly either.
So I used two more of my red connecting tubes to tidy up the wires & their routes.
- The green & black wire now joins one of the green wires a bit earlier than at the fuse box itself.
- The earth wire is now a single lead to "earth", with the rest of the wire the right size to tuck in nicely.
Which meant another section of the loom could be wrapped up.
Note:
The collection of wires heading off to the bottom of this photo are for the rear lighting.
But I still need to work out the route they will take from the bulkhead through the rest of the car.
Paul L is offline
