Surfdog57's Gen 3 (#12) build journal. - Page 13 - FFCars.com : Factory Five Racing Discussion Forum
 67Thanks
post #361 of 386 (permalink) Old 12-28-2018, 09:53 PM Thread Starter
SurfDog57's Avatar
Originally Posted by John Dol View Post
Looks great! Will you keep the original spoiler on the car when racing with the big spoiler on?
Or does that interfere with the aero?
Track configuration vs street.
In other words, street trim has no added aero bits or aero, just brake ducting NACA ducts on lower lip up front and the street spoiler installed out back.
On the rear, the street spoiler will come off when using the big wing, as per the analysis in this wind tunnel data summary. (It adds a bit more downforce to run both but at a big drag penalty)
http://www.johngeorgeracing.com/word...esting-report/
This is why I went to the trouble of using cam-lock fasteners on the “street spoiler”.
It comes on and off pretty quickly and easily.
I’m running what they call a “stage 2” aero package. GT300 wing and no down planes on the nose.
TBD is if I will need to up my spring rates with aero installed. (I assume that I will)
SurfDog57 is offline
post #362 of 386 (permalink) Old 01-02-2019, 11:27 PM Thread Starter
SurfDog57's Avatar
Rear wheelwell back aluminum was moving around a bit and rubbing tire some.
I didn’t want to put pop rivets through the body so used some panel bond to mount up a few support brackets. If it breaks loose from vibration or whatever, (unlikely) I can always pop a rivet through later.
Edit: one of the bonds didn’t hold (you guessed it, the first one due to poor panel bond mixing through the stupid mix tip. Make sure to discard first oz or so that comes through those tips as it is not well mixed...)
This will also serve to anchor those dangly body ends down there from shaking around.
That should definitely do the trick.
post #363 of 386 (permalink) Old 01-02-2019, 11:28 PM Thread Starter
SurfDog57's Avatar
Sway bar clamps in place. All four corners.
post #364 of 386 (permalink) Old 01-02-2019, 11:48 PM Thread Starter
SurfDog57's Avatar
Changed out break in oil. 12quarts
Process is a bit different than I’m used to because dry sumped
post #365 of 386 (permalink) Old 01-03-2019, 03:28 AM
Great idea on the brackets with the riv-nuts.
I'll do the same. I just have the one lower rivet through the body and I'm waiting for the rear wheelwells to blow forward.
Thanks for posting.
Dave #17
SurfDog57 thanked this.
taved is offline
post #366 of 386 (permalink) Old 01-11-2019, 03:24 PM Thread Starter
SurfDog57's Avatar
Tail stripes (at last). This detail took me awhile to address.
post #367 of 386 (permalink) Old 02-04-2019, 09:59 PM Thread Starter
SurfDog57's Avatar
Upgraded battery cutout
Upgraded turn signal switch.
Found short at end of rear turn signal (was loose)
Found multiple loose gauge connections and crimped then down better
FFR battery cutout seemed flimsy/failure prone.
post #368 of 386 (permalink) Old 02-12-2019, 10:12 PM Thread Starter
SurfDog57's Avatar
Rear wing X brace and air jack inlet are on.
Next step send them out for powder coat and call it a day.
post #369 of 386 (permalink) Old 02-16-2019, 12:36 AM Thread Starter
SurfDog57's Avatar
Buddy welding up bolt on air jack brackets
post #370 of 386 (permalink) Old 02-26-2019, 11:02 PM Thread Starter
SurfDog57's Avatar
Rear air jack mounts were a bit more involved due to space limitations.
post #371 of 386 (permalink) Old 02-28-2019, 04:37 PM Thread Starter
SurfDog57's Avatar
Heat shields to protect from exhaust and plumbing.
Rear as seen from diff out.
Mount sans jack.
Inside body air fitting
Outside
Protector flap “extension” to keep tire and rocks from hammering to hard on front jack
post #372 of 386 (permalink) Old 02-28-2019, 06:30 PM
q4stix's Avatar
Looks well thought out and implemented!
Gen 3 Type 65 Coupe builder
q4stix is online now
post #373 of 386 (permalink) Old 03-06-2019, 01:34 AM Thread Starter
SurfDog57's Avatar
Welded on a few tow hook hard points for tie downs in the trailer.
Edit: my buddy Greg at Ignite performance in Denver is welding a cross piece on there today to keep the tie down straps located to center once things start jiggling around in the trailer. Pics to follow.
Edit: in video below of air jacks you can catch a glimpse of the tow strap cross brace welded in and the whole thing painted white.
post #374 of 386 (permalink) Old 03-07-2019, 06:47 PM Thread Starter
SurfDog57's Avatar
No words.
https://youtu.be/DyWXN1eYMzs
WIS89 thanked this.
post #375 of 386 (permalink) Old 03-07-2019, 08:23 PM
That is so cool! Congratulations on getting them installed and working properly!
Your whole car is spectacular, and I have enjoyed following along.
Regards,
WIS89 is online now
post #376 of 386 (permalink) Old 03-07-2019, 08:40 PM
Thumbs up
That is really cool. Thanks for sharing the video
FFR Coupe # 487
Eaton Super Charged 306 SBF, T5 G-Force, IRS.
JimS Custom made headers, Mufflers, SC Intake, Power Windows, Dash board, ETC... :-)
JimS is offline
post #377 of 386 (permalink) Old 03-07-2019, 11:25 PM Thread Starter
SurfDog57's Avatar
Jack photos
Radiator lower shield/ splitter lip is done
Down position
Hood raised.
It should keep the back of the splitter planted at speed and direct air onto my radiator and oil temp system.
post #378 of 386 (permalink) Old 03-07-2019, 11:45 PM Thread Starter
SurfDog57's Avatar
Track day in a month or so and I’m about ready.
-touch up some paint here and there. (Also compound out some orange peel)
-powder coat some braces and brackets
-finish building high pressure hoses for air jacks. (I’m putting 3-400 psi into that hose). I got lucky and scored some free 3500 psi hose and fittings that just need a little build up. I’m trying to find 400 psi rated quick pneumatic disconnects.
Hood realignment is done
Modified fuel tank cover (to make space for air jack hardware) is off to powder coat and needs a bit pop riveting to get in. There was nowhere to go with the hardware for air jacks but up an inch or so onto the hatch. We made them a couple “gurney bumps”
Idle seems normalized a bit after cleaning out the MAF sensor. I might need a little more time with the tuner guy to get it fully smoothed out. The idle “bumps up” at seemingly random intervals. It’s mostly just a nuisance, but need sorting.
Corner weights need doing.
Suspension tweaking, ride height and sway settings are the next phase. I’ll be doing that without aero on to get the handling the way I like it, then will bolt on aero and try to get it set for similar feel but more side G. My main adjustment will be rear spoiler angle of attack and spring rates.
New track pads need install and a good bleed I’m finally pulling my head out and running full track pads. I honestly have no idea why I was running mystery “shipped with” pads last time out, but I do know they were just street pads and I lost my pedal at a very opportune time!!! Exiting. (In a not so good way). The addition (connection really) of brake ducts should also help.
Rubbing issues sorted
Wheel spacing sorted
Fuel siphoning sorted
Electric (gauge) issues sorted
Cheesy battery cutout switch sorted
Aero install sorted (but will not run for a few sessions).
Registration sorted!!!!!
Damn I’m feeling very ready for spring. Wish us luck as we go from graduate to racer. This should be a telling year for this build.
post #379 of 386 (permalink) Old 03-08-2019, 01:06 AM
John Dol's Avatar
That is awesome, very cool!
Building when I can, sigh....
First start Sept. 18 2013
First go kart Sept 19 2013
John Dol is online now
post #380 of 386 (permalink) Old 03-11-2019, 06:49 AM
northshore2014's Avatar
look forward to see how you are going to do the brake ducts..
Coupe 65 #646
Ordered - 28 May, 2014.
Delivery, Sydney - 18 August.
Engine running - October 2015
First gokart - December 2015
northshore2014 is offline
post #381 of 386 (permalink) Old 03-17-2019, 11:17 PM Thread Starter
SurfDog57's Avatar
Wax and detail.
WIS89 thanked this.
post #382 of 386 (permalink) Old 03-18-2019, 01:32 PM
Car looks really great! You did a great job, and I am completely jealous!
I don't remember you posting that you got your plates, yet I see one hiding behind the windshield; well done.
And, that's a fine looking Z you have sitting there keeping the coupe company. You need to tell us a bit more about hat ride...
Congratulations again on wrapping up a beautiful build. I look forward to hearing how she does on the track. Good luck!
Regards,
WIS89 is online now
post #383 of 386 (permalink) Old 03-18-2019, 03:21 PM Thread Starter
SurfDog57's Avatar
Regards,
My buddys Greg and Bill have been restoring and restomodding a pair of 240s. They are about finished.
I’m just starting one!
post #384 of 386 (permalink) Old 04-15-2019, 05:15 PM Thread Starter
SurfDog57's Avatar
I’m calling this build complete!!!!!!!
So this is now a “What did surfdog do with his Gen 3 track day toy today” thread.
I’m happy to answer any build advice or why the heck did you redesign this or that type questions but from here on out it will mostly be maintenance and track day report and car show stuff. (Though this is not really a show car at all...)
So... Cheers!
post #385 of 386 (permalink) Old 04-15-2019, 05:20 PM Thread Starter
SurfDog57's Avatar
Today’s project. Upgrade my “shipped with pads” to full track compound for my track day on the 27th.
Also I’ll be bleeding in better fluid. (Castro’s SRF).
Along with my untried brake ducts and pads I have high expectations of my revised brake setup!!!
I will be running in street trim to get car balance the way I like it before running all my race aero. (I anticipate I’ll need stiffer spring rates once I add on all that downforce, but I want to start with good “no-aero” balance before I start tuning the big wing and splitter.
post #386 of 386 (permalink) Old 04-15-2019, 05:26 PM Thread Starter
SurfDog57's Avatar
Originally Posted by SurfDog57 View Post
Let’s see if these make a difference. I think they will.
As a reminder here are those pads that have been sitting on the shelf since fall that are goin in today.
I will make a slight caliper shim adjustment while I’m in there to fix a slight pad misalignment leftover from initial shake down that I never got around to tweaking.
