Coupe in Sydney Australia - Page 5 - FFCars.com : Factory Five Racing Discussion Forum
 30Thanks
post #121 of 384 (permalink) Old 02-23-2015, 06:55 PM
John Dol's Avatar
Like your dash design. May want to look at the placement of the tach and speedo. The reason I went for the hump is so you can actually see them. In the coupe with a regular lay out they are hidden behind the spokes of the steering wheel. Not sure if your design will solve that, or if that's what you wanted to solve.
Building when I can, sigh....
First start Sept. 18 2013
First go kart Sept 19 2013
John Dol is offline
post #122 of 384 (permalink) Old 02-24-2015, 01:16 AM Thread Starter
northshore2014's Avatar
Thanks John.. Im not a great artist.. . The proportions on the sketch aren't quite right, the 14" wheel would allow the tach and speedo to be visible inside the rim.. have moved them closer together up around 3 inches in the metal template I made yesterday afternoon.
The hump is a single radius across the drivers side, and rises about 1 1/2" inches above the cross bar level. I also have a height and reach adjustable steering column fitted..
Chris
Coupe 65 #646
Ordered - 28 May, 2014.
Delivery, Sydney - 18 August.
Engine running - October 2015
First gokart - December 2015
northshore2014 is offline
post #123 of 384 (permalink) Old 02-24-2015, 03:20 AM
mmarshall's Avatar
Chris I finally got that measurement for you. The forward edge of my crank pulley to the X brace is 12.25".
FFR Coupe #340, 2003 LS1 350 RWHP, T56 6 speed, QT BH, Champ 10.5 QT pan, 5 Lug and AC, SAI mod, Nitto NT-01's 275/315 ..Licensed for 28k..Just over 30k w/race tires and many mods
Build started - 8 Apr 2008
2011, 2012, and 2013 St Louis region XP Champion
mmarshall is offline
post #124 of 384 (permalink) Old 02-24-2015, 04:43 AM Thread Starter
Awesome.. thanks Mike.. Im 10.75".
LS1 is 24 inches from the rear of the block to the front of the crank pulley.. not sure if the LS3 is the same block or engine mounting point (COG)
Any thoughts..?
Chris
Coupe 65 #646
post #125 of 384 (permalink) Old 02-25-2015, 08:33 PM Thread Starter
First fibreglass attempt.
Cant locate the HD foam you guys seem to have ready access to in the States, so Ive used paper lined foam board.
The pics are of the piece, pre the second coat of builders bog (aka Bondo or similar as best I can tell) and final finishing.
I was considering two options.
One, to glass over three sides of the piece (ex the bottom plane), trim it off once glassed then glue it to the metal section, before covering with dash underlay and a top skin.
Or
Cover the foamboard piece with the brown packing tape (that the resin doesnt apparently stick to) and use it as a mould, which will then create a hollow piece.. ??
Appreciate any thoughts..
Cheers
Chris
Coupe 65 #646
post #126 of 384 (permalink) Old 02-25-2015, 09:04 PM
Personally, I would do the plug -> Mold -> Final piece. It may seem like a lot of work, but you can make the plug in the final shape. Make the mold and then the final piece.
If you make a shape and then apply fiberglass, you will have to guess what to shape minus the fiberglass and then apply fiberglass. Then spend a lot of time shaping the final product. What you will find is the final product might not be what you originally wanted and you will have to fiddle and adjust it until you get it right.
The time spent on both will probably be the same in the long run and you will have a much better final product.
I rather spend time shaping Bondo, than grinding and sanding fiberglass.
oxide is offline
post #127 of 384 (permalink) Old 02-26-2015, 01:11 AM Thread Starter
thanks Oxide..
Have taken your advice. Will need to do the glass in two stages due to the overhanging lip on the cowl.
Cheers
Chris
Coupe 65 #646
post #128 of 384 (permalink) Old 02-26-2015, 02:51 AM
I hope you post some pics of your work. If you have any questions, please ask.
oxide is offline
post #129 of 384 (permalink) Old 02-26-2015, 04:24 AM Thread Starter
Well attempt 1 was a fail.. the matting was still a soggy mess after 4 hours.
Carefully measured the resin and catalyst this time (with thanks to my daughters cooking cups and a medicine vial)
Thankfully the matting doesnt stick at all to the brown packing tape. Attempt #2 currently on the bench.. Will post some pics when the fumes die down and Ive had a chance to trim it up..
Cheers
Chris
Coupe 65 #646
post #130 of 384 (permalink) Old 02-26-2015, 12:51 PM
Cheers
Chris
Chris,
The result will depend on the quality of the resin that you use. I only use Vipel FO10-TBN-28 . My regular supplier ran out and gave me the lower cost stuff. I measure down to the gram and I had one batch smoke and the next batch took days to cure. And I mixed it exactly the same as the FO10. I took it back and she refunded it. One weekend I needed some resin as I ran out mid work. I ran down to the local boat shop and got some vinyl ester from them. It took 2 days to cure completely. I only use the FO10 now.
And yes, you really need to be careful about proportions. I mix down to the gram.
oxide is offline
post #131 of 384 (permalink) Old 02-27-2015, 10:25 PM Thread Starter
Getting there with my fiberglass bits.. had forgotten how smelly, messy and dusty it is to work with.. !!! Have a good respirator (now)...
The second part is a glovebox insert.. I had used foamboard with the intention of removing it once cured... but that didnt work out.. ! I may line this with fiberglass in a couple of stages.. Have some 3mm (1/8"th) ply for any future attempts.
Thanks for the advice..
Chris
Coupe 65 #646
post #132 of 384 (permalink) Old 03-01-2015, 08:26 PM
mmarshall's Avatar
Any thoughts..?
Chris
Chris I think you will be very near a 50/50 bias which will be very balanced. I found that every inch the drivetrain is moved shifts the bias nearly 1%. This is a rough rule of thumb as the LS block is lighter and the T56 is heavier. Much of the weight of the T56 is in the rear as compared to the TKO. If you run a 275F/315R tire the car will be close enough to neutral to tune with the suspension. IMO!
post #133 of 384 (permalink) Old 03-01-2015, 08:31 PM Thread Starter
Thanks Mike,
Would have been better to be 48/52, so it had a neutral balance under braking, but we will have to give it a try and see whether understeer is an issue that cant be turned out with suspension geometry / roll bar as well as a little more right foot..
Cheers
Chris
Coupe 65 #646
post #134 of 384 (permalink) Old 03-01-2015, 10:41 PM
mmarshall's Avatar
I bet with you in the car and a decent fuel load it will be close 52 rear. Minor balance adjustments can be tuned with camber, spring rates, shock settings, and tire pressures. Even with a bunch of rear brake bias the car is stable and controllable while trail braking.
post #135 of 384 (permalink) Old 03-02-2015, 02:15 AM Thread Starter
thanks Mike..
Will be interesting to see..
Drew up a couple of AC ductwork pieces to add to the current backlog for the 3D printer... been waiting about 6 weeks for a replacement control board. These parts cost a few cents to produce, no dust, no fumes.. prob not a lot different in time spent to doing it in fiberglass, although revisions / mods are quick as revising the CAD..
Will be good to move past the AC and finish the dash area.. .
Cheers
Chris
Coupe 65 #646
post #136 of 384 (permalink) Old 03-04-2015, 08:54 PM Thread Starter
MkII glovebox roughed in around midnight last night. Will add dynamat to the back face, line with padding and then leather or vinyl consistent with the finish for the dash and console.
Cheers
Chris
Coupe 65 #646
post #137 of 384 (permalink) Old 03-05-2015, 02:23 AM
John Dol's Avatar
Chris,
Now all you need is a pair of gloves!
looks good!
John Dol is offline
post #138 of 384 (permalink) Old 03-05-2015, 05:47 AM Thread Starter
Cheers John.. all tidied up now and sealed.. Will keep an eye out for a suitable pair..
Coupe 65 #646
post #139 of 384 (permalink) Old 03-10-2015, 09:12 PM Thread Starter
Roughed in the rear sheet metal while waiting for the electrical works to progress. Will leave the fitment of the access hatches to the trimmers once I get to that stage.. Have ordered some tie down anchors for the hatch are VW Touareg / Audi, chromed style recessed D hooks. Will bracket and fit those this week.
Desperate to hear some noise.. (Mike Marshall.. stop posting videos of your gorgeous open exhaust.. ). Have a guy lined up to make up a set of headers and an exhaust for rego purposes as well as a set of pipes for installation post the inspection process (noise regs here are a killer for side pipes).
Cheers
Chris
Coupe 65 #646
post #140 of 384 (permalink) Old 03-10-2015, 09:22 PM
What are you doing for gauges? Thought about doing custom ones?
Since I am in Canada, I went metric along with a different look.
oxide is offline
post #141 of 384 (permalink) Old 03-10-2015, 09:49 PM Thread Starter
The quality of your work makes me cry mate.. Seriously.. Im a decent engineer and a very average fabricator..
I got a full set of the metric gauges with my kit.. Autolite I think is the brand. They are not as efficient on space as yours with the chrome bezels. Love the GT40 style dash..
Cheers
Chris
Coupe 65 #646
post #142 of 384 (permalink) Old 03-10-2015, 11:09 PM
I am pretty slow at it. SpeedHut is pretty cool when you want to make custom gauges. I did the artwork in Illustrator and had them make them. Here is one of the versions that didn't make it.
oxide is offline
post #143 of 384 (permalink) Old 03-11-2015, 05:13 AM Thread Starter
Nice.. I didnt know you could get stuff like that.. will have a look and see if they do dash lights and indicators as well
Coupe 65 #646
post #144 of 384 (permalink) Old 03-11-2015, 11:39 AM
I had them make the switch panel for me using the same stuff. Here was version 1. Version 2 is better and covers the whole plate.
I have lights underneath that shine through.
oxide is offline
post #145 of 384 (permalink) Old 03-11-2015, 10:30 PM Thread Starter
Nice one.. am tempted to take a trip to the US just to see your work...
Im using a Motec PDM and switch panel for mine.. Reduces wiring, eliminates plug in fuses and gives me an option to use a Clubman style dash in the future.. . Is going to the left of the tacho.
Cheers
Chris
Coupe 65 #646
post #146 of 384 (permalink) Old 03-12-2015, 12:36 AM
Chris
Chris,
I am in Canada. But you are welcome to come visit.
oxide is offline
post #147 of 384 (permalink) Old 03-12-2015, 01:09 AM
John Dol's Avatar
Now there's a worth while trip. Start with Ron, visit builders in NE, then go to FFR after which you make your way across the US visiting other builders. End up on the West coast where there are quite a few coupes to see,then fly through Hawaii and back to Sydney.
This may give you more ideas expanding your time line and budget though.
Your call!!
John Dol is offline
post #148 of 384 (permalink) Old 03-12-2015, 02:51 AM
mmarshall's Avatar
Yeah and if you time the trip right we can go thrash the LS coupe.
post #149 of 384 (permalink) Old 03-12-2015, 10:51 AM Thread Starter
Thanks gents.. is definitely on the to do list.. along with picking up some sweet go fast bits..
"Yeah and if you time the trip right we can go thrash the LS coupe".. Mike, that IS the purpose of the trip.. lol
Cheers
Chris
Coupe 65 #646
post #150 of 384 (permalink) Old 04-26-2015, 03:26 AM Thread Starter
Update after a few frustrating months.
Had a mate that said he could help with the wiring... he did a fair bit of planning, but unfortunately wasnt real confident with the actual work. So Ive done what I can and have called in someone who can do it right the first time.. (ie, not ME)
I was getting to the stage of prepping for gokart testing, but have gone a fair way backwards now after issues with a clutch pedal that would not actuate once bled.
The engine builder who I entrusted to get the correct parts, well, basically didn't and there was no preload on the thrust bearing (the recommended range is 14-17mm for the hydraulic slave on the TR6060). I have one spacer for the slave cylinder, will have to order a second tomorrow and go from there.
In taking the engine out, Ive unfortunately had to disconnect all of the AC, heating and electrics as well as pull out the dash panels and some of the console sheet metal... is a bit of a mess, but it wont be too hard to put it all back together, but its a decent set back in the build
Best to all..
Cheers
Chris
Coupe 65 #646
Tags
australia , coupe
