Coyote wiring conversion from 347 - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 4 (permalink) Old 11-07-2019, 11:52 PM Thread Starter
bsmith's Avatar
I just ordered a 5.0 Coyote and have been reading up on the wiring. Can I use the wiring from the solenoid in my old setup ?
File Type: jpg 26F1B98E-565D-4A06-85CE-10D596F8D3D2.jpg (14.2 KB, 13 views)
bsmith is offline
post #2 of 4 (permalink) Old 11-08-2019, 04:18 AM
Assume you would install the Coyote with the Ford Performance controls pack? If so, remove the blue start wire on that firewall solenoid and replace with the Coyote harness start wire and it should function just like it does now. Having said that, do you need it with the normally installed Ford PMGR mini starter typically installed on the Coyote that has an integral solenoid? No.
edwardb is online now
post #3 of 4 (permalink) Old 11-08-2019, 05:01 AM
Pro FFR Builder and Moderator
Gordon Levy's Avatar
Assuming you do not want to have an empty space where the relay was. Route the blue wire to the trigger on the starter and ove all the power wires to 1 terminal on your relay.
2nd 2005 Nationals
Over 200 Turnkey FFR's in 21 years and still counting
Gordon Levy is online now
post #4 of 4 (permalink) Old 11-08-2019, 12:14 PM Thread Starter
bsmith's Avatar
bsmith is offline
