Help!!-Rear cockpit bulkhead doesn't line up - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 16 (permalink) Old 08-15-2019, 06:20 PM Thread Starter
kenladdude's Avatar
So have been working on cockpit Aluminum panels past few weeks.
Man my poor drills are getting a workout.
Few Minor flubs (couple extra holes that go to empty space, drill walked on 2 holes)
but noting that I feel like actually getting new panels to fix, I mean hey its all covered by carpet/hidden right?
Overall going OK
See the status pic
Well that was until Sunday when I installed the rear cockpit panels.
Followed manual steps of U-Joint cover, corner panels outside rear corners,
then went to install the Big rear bulk head and UT-oh not lining up no matter what I do.
Best compromise was having the driver side seems to line up OK with Seat belt holes lines up to the frame tubing & the original FF drilled hole, Panel Gap/alignment looks decent.
But the passenger side is all FUBARed no matter which way I do it.
Posting pics of 4 different arrangements (see next posts), none of which seem good
HELP !!!!!
looking for advise here and I am not even sure getting a replacement (rear passenger corner) panel would fix the problem
See next couple of posts for different arrangement (below is the drivers side)
kenladdude is offline
post #2 of 16 (permalink) Old 08-15-2019, 06:24 PM Thread Starter
kenladdude's Avatar
Here are pics of arrangements
1 - seat belt hole aligned with the frame tubing (like Driver side) with corners/sides in clecoed in original locations
File Type: jpg 1-Seat belt hole lined up Side pannels clecoed(1).JPG (172.5 KB, 32 views)
File Type: jpg 1-Seat belt hole lined up Side pannels clecoed(2).JPG (180.0 KB, 29 views)
File Type: jpg 1-Seat belt hole lined up Side pannels clecoed(4).JPG (153.1 KB, 28 views)
post #3 of 16 (permalink) Old 08-15-2019, 06:25 PM Thread Starter
kenladdude's Avatar
2 - Moving bulkhead down so flush with floor but then the bottom of seat belt holes are about 1/3-3/8" below the frame tubing
The panel to panel gap is better than #1 here but still not great.
post #4 of 16 (permalink) Old 08-15-2019, 06:26 PM Thread Starter
kenladdude's Avatar
Last ones
3- SB holes still low as in #2 but now unclecoed the corner panel from original position and lined up to original FF drilled hole.
Now the panel to panel gap is OK but the Corner panel is sitting off the floor and the outer corner (of the corner panel) is ~ 1/2" off the frame
& none of the original holes line up.
4- Moved the SB Holes back to lined up with frame (same as #1) & using the FF hole
While the top lines up between the 2 panels & panel to panel gap looks OK, everything else is jacked.
Both panels are off the floor now, no original holes line up outside corner is off frame (like in #3) . . .
I know that using the original FF holes is not always the best course,
but over all they have worked well for the most part as a guide for the rest of the cockpit panels (just some minor trimming so far).
Something just doesn't seem right here, I feel like I am missing something in the process.
I checked the cross tube & it seems to be the same height on Driver & Pass side (at least from the large main tube below it).
Seat belt holes seem to be the same distance from the bend/crease in the bulkhead.
If I need to order a new corner panel and start over that is fine, I just don't see what that would solve as I think I would still end up with issues.
Grr. . . . .
Any help or advise would be much appreciated
File Type: jpg 3-On floor to original FF hole (5).JPG (200.8 KB, 18 views)
File Type: jpg 3-On floor to original FF hole (6).JPG (192.0 KB, 16 views)
File Type: jpg 4a-Seabelt holes lines up FF hole side pannels not celcoed (8).JPG (163.9 KB, 16 views)
File Type: jpg 4-Seabelt holes lines up FF hole side pannels not celcoed (6).JPG (106.2 KB, 16 views)
File Type: jpg 4-Seabelt holes lines up FF hole side pannels not celcoed (7).JPG (134.1 KB, 16 views)
post #5 of 16 (permalink) Old 08-15-2019, 08:46 PM
Hard to follow everything you've posted. But for starters the seat belt holes are supposed to be somewhat below the chassis tube. Since the belts are attached behind and below the rail, the hole is placed below so the aluminum panel edge isn't against the belt. You can see where they fell on my #8674 build in the attached picture. Allowing the rear panel to be lower than you have in many of your pictures might help.
My other question is are you installing the panels in the exact sequence as in the instructions, and exactly following the recommended overlap directions? And also don't get real hung up on the shipping screws (if you are). They may/may not be exactly where the part needs to be.
My experience with several of these is the parts are amazingly accurate and fit quite well. Only thing I've ever had to do in the cockpit aluminum is adjust a couple bends a little and also clearance a few welds.
and
edwardb is online now
post #6 of 16 (permalink) Old 08-15-2019, 09:16 PM Thread Starter
kenladdude's Avatar
Thanks, Ed.
As always you have great feedback and suggestions & thanks for the pic.
Yes the main thing I thing I was trying to figure out how critical was the position of the SB holes, I was worried about chaffing the belts.
I will try shifting the bulkhead down (on both sides and see how everything lines up).
Make sense as overall seems to line up better the lower it is.
Yes installing the sequence as in the instructions (so far as I can tell)
and yes overlap (over vs under I assume you mean)
+ I had marked over vs under before taking panels off (with many pics for ref)?
This is the first time that the shipping screws have really seemed to be off, will just have to let that one go.
Agreed on how well everything has seemed to fit.
This is the first time something with the panels really seemed off,
so I guess that is why I got a little flustered and stepped away to think about it and ask for help.
I will breath and ignore the shipping screws and do some adjustments this weekend and see if it falls into better alignment.
What order do you suggest for drilling and mounting the bulkhead panel ?
Start at the top and work down?
I tend to do one row/tab/area at a time, test fit-Cleco, mark panel for next area/frame bar, repeat till complete
post #7 of 16 (permalink) Old 08-15-2019, 10:51 PM
I don't do anything special with any of the panels. First mark them where the frame is located, e.g. Sharpie tracing on the back side. Then lay out where I want the holes. Drill and de-burr the holes in the panel. Then back on the frame, locate in position, usually clamp where it's supposed to be, and start drilling holes and putting in clecos. Typically doesn't move once it's clamped in place and drilling/clecoing starts. I also typically line up all surrounding panels before drilling/clecoing.
One other hint. Maybe you've seen mentioned in other threads. Don't rivet the back cockpit wall until the trunk floor is done. If you rivet the back wall before the trunk floor, you'll have trouble getting the rivets in the trunk floor.
and
post #8 of 16 (permalink) Old 08-16-2019, 12:21 AM Thread Starter
kenladdude's Avatar
Roger that Ed, usually follow your recommendations/procedures
Biggest mistake was not putting the rear bulkhead panel in to test fit before drilling the surrounding ones.
Forgot to think that many steps ahead (have done test fitting in other areas like footboxes).
Doing the trunk next so need to not forget to do that
& Yup seen about rivet trunk first, just clecoing everying thing now, so hopefully I remember when it comes time to final rivet.
Definitely follow your build threads (& a couple others) for tips & tricks, just so much to try to remember . . . .
Thanks for all the time you spend help us first timers out.
post #9 of 16 (permalink) Old 08-16-2019, 01:05 AM
You need one cleco about every 5 or 6 holes, not everyone.
rich grsc is online now
post #10 of 16 (permalink) Old 08-16-2019, 04:18 PM Thread Starter
kenladdude's Avatar
Thanks Rich
Understood, I plan on removing majority once finished with all panels, just haven't gotten to it yet.
I'm a belt and suspenders kind of guy
post #11 of 16 (permalink) Old 08-16-2019, 08:19 PM
You must've got a great deal on those things.. I thing I only had about 25 total.
post #12 of 16 (permalink) Old 08-16-2019, 08:40 PM
Avalanche325's Avatar
Looks like belt, suspenders, and Depends.
MKIV Roadster....FFR7694
Avalanche325 is offline
post #13 of 16 (permalink) Old 08-20-2019, 10:56 AM
You mentioned that a couple of times your drill bits "walked". Are you using a spring loaded center punch to dimple prior to drilling? If not, get one from Harbor Freight.
FFR7995
MK IV
Prestige Motorsports 347 SBF, Moser 8.8 (3.31), 3 link, TKO 600,hydraulic clutch, PS, Heat/AC, 17" Halibrands, Nitto 555s,
Bobby Doug is offline
post #14 of 16 (permalink) Old 08-20-2019, 07:32 PM Thread Starter
kenladdude's Avatar
Yes I use the center punch.
One of the holes onto the round frame tube and just didn't bite,
skated of the side of the tube and let me tell you drill bits can make for good routers on the Al panels (went about 1/2" before I stopped) Grr.
It also must have broken the tip of the bit b/c when I went to the next hole (on square tube this time) it did the same thing b/c of the broken tip.
Overall 2 holes out of like 500 is not to bad (< .5% error ?), IMO
Wish it hadn't happened but both are basically going to be hidden anyways so . . .
post #15 of 16 (permalink) Old 08-20-2019, 07:34 PM Thread Starter
kenladdude's Avatar
Well actually it has been one of the cheaper things over all for the project
post #16 of 16 (permalink) Old 08-20-2019, 07:49 PM Thread Starter
kenladdude's Avatar
Did a little finagling this weekend, got the rear panels to line up better over all once I moved the bulkhead down a little (SB Hole edge below frame bar).
Would have liked a little better but best comprise with the situation as it is (Other panels already drilled, lesson learned)
Still not as nice as yours of course
Will post some pics once I get everything locked down.
Thanks again Ed.
