Cherry Bomb Muffler Under Car - FFCars.com : Factory Five Racing Discussion Forum
 15Thanks
  • 1 Post By Alan_C
  • 1 Post By Avalanche325
  • 1 Post By Keysergogo
  • 2 Post By jolsen42
  • 2 Post By Dave Schwaab
  • 1 Post By jolsen42
  • 1 Post By SC210Ford
  • 3 Post By Jim Doak
  • 1 Post By Alan_C
post #1 of 18 (permalink) Old 08-10-2019, 12:33 PM Thread Starter
Cherry Bomb Turbo Mufflers #16808CB seem like they will fit under the MK4 seat pan with 3/4 inch space for airflow. They are 3.25 inches high. Online sound clips seem a lot quieter than side pipes. Anybody ever try one under a Cobra with 2.25 inch pipe?
https://www.summitracing.com/parts/imm-16808cb
Bill46 is offline
post #2 of 18 (permalink) Old 08-10-2019, 01:34 PM
Alan_C's Avatar
Consider using Spintech mufflers. The offer a number of low profile mufflers with options on sound level. They make mufflers for use with with round and oval exhaust pipe. The oval pipe, although expensive, could help with ground clearance in critical areas.
https://spintechmufflers.com/street-...r-low-profile/
jolsen42 thanked this.
MK4 base kit, 2004 Mach 1 donor, 4.6L DOHC, TR-3650 5-speed, narrowed stock axle with 3.55 gears and TruTrac, PS, PB, ABS, 17" Halibrand replica wheels, 255/40-17 F 295/35-17 R Kumho XS, dual roll bars, Kirkey high back seats, paint by Jeff Miller, registered 9/2014, sold 3/1/2018.
Alan_C is offline
post #3 of 18 (permalink) Old 08-10-2019, 02:38 PM Thread Starter
Thanks Alan, I have thought about Spin Techs and they are a real possibility. I was about to order them when I saw the Cherry Bombs and for the difference in price, maybe I should try the Cherry Bombs. I know you "get what you pay for", but unless you ask you never know.
Bill46 is offline
post #4 of 18 (permalink) Old 08-10-2019, 06:53 PM
Avalanche325's Avatar
There are a couple guys with under car systems. I would definitely find out what they did. Cheap mufflers tend to be HP killers if you care about that.
Bill46 thanked this.
MKIV Roadster....FFR7694
Avalanche325 is offline
post #5 of 18 (permalink) Old 08-10-2019, 09:30 PM
It really depends how anal you are about keeping things above the lowest point on the frame. I used a 3” thick spintech on each side, and yes the case is 3”, but there are seams that add another 1/8+ to the overall thickness of the muffler. Keep that in mind with these Cherry Bombs.
Round 2 1/4 pipes do not leave much room under the footboxes for an air gap without dipping a little below the frame (or very close to it), I used oval 2.5” pipe and even that was cutting it close.
I tried my best to keep everything as tight as possible, and my “calculations” had my muffler sitting about an 1/8” above bottom of the frame and 3/4” off the floor pan.... but with welding and holding stuff in place and making mounts etc., those small tolerances get eaten up pretty quickly - I ended up with the muffler a butt-hair higher than the frame.
I’ve got a thread on it floating around somewhere, plenty of pics to show just how tight things get.
Keysergogo is online now
post #6 of 18 (permalink) Old 08-10-2019, 10:28 PM
Real time recon's Avatar
Curious.Why a muffler 'under' a Cobra ?
Real time recon is online now
post #7 of 18 (permalink) Old 08-10-2019, 10:41 PM Thread Starter
Actually, two mufflers for undercar exhaust. Tired of side pipes blasting in my ear plus I like the look better.
Bill46 is offline
post #8 of 18 (permalink) Old 08-11-2019, 12:54 AM
jolsen42's Avatar
Because that's what the originals came with!
Here is a picture of mine.
John O
John4337 and RBachman thanked this.
Government is a disease...
...masquerading as its own cure…
FFR1293K-289 slab side "Mr Bruce" body, 289 hi-po, original Cobra dual quad with Carter 3258s and 3259s carbs, original AMCO luggage rack, Tremec TKO, 3-link 3.55 rear, spoked wire wheels, under car exhaust. A replica of CSX 2367.
jolsen42 is offline
post #9 of 18 (permalink) Old 08-11-2019, 01:38 AM
John4337's Avatar
I used SpinTech cruiser series mufflers. They are 2 1/4 inches thick and match the 2 1/4 inch pipe I used.
FFR #7388 - Mk 4 Complete Kit w/ IRS, Ordered 10/21/10, Completion Date 11/13/10, Delivered 12/8/10, Drivetrain in 8/21/11, Graduated 6/10/13
John4337 is offline
post #10 of 18 (permalink) Old 08-11-2019, 04:01 AM
Dave Schwaab's Avatar
Send a message via AIM to Dave Schwaab
Faq
jolsen42 is being a little humble here, but his under car exhaust is illustrated in the FAQ section:
https://www.ffcars.com/FAQ/undercarexhaust.html
Life got in the way!
Sold my kit to JoeE.
Already planning to start again.
Dave Schwaab is offline
post #11 of 18 (permalink) Old 08-11-2019, 10:34 AM
John O
Thanks,yes,I knew that.I thought we were talking about a FFCobra.
post #12 of 18 (permalink) Old 08-11-2019, 03:05 PM
John O's car is not an original Cobra. It is indeed a Factory Five. He re-bodied the car in his quest for authenticity. Currently, it has been re-bodied again, this time with a slabside body by Mr Bruce. Beautiful!
jolsen42 and Real time recon thanked this.
post #13 of 18 (permalink) Old 08-11-2019, 03:39 PM
jolsen42's Avatar
Thanks David, and a belated "Happy Birthday" to you.
John O
Dave Schwaab thanked this.
jolsen42 is offline
post #14 of 18 (permalink) Old 08-16-2019, 08:34 PM
Engine Masters just did a $40 muffler shootout on their latest episode. The did several of each; pass-through, chambered , and turbo. There was a Cherry Bomb in each group. Of course, pass through had the most HP and was loudest. The worst was about 20 HP less than the best on a 600hp engine.
post #15 of 18 (permalink) Old 08-16-2019, 11:36 PM
SC210Ford's Avatar
My dad’s mk 3.1 has under car exhaust with cherry bombs.
It sounds good, but my car with side pipes sounds a lot better.
He has factory headers and the j pipes,
I’m sure the headers are the biggest restriction. With a good set of headers it would have a lot less exhaust than a stock mustang.
306ci Speed Density, 4into4's, T-5, 3.55s
CobraR wheels, Lexus Blue, White stripes
My roadster is the first car I've ever owned that wasn't a Mustang, is that wrong?
SC210Ford is online now
post #16 of 18 (permalink) Old 08-17-2019, 02:14 AM
Jim Doak's Avatar
I built my undercar exhaust using Spintech mufflers and some ovalized as well as round tubing.
I'll admit I'm biased but I really like the look and sound.
jolsen42, John4337 and Bill46 thanked this.
Jim Doak
FFR 2117, Under Car Exhaust, Power Steering and Hydraboost Power Brakes, Rear Flares
Jim Doak is offline
post #17 of 18 (permalink) Old 08-17-2019, 10:10 PM
Alan_C's Avatar
I like what you did with the Spintechs, but a little surprised you did not route the exhaust all the way to the back. What you did sort of looks like an under the car side exhaust? Last week I ordered the Spintech side exhaust kit for 65-85 Mustangs together with their universal x-pipe kit. I don't expect to see it for a couple of week yet, but I am looking forward to fitting it to my 1970 Mach 1 restomod.
Alan
Alan_C is offline
post #18 of 18 (permalink) Old 08-17-2019, 11:03 PM
SC210Ford's Avatar
This is the same layout as my dad’s car but he used cherry bomb glass packs
