Creaking sound from toll bar. - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 6 (permalink) Old 07-19-2019, 07:47 AM Thread Starter
Nigel Allen's Avatar
Hi all,
After a few thousand k's my car has developed a creaking sound which seems to come up through the roll bar on the driver side. It sounds like the rollbar itself however all the bolts are tight. The noise is only there when the car is being driven over undulating road surfaces. I have tried rocking the car via the rollbar when parked, but can't make the noise happen. The car is a right hand drive Mark 4. therefore the rollbar is effectively on the right-hand side. It has earlier series independent rear suspension fitted. Everything seems tight and how it should be.
Anyone able to shed light on what the noise source might be?
Many thanks in advance, Nigel
Nigel Allen is online now
post #2 of 6 (permalink) Old 07-19-2019, 10:56 AM
Lift up your roll bar trim rings and check to be sure that the bar isn't contacting the body.
BTW, Although you clarified later when I read "driver's side" in the first sentence I wondered if you meant the correct driver's side or the wrong driver's side
Cheers,
JKleiner is online now
post #3 of 6 (permalink) Old 07-19-2019, 12:25 PM
CFranks's Avatar
Is it possible you have to lube up the chassis? Mine creaks like an old man every time I put it up since I havenít fully lubed yet. Just a thought if the bars arenít contacting the body as mentioned below.
CFranks is online now
post #4 of 6 (permalink) Old 07-19-2019, 02:27 PM Thread Starter
Creaking sound from roll bar.
G'day Jeff, thanks for the tip, I will check body to roll bar clearance in the morning. Nice quip about the driver's side, maybe the right side is the right side after all. Then again, I am left handed and everything is 'down under' here.
Cheers, Nigel in South Oz.
post #5 of 6 (permalink) Old 07-19-2019, 02:29 PM
Well Used Member
Boat737's Avatar
I had a 'chirp' that I eventually traced to the body/trim ring rubbing on the roll bar. When the body was first fitted, there was no interference and the roll bar was nicely centered in the hole and ring. After 400 or 500 miles, the body settled, or shifted, or aligned itself a bit, and was just touching the roll bar.
I put a little silicone spray on a Q-tip and put just the tiniest bit of it on the roll bar where it was touching. Did the trick. The noise has not com back for 800 miles now.
If Brute Force doesn't work, you're not using enough of it.
Basic Stuff: MK4 Complete Kit #8439, Wilwood's, 17" Halibrands,
Extra Stuff: SS Brake/Fuel Lines, Breeze cooling, battery mount, SS Roll Bar,
Old Fart Stuff: Heater, Seat Heaters, Footbox Fresh Air, Stereo, Keyless ignition, Power Steering, Hyd Clutch
Young & Dumb Stuff: 427w Dart, TKO600, 3 link Moser M9/Ford 9", 3.5:1, Eaton TruTrac Posi
Boat737 is offline
post #6 of 6 (permalink) Old 07-20-2019, 05:57 PM
For anyone else following this thread I will add a hint. The same thing can happen to the windshield posts.
CraigS is offline
Laser Stan
