Recommendations for Spark Plug Wires - FFCars.com : Factory Five Racing Discussion Forum
 2Thanks
  • 1 Post By JKleiner
  • 1 Post By turbonut48
post #1 of 18 (permalink) Old 07-13-2019, 05:12 PM Thread Starter
Carl Johnson's Avatar
Hey guys, I need a new set of plug wires. Im running a 5.0 (302), with GT40P heads and FFR/BBK 4 into 4 headers.
My FRPP wires were good for a few years, but 2 are close to the headers and failed. Thanks for your suggestions.
FFR 4857K - MK II, 5.0 EFI, 3.73's, Levy Street Bump Steer kit, Power Brakes, Paxton, Fiji Blue with white stripes
Carl Johnson is offline
post #2 of 18 (permalink) Old 07-13-2019, 06:38 PM
I've had excellent results with Taylor wires. Ford Racing wires not so much...
Mark Reynolds thanked this.
JKleiner is offline
post #3 of 18 (permalink) Old 07-13-2019, 07:33 PM
M DOUGHERTY's Avatar
I have had good luck with ford racing wires.
the GT40P heads are a problem with the FFR headers.
there is 1 plug very close on each side that will eventually burn
the boot due to proximity to heat.
best Thing I have found are the Kevlar sleeves to go over the boots.
The Traveling Builder
M DOUGHERTY is offline
post #4 of 18 (permalink) Old 07-13-2019, 11:47 PM
DWIGHT's Avatar
Thumbs up
Taylor or MSD kits.
Make them so they fit your motor. Don't buy the universal set. They never fit the motor, two wires are to long and one or two are to short.
They are very easy to make up. All you need is a vise.
1966 Ford Fairlane GT 2 door hardtop with 390 5 speed.
DWIGHT is offline
post #5 of 18 (permalink) Old 07-14-2019, 12:54 AM
Cobra Jon's Avatar
Plug Wires
I like Taylor, but I've also used Accel wires with the ceramic boots. I had a car that kept burning a couple of the boots. The ceramic boots solved the problem.
Mark IV #7900
Cobra Jon is offline
post #6 of 18 (permalink) Old 07-14-2019, 01:22 PM
Ditto. After burning through the first set of wires after 1000 miles, no problem with the ceramic ones ever since.
Brien767 is offline
post #7 of 18 (permalink) Old 07-14-2019, 02:46 PM
silver_pilate's Avatar
I used these hi temp boot sleeves.
I'm still in go kart so don't know how it will work out just yet.
MKIV Complete Kit(order placed: 4/5/16; order completion: 5/14/16; delivered: 5/24/16): 3-link, PC, cutouts, vintage gauges, glove-box dash, chrome roll bars; 17" wheels, B/T leather seats, wind wings/visors sourced during separate 50/50 sale; side pipes and headers sourced through Gan-n
First start: 6/22/19
Drive train: Levy 408w w/carb, TKO600, Moser 8.8 with 3.55s and GT rear brakes
Paint Plan: Under consideration (probably dark grey/titanium with silver stripes)
silver_pilate is offline
post #8 of 18 (permalink) Old 07-14-2019, 08:57 PM
turbonut48's Avatar
I bought the boots for mine. Used them for 4 years now. They ve protected the wires really well.
Tom H
Danner thanked this.
turbonut48 is offline
post #9 of 18 (permalink) Old 07-14-2019, 09:47 PM
Ray
Ray's Avatar
Send a message via Yahoo to Ray
I've got these: https://performancedistributors.com/...ivewires-ford/
You can also get them from Summit Racing.
Ray
Ray is online now
post #10 of 18 (permalink) Old 07-14-2019, 11:26 PM
niceguy's Avatar
I have good luck with Ford racing wites9
niceguy is offline
post #11 of 18 (permalink) Old 07-15-2019, 12:27 AM
I bought new Ford Racing wires for my 1996 DOHC 4.6. Put them on new when I put the motor in the Cobra. Car ran good for a few hundred miles and then started to misfire, gradually getting worse and worse. Chased the problem for months before I decided to try the old wires, immediately ran perfect again. Multiple wires out of the set failed. Replaced with Taylor wires and no problems since.
bcshannon5448 is offline
post #12 of 18 (permalink) Old 07-15-2019, 01:04 AM
Funny how our experiences differ isn't it? I have had Summit house brand universal wires on mine for about 5 years along w/ boots like silver_pilate's. The 45 deg plug ends fixed the couple that were in contact w/ the headers in the previous set w/ straight ends.
CraigS is offline
post #13 of 18 (permalink) Old 07-16-2019, 03:20 AM
Plug angle on the GT40P is different and so more of a challenge to keep boots away from headers. I'm a fan of trim your own to length and assemble (Taylor)
Mark Reynolds is offline
post #14 of 18 (permalink) Old 07-16-2019, 04:50 PM
I second Mark, I thoroughly enjoyed getting the Taylor cut-to-length wires and using the crimping tool. It cuts and crimps the ends perfectly and effortlessly. I haven't been able to re-figure out the Photobucket thing but my wires are nice and tidy.
_
_
NiceGuyEddie is offline
post #15 of 18 (permalink) Old 07-16-2019, 05:37 PM
Bill_VA's Avatar
Same here. I have the big, thick Taylor custom set. Get the good crimping tool, the little aluminum thing will only frustrate you. I also have a set of Roush aluminum wire looms to lock the wires down the keep them exactly where you want them (and away from headers).
New Owner of
Bill_VA is offline
post #16 of 18 (permalink) Old 07-16-2019, 08:54 PM
Avalanche325's Avatar
I am using Taylor. No issues in 22,000 miles
Completely agree with Bill_VA, get the proper tool.
MKIV Roadster....FFR7694
Avalanche325 is offline
post #17 of 18 (permalink) Old 07-17-2019, 01:42 PM
Buck
Buck8one2's Avatar
I vote with Taylor Universal cut to length. Also get the 135 boots, they clear the headers so they don't burn. Silicone electrical grease helps a lot mounting the boot.
Buck
302 bored 0.030, AOD by Monster, RPM Air Gap, FITech EFI, 8.8 with 3.73 gear, 17' Foose Nitrous 5 spoke wheels, and Nexen N3000 tires
Buck8one2 is offline
post #18 of 18 (permalink) Old 07-18-2019, 01:53 AM Thread Starter
Wires
Thanks all, I'll tackle this after vacation.
