Hydraulic clutch-opinions? - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 10 (permalink) Old 07-13-2019, 12:26 PM Thread Starter
Steven K's Avatar
I am almost at the stage of mounting the clutch and transmission and I figure there is no better or more convenient time to add the hydraulic clutch, but I am curious what everyone's experience is with it. Any opinions, for or against, are welcome.
Thanks.
Steve K
FFR#3906
Steven K is offline
post #2 of 10 (permalink) Old 07-13-2019, 01:20 PM
I bought the slave cylinder kit from Daze: https://www.dazecars.com/dazed/TestT5kit.html
Then I got a wilwood master cylinder from Summit and a pre-made hydraulic line from them too, and an extra reservoir from FFR.
Wasnít very expensive to do, and the wilwood pedal box from FFR was designed for a 3rd master cylinder so everything just bolted up essentially. I never messed with the cable clutch so I have no experience to compare the two, but the hudraulic clutch feels exactly like the one in my daily driver jeep.
Keysergogo is online now
post #3 of 10 (permalink) Old 07-13-2019, 01:51 PM
FFR3247's Avatar
I have had issues with my clutch in the past and wanted to go hydraulic and as a last effort bought a really good cable from Maximum Motorsports. It’s like butter now. Can’t see how hydraulic could be any easier and I have driven many with one.
Just a thought
FFR# 3247,3535,3730,3951,4338, and 5665
FFR3247 is offline
post #4 of 10 (permalink) Old 07-13-2019, 09:38 PM
The slave cylinder ends is relatively easy to switch over. I think the tough part will be the MC end. Per Keyser, it looks like later FFRs are set up for it. I am not sure about yours though. When my 8 yrs old cable gave up 2 years ago I installed an oem Ford cable. Not sure how my Spec2+ clutch is compared to others but the clutch effort is just fine for a 71 yr old non athletic type.
CraigS is offline
post #5 of 10 (permalink) Old 07-13-2019, 11:42 PM
DWIGHT's Avatar
Thumbs up
I put 42,000 miles on my Cobra with a cable. I had to adjust it a couple of times when the cable stretched.
I have several old hyd slaves in the back room that I replaced on other Cobras.
I like a cable
1966 Ford Fairlane GT 2 door hardtop with 390 5 speed.
DWIGHT is offline
post #6 of 10 (permalink) Old 07-14-2019, 04:12 AM
CDXXVII's Avatar
Hydraulic Clutch
I did the same thing. Works great and a super simple design. I used a Tilton Master but same experience with the Wilwood pedal box.
I used a variation of this kit for a TKO600 -- https://www.dazecars.com/dazed/Test3550bracket.html
Great thing about this kit is that the slave cylinder is a common stock part. You will always be able to find a replacement. https://www.dormanproducts.com/p-33627-cs37793.aspx
Wasn’t very expensive to do, and the wilwood pedal box from FFR was designed for a 3rd master cylinder so everything just bolted up essentially. I never messed with the cable clutch so I have no experience to compare the two, but the hudraulic clutch feels exactly like the one in my daily driver jeep.
First Start 05/23/2015
First GoCart 05/23/2015
CDXXVII is offline
post #7 of 10 (permalink) Old 07-15-2019, 05:02 PM
Chepsk8's Avatar
As I have commented on many threads, I designed and built my own external slave system that works with the Fox pedals and a SPEC Mk3 clutch. It has smooth easy effort, and hes been perfect since I put it together in 2005.
I am one for the fluid side!
Chepsk8 is online now
post #8 of 10 (permalink) Old 07-16-2019, 02:54 AM
mdjr70's Avatar
I am using a Tilton hydraulic clutch release bearing and I couldnít be happier with it.
Sam
Coupe #453 delivered June 28, 2009;
First drive October 29, 2013.
Completed October 5, 2016.
461 cid Butler Performance Pontiac
522 hp, 577 ft/lbs @ 4500 rpm
SCCA Super Production Class ID 10-1488
"This might be difficult..."
Blog of my build:
Link to my photo album:
mdjr70 is offline
post #9 of 10 (permalink) Old 07-16-2019, 09:12 PM
Avalanche325's Avatar
I had a cable clutch for 21,000 miles. Mine was the old design with the offset quadrant. For anyone that still has that, take this as a warning. The offset torque ruined my Wilwood pedal box. It ovaled the hole in the box that holds the pedal shaft. No fun changing a pedal box in a complete car.
Back to the subject. The cable was OK, very stiff. My clutched engaged closer to the floor than I liked even with some pre-load, but there is no real way to adjust that. My Ford cable (used the FFR one as a spare) was starting to fray a little a the quadrant. Going to change the cable is when I found the slop in the pedal.
I changed to a hydraulic setup. It is a little bit lighter. More linear. It has WAAAAY better feel. I was surprised at that. It also engages about half way up which is perfect, especially when autocrossing or on the track where you shift fast. I also have adjustability if needed. So far, I love it.
I used a Dazecars salve cylinder (some OE type part, with a nice amount of throw), and his adjustable pushrod. I made my own bracket and used a Wilwood master.
I would definitely go hydraulic if I were doing it again.
MKIV Roadster....FFR7694
Avalanche325 is offline
post #10 of 10 (permalink) Old 07-16-2019, 10:47 PM
I have fortes hydraulic setup and it’s great, I’ve driven a FFR wilwood cable setup and actually struggled as it just didn’t have nearly as nice a feel.
Very happy with my decision, so far. Knock on wood.
Murd is offline
