AFR 185 Heads and MKII Hooker 4 into 4 sidepipes - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 5 (permalink) Old 06-25-2019, 01:28 PM Thread Starter
Chepsk8's Avatar
I know the old "Header" section of the sidepipes had to have a bevel ground into the lower flange edge to clear a bump on the GT-40 heads.
Do the AFR's need more clearance?
Chepsk8 is offline
post #2 of 5 (permalink) Old 06-25-2019, 03:19 PM
Not sure about the 185s but from my experience with AFR heads (205, 225 & 220s) the flat mounting surface is fairly large. I have had to cut the top of the header flange to clear a "lip" just below the valve cover mounting surface on a previous set of headers.
I just finished a flange design for 220 & 225s, spent a lot of time measuring and drawing in CAD. Had new flanges laser burned, came out really well.
No experience with the GT-40 heads and the "bump".
Not sure if I can help but would be happy to try.
Jim1855 is offline
post #3 of 5 (permalink) Old 06-25-2019, 04:22 PM
I'm sure the AFR heads have more clearance, but I'd still do a quick check when they show up. I have the BBK long tube headers. I can't go check as my car is still on "high & dry ground" storage, may come home today or tomorrow.
rich grsc is offline
post #4 of 5 (permalink) Old 06-25-2019, 06:41 PM
2007 Calendar Cover Car
Redfish's Avatar
My MKII-vintage headers bolt right up to my AFR 185s, no issues.
FFR4462K MKII
331 Dual 390CFM Holley Quads, AFR 185s, Comp Cams XE274HR
315 Mod, IRS, FR500s, Power Cobra Brakes, Manual Steering
'68 Mustang Hardtop, 302, C4
Redfish is online now
post #5 of 5 (permalink) Old 06-25-2019, 11:44 PM
trevor's Avatar
I have the hooker Mark II headers with AFR185 and AFR205 heads. Both fit fine.
trevor is offline
