MKIV passenger footbox scale drawings - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 4 (permalink) Old 06-23-2019, 12:28 AM Thread Starter
mdutton11's Avatar
Looking at Don Payne's PDF's of the passenger footbox mod drawings. Does anyone have a link to the drawings in full scale that can be printed at a copy / print shop? The only ones I see are for 8 1/2 X 12.
Cheers
mdutton11 is offline
post #2 of 4 (permalink) Old 06-23-2019, 11:44 AM
Look at the drawings, understand what they are doing. Get a few pieces of poster board and make your own templates.
CraigS is offline
post #3 of 4 (permalink) Old 06-23-2019, 12:00 PM
Chepsk8's Avatar
There is an older Mod based on the MKII's, that addressed many of the shortcomings of the older cars. Not sure if they work on the 4's
Chepsk8 is online now
post #4 of 4 (permalink) Old 06-25-2019, 08:50 PM
phileas_fogg's Avatar
I recommend you make some cardboard templates based on those dimensions & tape them into place on your car. When I did mine I found that a couple of dimensions required “adjustment” to the tune of 1/2” (on the outside wall & front panels if I recall correctly). You’ll also be able to better match the curve where the inside panel meets the 4” tube on the inside panel.
IMG_2116 by jhsitton, on Flickr
MK IV Roadster #8631
phileas_fogg is offline
