Question for you EFI experts - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 9 (permalink) Old 06-18-2019, 09:55 AM Thread Starter
I have a customer with a donor build cobra that (randomly) will not start after it warms up. After much research I diagnosed it as a bad ecu. I swapped in a known good one and the problem went away. Sent the old one out to be repaired, re-instlled and everything was good. Started it hot at least 20 times. Customer drives the car to NH and when stops for gas it will not restart. Heres a clue. The only way to get it to restart hot is to trip the impact switch to shut off the fuel pump. Found this out by accident. I can duplicate this over and over. Why does shutting off the pump allow it to start?
Is it possible something in the ECU is still bad?
Thanks Mike
Michael Everson is offline
post #2 of 9 (permalink) Old 06-18-2019, 11:38 AM
beeman's Avatar
So when you trip the inertia fuel switch, does the fuel pump run or does the car start then die as the remaining fuel in the line is consumed?
The inertia switch is independent of the ecu and they are unaware of each other. If the pump runs even with the switch tripped, there's probably a short in the switch and I'd replace it.
If the car starts then dies only after the pump is off, I'd guess a fuel pressure issue. You'd be able to replicate that by pulling the fuel pump fuse/relay.
MK3.1 2004 Mach 1 donor. PS, PB, ABS, TC.
GTM #304 525hp LPE LS3
2000 C5 Coupe 489HP LPE LS1
beeman is offline
post #3 of 9 (permalink) Old 06-18-2019, 11:41 AM
Dennis C's Avatar
Can you re-start when hot by un-hooking the battery or do you have the re-set the crash switch? If you have to re-set the crash switch it may be bad.
Dennis
FFR 6165 Delivered June 10, 2007
kentuckycobraclub.com
Dennis C is offline
post #4 of 9 (permalink) Old 06-18-2019, 01:06 PM Thread Starter
I don't think its crash switch related. My thought was it was flooding and causing it not to start. When I trip the switch it starts and runs for a second or two. It takes 2 people to restart it once this happens.
Trip the switch, one person cranks it and the other to re-energize the switch. Funs perfect after that. I was able to repeat this over and over with the same results. Very strange. This is a basic stock EFI setup. Pump runs for a couple of seconds when you turn the key on. I can hear the pump operating properly even when it doesn't start.
post #5 of 9 (permalink) Old 06-18-2019, 02:23 PM
weendoggy's Avatar
Well, I'm going to ask what fuel pressure you see when this happens. If you're seeing full pressure (at least 40psi) I wouldn't be suspecting the fuel system. Are you getting spark when this happens? A lot of simple things you may have covered but not sure from the post.
weendoggy is offline
post #6 of 9 (permalink) Old 06-18-2019, 03:27 PM
If you think it is a flooding condition, most efi systems shut off the fuel injector pulse, if you open the throttle all the way while cranking.
railroad is offline
post #7 of 9 (permalink) Old 06-18-2019, 03:39 PM
HighTech Redneck
kgkeys's Avatar
I had a similar problem on my '03 silverado when the fuel pressure regulator diaphragm failed. It was pulling fuel through the vacuum line and would not hot restart. Had to let it sit until the gasoline evaporated and then it would restart. Luckily, I figured it out pretty quick and gave it an oil change, as well...
-Kyle
Donor Purchased: 1-7-2012 Donor scrapped: 5-12-2012
Kit ordered: 11-26-2012 (Black Fri.) Kit Delivery: 5-9-2013
First start: 4-2-2016 Registered: 12-20-2016
Details: 302, AOD, FFR lower arms, Fox spindles and brakes front,
Pin-drive width IRS, Mk VIII brakes rear, '84 manual Jeep MC.
kgkeys is offline
post #8 of 9 (permalink) Old 06-18-2019, 04:44 PM
It just dawned on me I have the same problem with an old model of the Holley Projection TBI.
It is injector leak down. To confirm this is the issue, bleed down the fuel rail on the warm engine. I use the schrader valve. Putting a rag around it and bleed the pressure off. Your symptoms sure sound like the issue I have.
railroad is offline
post #9 of 9 (permalink) Old 06-18-2019, 07:21 PM
Official OLD GUY
Big Blocker's Avatar
Fuel Pressure
By-pass the inertia switch completely and see if it still does this no start when hot issue . . . no effect, not the inertia switch.
The EEC does know that the pump is there (by relay coil resistance), or at least that it is energizing the relay for it . The pump won't [continue to] run unless the dizzy is spinning.
I'm leaning toward the injectors leaking down and flooding the engine.
Doc
little block, BIG BLOCK . . .
HUMMMMMMM?
Big Blocker is offline
