Has anyone fabricated/purchased/used a transmission fluid cooler - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 13 (permalink) Old 05-28-2019, 03:36 PM Thread Starter
Chepsk8's Avatar
Thinking about using a transmission fluid cooler (ATF). I have a T-5Z which has been great, change the fluid the start of every season, but looking at extra insurance.
Has anyone done this, what did they use, how did they install?
Chepsk8 is offline
post #2 of 13 (permalink) Old 05-28-2019, 04:11 PM
What would you use for a pump? I did a diff cooler on a racecar once following instructions from someone I trusted. Aimed the return so it flowed right onto the ring gear as near the pinion as possible. I wonder where you would want the return to flow to given the trans has so many more gears.
CraigS is offline
post #3 of 13 (permalink) Old 05-28-2019, 05:26 PM Thread Starter
Chepsk8's Avatar
Would use the bottom plug as the suction, side as the return
Chepsk8 is offline
post #4 of 13 (permalink) Old 05-28-2019, 05:50 PM
BEAR-AvHISTORY's Avatar
Agree on using the existing threaded openings. My thought was where would you locate the pump & heat exchanger?
Kevin
Raleigh, NC. MK-IV 8243 Coyote (2014)/TKO-600
Delivered - 2/7/14
Go Cart - 11/22/14
Body Painted - 1/8/15
Body on Chassis - 1/28/15
Dyno Tune - 2/19/15
Trailer home - 3/7/15
BEAR-AvHISTORY is offline
post #5 of 13 (permalink) Old 05-28-2019, 06:45 PM
Never knew they existed so I looked them up. Found this link which is pretty informative. The video at the bottom of the page gives some scale to the size of the pump (couldnt find dimensions listed anywhere). Looks do-able mounted in the tunnel somewhere as its a pretty compact pump. Also has a filter to keep the garbage from recirculating:
https://www.driftmotion.com/Driftmot...t-p/dm3561.htm
Keysergogo is offline
post #6 of 13 (permalink) Old 05-28-2019, 09:13 PM
Ford offered trans and rear gear coolers on their 13/14 Shelby GT500s.
They also said, not needed unless you plan on tracking the car.
railroad is online now
post #7 of 13 (permalink) Old 05-28-2019, 11:37 PM
There ya go. Probably pricey buying from Ford but could provide good info on how to go about it on a similar trans.
CraigS is offline
post #8 of 13 (permalink) Old 05-31-2019, 07:09 PM
I'm planning for the option of a diff cooler, but will check temps on the diff and trans, TKO-600. But have never seen the need for a trans cooler and don't know anyone running one, doesn't mean that there wouldn't be a benefit.
Just as a suggestion, it wouldn't be that hard to buy a gauge and install it in the drain plug hole, an adapter may be required. Then you could evaluate the temps during your hard use times.
I doubt that street use or even HPDE will get the temps to the point of real concern. Now racing, well, that's a different story. There are videos of John George running the new Coupe; he was showing IRS temps of 350+ in the 2015 Mustang IRS. Not sure if that was with or without a diff cooler. He did show a diff cooler in some of his build notes.
Jim1855 is online now
post #9 of 13 (permalink) Old 06-14-2019, 12:13 AM
This is what I used for trans and real coolers:
Tilton Pump
Bart Carter
FFR 4001
Bart Carter is offline
post #10 of 13 (permalink) Old 06-14-2019, 04:05 AM
Tilton Pump
I used one of these pumps for engine oil. I had a pick up on the side of the pan that went to the cooler, then the pump, and then back to the pan. During track use, I never saw a pan temp greater than about 200* or so.
The failure rate was pretty high. And when they fail, they leak. When I contacted Tilton about the failure, they told me it was not designed for hot oil.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
HPDE Instructor
Bob Cowan is offline
post #11 of 13 (permalink) Old 06-15-2019, 12:25 AM
FFCobra Captain
Dan Babb's Avatar
If you're not running power steering, how about using a power steering pump and a cooler. It would handle the RPMs and probably be ok with the fluid temps and you wouldn't have to rig brackets or mounting locations.
FFR5857
PS/PB/AC
Dan Babb is offline
post #12 of 13 (permalink) Old 07-15-2019, 11:29 AM
Banned
What problem you are facing? I am running this, I bought it from Reecoupons, and its quite working well, well tell me about your one.
saraluck9090 is offline
post #13 of 13 (permalink) Old 07-15-2019, 04:15 PM
I have two transmission coolers from Ford 7.3 trucks. Were removed and replaced with much larger coolers. They would be perfect for tranny or rear end coolers. They have brackets attached that could be bent to bolt to whatever needed. Large enough maybe wouldn't need a fan.
I'll send them to your door for $75 in conus. PM me if you are interested or want pics and send your email.
vector1 is offline
