Lock washers to mount transmission? - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 5 (permalink) Old 05-19-2019, 02:58 AM Thread Starter
silver_pilate's Avatar
I got the transmission (TKO600) mated up today. Flat or lock washers were not included with the bolts, so my question is what is needed to mount the transmission to the bellhousing? Flat washer, lock washer, locktite, or a combination? I feel like flat washers and blue locktite is a minimum, but I'll need to pick some up if I need lock washers. Just have the bolts in right now until I figure this one out.
MKIV Complete Kit(order placed: 4/5/16; order completion: 5/14/16; delivered: 5/24/16): 3-link, PC, cutouts, vintage gauges, glove-box dash, chrome roll bars; 17" wheels, B/T leather seats, wind wings/visors sourced during separate 50/50 sale; side pipes and headers sourced through Gan-n
First start: 6/22/19
Drive train: Levy 408w w/carb, TKO600, Moser 8.8 with 3.55s and GT rear brakes
Paint Plan: Under consideration (probably dark grey/titanium with silver stripes)
silver_pilate is online now
post #2 of 5 (permalink) Old 05-19-2019, 11:24 AM
Mine has lock washers and no blue.
CraigS is offline
post #3 of 5 (permalink) Old 05-19-2019, 02:19 PM
Locks and proper torque.
JKleiner is online now
post #4 of 5 (permalink) Old 05-19-2019, 05:36 PM Thread Starter
Thanks, guys. Picked up the split lock washers just now.
post #5 of 5 (permalink) Old 05-20-2019, 04:03 AM
Split lock washers only work after the bolt starts to come loose, and there's enough space for the washer to split apart. Because the transmission "ears" are aluminum, you want to spread out the clamping force as much as possible.
Personally, I use a large heavy steel flat washer, and enough torque to keep it tight. I do not use any kind of lock washers, or thread lockers. Because there is a dowel pin, those bolts are not prone to coming loose. I have never had one come loose during use. Never.
Also, because there is a dowel pin, you can use a grade 8 if you want to. There really isn't any need for it, but you can if you want to.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
HPDE Instructor
Bob Cowan is offline
Similar Threads
FIA interference with Breeze lower radiator mount EZ$ Factory Five Roadsters 3 03-16-2019 09:53 PM
S10 transmission mount question EZ$ Factory Five Roadsters 11 03-01-2019 12:40 AM
T56 Transmission Mount dhuff Factory Five Roadsters 12 01-12-2019 09:45 PM
More Ford Racing Crate Engine Adventures - Possible Failed Rear Main Seal CDXXVII Factory Five Roadsters 15 12-29-2018 04:43 PM
Motor Mount Torque Question Shoeless Factory Five GTM Forum 2 09-03-2018 10:47 PM
