upholstering rear bulkhead question - FFCars.com : Factory Five Racing Discussion Forum
 2Thanks
  • 1 Post By phileas_fogg
  • 1 Post By donkeykong
post #1 of 13 (permalink) Old 05-16-2019, 04:49 AM Thread Starter
As I'm redoing the carpeting in my car I decided to do the rear bulkhead behind the seats in leather. Has anybody accomplished this in one piece? It's looking super nice right to the beginning of the transmission tunnel...now I'm stuck! I can't make the curves down to the floor, so I'm thinking there's maybe a trick to this OR it's not going to happen and I need a seam somewhere. If a seam is the million dollar answer...Where is the best spot to put it?
Appreciate the help guys.
donkeykong is offline
post #2 of 13 (permalink) Old 05-17-2019, 03:35 AM
Google Tennessee Tim, he did a leather or vinyl bulkhead. His build may give you some ideas. His website detailed his build.
FFR7995
MK IV
Prestige Motorsports 347 SBF, Moser 8.8 (3.31), 3 link, TKO 600,hydraulic clutch, PS, Heat/AC, 17" Halibrands, Nitto 555s,
Bobby Doug is offline
post #3 of 13 (permalink) Old 05-17-2019, 11:00 AM
2yrproject's Avatar
I did it on my MK 3 and it was a pain. I had to enlist the help of my wife and we spent half a day attempting to get the diamond stitched leather to match up and fit around the curves. We used a 3M adhesive to attach the leather to the aluminum and cut out sections of the leather to reduce bunching due to bends in the aluminum. In retrospect, if doing it again, I would take it to an upholstery shop and have the experts fiddle with it for hours. What a PIA.
Build School 10/08
MK3 Kit Ordered 08/05/08 ; Delivered 09/26/08
First Start 10/05/10 ; First Drive 08/31/11, License Plates 10/05/11
Picked up from the Batcave 10/19/13
Levy Stage 4 (347) & Levy T5 /Mass-flo EFI / Wilwood Brakes / Paint by J. Miller (Lexus Indigo Ink) / Custom hood louvers with aluminum plating by Metal-Morphous / Engine turned dash bezels.
"You can't build a reputation on what you're going to do." -- Henry Ford
2yrproject is offline
post #4 of 13 (permalink) Old 05-17-2019, 12:24 PM
phileas_fogg's Avatar
From the build threads I bookmarked: 14 Jan 13 update: Home and Post #82: https://www.ffcars.com/forums/17-fac...-thread-2.html
Cheers,
WIS89 thanked this.
MK IV Roadster #8631
phileas_fogg is offline
post #5 of 13 (permalink) Old 05-17-2019, 07:31 PM Thread Starter
Thanks for the info, it was half leather/vinyl half carpet. There was a good picture of where he made his seam, so that was at least helpful to reinforce how I had it visualized.
post #6 of 13 (permalink) Old 05-17-2019, 07:33 PM Thread Starter
That's the problem, the bunching! I think if I made a seam I should be able to get the second half without an issue...I hope.
post #7 of 13 (permalink) Old 05-17-2019, 07:35 PM
narve00's Avatar
Around the transmission tunnel will need some creativity. Use paper and play around with different cutting and wrapping.
Throw the seats in and look at what’s visible, a lot of sin disappears behind the seats if they are like mine and jammed tight to the bulkhead.
narve00 is offline
post #8 of 13 (permalink) Old 05-17-2019, 07:38 PM Thread Starter
Cheers,
I came across the thread last night, However, thank you so much for taking the time to look that up and link it here for me...I do appreciate that.
post #9 of 13 (permalink) Old 05-17-2019, 07:39 PM Thread Starter
YES!!! That's my saving grace at this point.
post #10 of 13 (permalink) Old 05-17-2019, 08:27 PM
No worries mate; just glad to help.
post #11 of 13 (permalink) Old 05-20-2019, 04:56 PM
egchewy's Avatar
looking at Tim's build, do you guys believe he got the diamond stitching pattern just by using spray adhesive and pushing the leather into the recesses he cut out in the foam? Looks stitched from far away.
#9503 MK4 complete kit
1966 289 SBF HiPo bored 30 over
Tremec T5Z
8.8" Moser rear end w/ 3.55 gear ratio
manual steering
RT drop trunk
Breeze front battery box
egchewy is online now
post #12 of 13 (permalink) Old 05-22-2019, 07:31 PM Thread Starter
I would say no. I have diamond patterns in my trans tunnel and seats...there's no way adhesive would hold for the long run in that many creases.
egchewy thanked this.
post #13 of 13 (permalink) Old 05-22-2019, 08:09 PM
Brastic's Avatar
My rule of thumb is to have leather where you touch and vinyl everywhere else. Besides the cost difference, the modern vinyls look and almost feel like leather. The big deal is that vinyl comes in large sheets that are much easier to work with and the maintenance of vinyl is almost none. I have to treat leather at lease yearly to keep it up. I would not like to remove the seats to treat leather back there. YMMY.
Brastic is online now
Similar Threads
Where to get rear sway bar Robert D Factory Five Roadsters 6 02-19-2019 06:33 PM
Rear Bulkhead Mod. HinoonAZ Factory Five Roadsters 9 01-20-2019 03:17 AM
More Ford Racing Crate Engine Adventures - Possible Failed Rear Main Seal CDXXVII Factory Five Roadsters 15 12-29-2018 04:43 PM
Half Butt Drop - Body Position on Rear Frame Lou N Factory Five Roadsters 3 10-25-2018 09:44 PM
rear suspension question jasont Factory Five Roadsters 15 09-17-2018 05:24 PM
