Squeaks and chirps - need your help. - FFCars.com : Factory Five Racing Discussion Forum
 8Thanks
  • 1 Post By edwardb
  • 1 Post By CRZN 427
  • 1 Post By JKleiner
  • 1 Post By noclot
  • 1 Post By Keysergogo
  • 2 Post By CraigS
  • 1 Post By caesarmascetti
post #1 of 13 (permalink) Old 05-09-2019, 03:16 PM Thread Starter
FFCobra Website Stalker
Atlantacobra's Avatar
Hey guys. Would love your input. My 13 year old build has developed some squeaks and chirping while driving. I'm sure after this long some things have worn and/or loosened, so trying to figure out the obvious culprits first. Sounds like it's mostly coming from the suspension as I hit dips in the road and such. I bought the car already complete.
What are your experiences on what I should look for first? Coil overs on all four corners and solid rear axle.
Any thoughts would be helpful. Thanks guys.
-Greg G.
65 MKIII
4.6L T-5 trans
Atlantacobra is offline
post #2 of 13 (permalink) Old 05-09-2019, 03:43 PM
Obvious first place would be to make sure it's lubed properly. Control arms, tie rod ends, ball joints, etc. with special attention to the pivots on the front upper control arms. You don't mention mileage, but after that amount of time, some of the items listed may be due for replacement.
Atlantacobra thanked this.
edwardb is online now
post #3 of 13 (permalink) Old 05-09-2019, 03:47 PM
CRZN 427's Avatar
Thoughts...
Check the front coil-overs at the top. There were some issues with the upper end being able to contact the A-arm if the spacers were slightly off, or worn.
Make sure the flexible brake lines aren't contacting any suspension components, and that the hard lines are still securely fastened.
Check the aluminum panels (the "F" panels) in the area for loosened rivets that might lead to movement in the panel.
Check the tie rods to insure they aren't worn or rubbing on any of the wiring harness (I had something like that with my donor harness).
Check the ball joints for lubrication and wear.
Check the horns, or other accessories, attached to the front of the chassis for loose connections.
Check the aluminum closure panels at the radiator for tightness and fit.
That is all I can bring to mind. I'm sure there will be other suggestions coming.
Regards, Rick.
CRZN 427 is offline
post #4 of 13 (permalink) Old 05-09-2019, 04:40 PM
Paul already mentioned my first suspicion---upper control arm pivots. The ones used in cars of your vintage with the aluminum pivots have a reputation for not accepting lube and galling which can ultimately lead to them seizing. I had a car brought to me a few years ago with the same complaint as yours and that was the problem. Raise the car, take off the wheels and then one at a time remove the bolt that attaches the link to the pivot and check to see if the pivots rotate freely on the cross shaft.
Good luck,
JKleiner is online now
post #5 of 13 (permalink) Old 05-10-2019, 03:28 AM
I had a loud, annoying rattle that started at 30mph and ended at 40mph. I just could not find it!. Finally, I bought a mechanics stethoscope at HF tools, and added a long extension tubing. I moved the end of the tube around the engine compartment making many trips until I located the source. I must have looked ridiculous driving with a stethoscope.. Anyway, I ultimately located it as a loose piece of aluminum shroud above the radiator on the front side. It was then an easy fix.
noclot is offline
post #6 of 13 (permalink) Old 05-10-2019, 01:47 PM Thread Starter
Excellent suggestions guys. Thank you! Will be checking these items out this weekend.
65 MKIII
4.6L T-5 trans
post #7 of 13 (permalink) Old 05-10-2019, 05:26 PM
I had the squeaking too, I completely took apart my Gold UCAs. Even though I lubed them every year, they were almost bone dry inside. Cleaned, sanded, lubed. Solved the problem.
_
_
NiceGuyEddie is offline
post #8 of 13 (permalink) Old 05-11-2019, 01:18 PM
I had an annoying chirping from the rear when I’d hit bumps while driving. I took the shocks and control arms off cleaned lubed etc, but it was still there. Drove me insane. Finally found it by accident by bumping into the fuel tank with my elbow while jacking the car up this winter - the top edge of the plastic fuel tank “cover” was squeaking against the fuel tank on the drivers side rear corner.
Keysergogo is offline
post #9 of 13 (permalink) Old 05-11-2019, 09:44 PM
Another squeak I found was the windshield post not having quite enough (none) clearance to the fiberglass body.
For anyone whose steel on steel UCAs are badly worn here are the parts needed to update to the newer better stuff.
Go here and scroll to pg 152.
https://www.spcalignment.com/images/...t_2018-web.pdf
You want;
2-cross shafts #93400
4-pivots #92025
I order them from Summit. These are the current greasable delrin insert pivots. They have very nice channels in them so when you grease them you see 6 little grease worms coming out of both sides of the pivot. Really nice to know that the grease is actually going where it needs to go.
WIS89 and Atlantacobra thanked this.
CraigS is offline
post #10 of 13 (permalink) Old 05-12-2019, 11:39 AM
I had this exact same issue, and found it the same way LOL
caesarmascetti is offline
post #11 of 13 (permalink) Old 05-19-2019, 04:55 PM
ratsey's Avatar
Oooh! Now I'm going to have to check mine ... I've an annoying sound that I get on some bumps and I feel like I've checked everything - except that!
I also get a heavy thud off my IRS pumpkin when it 're-engages' with the T5z after lifting off which is annoying.
J.
FFR6243RD, MkIII, 3.55, IRS, pin-drive width, carb'd 351W, T5, 1/2 dropped butt, Fortes hydraulic clutch, deep dish AC-III wheels by Team III. 9 year build; NY registered 7/18/2016 - "Sweet 16" winner at 2016 Taconic State Nationals 5 days later ... $54 PlastiDip paint job for the foreseeable future!
- Leave me a comment!
Register your Factory Five on the Factory Five Cars Rule! mobile app - download from the app store
ratsey is offline
post #12 of 13 (permalink) Old 05-20-2019, 09:28 PM
My car is in go-cart stage. At around 400 miles i started to get a ‘chirping’ sound. Turned out it was the plastic cover against the fuel tank at the driver side rear corner, just as others stated.
vspeeds is online now
post #13 of 13 (permalink) Old 05-20-2019, 10:05 PM
I swear I thought it was my shocks or coils or something making that sound, but that darn cover was the culprit! I half-a$$ed my repair for that - just squeezed a folded up grommit between the plastic and the tank as a temporary fix to see if it stopped the chirpping... temp turned into permanent and the chirp is still gone! I’ll have to get in there and truly address it one day, but for now I’m enjoying the chirpleass-drive
