Rear License plate Mounting?? - FFCars.com : Factory Five Racing Discussion Forum
 2Thanks
  • 1 Post By steno
  • 1 Post By Boat737
post #1 of 14 (permalink) Old 04-22-2019, 01:10 PM Thread Starter
WBILB's Avatar
Just attempted to mount the rear plate on my MK4 and lo and behold the vertical space between the bottom of the plate light and the top of trunk latch handle is about an inch too close for the plate to fit??? I don't see an easy solution using these parts. Any thoughts?
FFR MK4 F5R1008617RD
FFR MK4 F5R10008617RD
2006 Aston Martin db9
2012 MV Agusta F4 1000R
WBILB is offline
post #2 of 14 (permalink) Old 04-22-2019, 01:39 PM
steno's Avatar
Here we go again! Search bar is your friend! Jeff Kleiner has the best fix! The trunk was splashed from an original... the tags in England were narrow and longer than ours.
WBILB thanked this.
steno is offline
post #3 of 14 (permalink) Old 04-22-2019, 02:00 PM
Well Used Member
Boat737's Avatar
I did the Kleiner license-plate-light mod (with added LED's), and built up the little pad on the trunk lid. Between raising the light fixture on the pad, and raising the plate into the light fixture, I didn't have to cut the plate at all.
See post #22 of my graduation thread. https://thefactoryfiveforum.com/show...d-Circumstance
I think Jeff's mod is here. https://thefactoryfiveforum.com/show...nd-Plate-Mount
Some people cut the plate. Either at the top into the fixture, or at the bottom around the handle.
WBILB thanked this.
If Brute Force doesn't work, you're not using enough of it.
Basic Stuff: MK4 Complete Kit #8439, Wilwood's, 17" Halibrands,
Extra Stuff: SS Brake/Fuel Lines, Breeze cooling, battery mount, SS Roll Bar,
Old Fart Stuff: Heater, Seat Heaters, Footbox Fresh Air, Stereo, Keyless ignition, Power Steering, Hyd Clutch
Young & Dumb Stuff: 427w Dart, TKO600, 3 link Moser M9/Ford 9", 3.5:1, Eaton TruTrac Posi
Boat737 is offline
post #4 of 14 (permalink) Old 04-22-2019, 02:09 PM
Not correct. There was enough room on the original trunk mount for a US plate. No modification to the mount or plate was required.
Bob P is offline
post #5 of 14 (permalink) Old 04-22-2019, 03:35 PM Thread Starter
WBILB's Avatar
Bob, BOAT373 pointed me in the right direction to Jeff Kleiner's excellent modification...... Just FYI the MK1-3 cars will accommodate a standard 12x6 plate, however the MK4 lids were made a little more closely to originals and will NOT accommodate a standard US plate.
WBILB is offline
post #6 of 14 (permalink) Old 04-22-2019, 06:20 PM
When I said original, I meant the real original Shelby/AC-built cars - which would fit a normal US plate.
Bob P is offline
post #7 of 14 (permalink) Old 04-23-2019, 09:44 PM
Laser Stan's Avatar
Steal Some Space from Two Places
Round out a clearance at the bottom-middle of the plate, and make a slot in the bottom of the plastic light bulb cover. Works fine.
Mk4 complete kit, December 2010; Ford Racing 347; 365 RWHP; Holley 670 Street Avenger; Classic Chambered Mufflers; TKO 600; Moser 3:31: Nitto NT555 G2, 315-35-17 rears 245-45-17 fronts; grab bar; Dynamat; Duplicolor Bed Armor; Ford Royal Blue Pearl & Arctic White stripes by Celina Custom Auto; Corbeau Classic II seats.
Laser Stan is offline
post #8 of 14 (permalink) Old 04-23-2019, 11:25 PM
Or notch both the top and bottom of the tag. Yeah, I know it may be illegal technically, but I've been driving w/o a front tag for 14 yrs and that is technically illegal too.
CraigS is offline
post #9 of 14 (permalink) Old 04-24-2019, 12:20 PM
MCathcart's Avatar
Cool
Yes, you should already know... I'm in Left Field.
Screw that junk. Get a "used" Ford trunk release and scrap the handle. I used the Ford trunk latch and a two channel remote and no Problem! (The manual trunk release will fit in the FFR trunk latch hole that ends up behind the tag. If something happens, dead battery, trunk release button takes a dump or lost remote, just remove the license plate and turn the release with a screwdriver.)
To complicate the "key" thingie more, I don't have any period. I'm using an RF ID start system and a button.
This is one of those "little" problems that FFR has just let go.
MCathcart is offline
post #10 of 14 (permalink) Old 04-24-2019, 01:44 PM
Dave M's Avatar
If you look at the back end of an original cobra such as Dick Smiths 198 the light seems to be mounted higher giving more than enough room for the plate. It almost looks like the rear face of the trunk lid is taller??
Dave M is offline
post #11 of 14 (permalink) Old 04-24-2019, 02:42 PM
Man Cave Master Craftsman
Blown 5.0's Avatar
Same mod as MCathcart, it's a little more effort but well worth it. Now I can pop the trunk open with a push of the under dash trunk release button or the alarm's remote trunk release button. I also used the manual trunk release as the emergency release, just remove the license plate and turn with a screwdriver. Definitely like the cleaner no handle look of the trunk too.
Editor's Choice
Go Cart
Best In Show Roadster & Best Paint
HP & Torque
Supercharged Coyote|Traction/Launch Control|PS|PB|ABS|IRS|3.73|TKO 600|Roush|Ford Racing|AEM|VMP|NRG|Speedhut|Ididit|Casey Design|Boyd|Spec|Quicktime|Eaton|Moroso|Mcleod|DSS |Unisteer|Aeromotive|Metco|StainlessHeader|Bowler| Spal|Wilwood|Earl's|Summit Lokar|Forte's|Thompson's|Everson's|Breeze|
Blown 5.0 is offline
post #12 of 14 (permalink) Old 04-24-2019, 07:58 PM
Danner's Avatar
Send a message via AIM to Danner
I cut my plate, and I'll do it again. Police and RMV don't seem to care, and it's the lowest effort of any solution I've seen. I just used a drill, a hacksaw, and a file.
Danner is offline
post #13 of 14 (permalink) Old 04-24-2019, 11:21 PM
BEAR-AvHISTORY's Avatar
Notched mine at the top, wanted the year to show. No NCDMV or LEO issues.
Kevin
Raleigh, NC. MK-IV 8243 Coyote (2014)/TKO-600
Delivered - 2/7/14
Go Cart - 11/22/14
Body Painted - 1/8/15
Body on Chassis - 1/28/15
Dyno Tune - 2/19/15
Trailer home - 3/7/15
BEAR-AvHISTORY is offline
post #14 of 14 (permalink) Old 04-24-2019, 11:34 PM
John4337's Avatar
Do the Kleiner mod. Super easy and works great
FFR #7388 - Mk 4 Complete Kit w/ IRS, Ordered 10/21/10, Completion Date 11/13/10, Delivered 12/8/10, Drivetrain in 8/21/11, Graduated 6/10/13
John4337 is offline
Similar Threads
Roll bar headrest? Blown 5.0 Factory Five Roadsters 9 12-22-2018 10:08 PM
For Sale: 2013 BOSS 302 - 832 rear wheel horsepower fully built Mark Gearhart Other Vehicles For Sale / Wanted 2 12-15-2018 06:09 PM
Phileas_Fogg's MK 4 Roadster Build phileas_fogg Factory Five Roadsters 476 12-05-2018 02:13 AM
Half Butt Drop - Body Position on Rear Frame Lou N Factory Five Roadsters 3 10-25-2018 09:44 PM
rear suspension question jasont Factory Five Roadsters 15 09-17-2018 05:24 PM
