painting 8.8 rear end - FFCars.com : Factory Five Racing Discussion Forum
 2Thanks
  • 1 Post By Danner
  • 1 Post By DadofThree
post #1 of 12 (permalink) Old 04-22-2019, 02:09 AM Thread Starter
egchewy's Avatar
getting my Moser from Mike Forte this week. I've ordered some KBS (heard it was the new and improved POR 15 from Mike) and was wondering if anyone had suggestions on what to paint and what not to paint on the rear end/hubs.
thanks in advance.
#9503 MK4 complete kit
1966 289 SBF HiPo bored 30 over
Tremec T5Z
8.8" Moser rear end w/ 3.55 gear ratio
manual steering
RT drop trunk
Breeze front battery box
egchewy is online now
post #2 of 12 (permalink) Old 04-22-2019, 03:43 AM
I recently picked up my axle from Forte and the finish was a little duller than what I'd like; i am not certain it would require a new coat of POR-15, unless you are just looking for an additional protective coating. I was debating on whether or not to replace the cover vs. painting it.
Eager to hear what others have to say.
flip1216 is offline
post #3 of 12 (permalink) Old 04-22-2019, 01:34 PM
Dave M's Avatar
I guess the main thing to caution against is to not paint any mounting surfaces like axle and drive shaft yoke flanges. Maybe the inner areas of tabs where the control arms mount just to make it easier to get them slid in.
Dave M is online now
post #4 of 12 (permalink) Old 04-22-2019, 03:21 PM Thread Starter
egchewy's Avatar
my impression after talking to mike was that the axle was bare metal and would need to be painted.
Tremec T5Z
manual steering
RT drop trunk
post #5 of 12 (permalink) Old 04-22-2019, 03:47 PM
Danner's Avatar
Send a message via AIM to Danner
thanks in advance.
I'm not sure if this helps, but this is Rustoleum aluminum paint, I thought it came out pretty well. YOu can see all the stuff I taped off.
egchewy thanked this.
Danner is offline
post #6 of 12 (permalink) Old 04-22-2019, 05:44 PM
DadofThree's Avatar
POR-15 is what I used on my 8.8.
IMG_2118 - Copy by D. R., on Flickr
IMG_2357 by D. R., on Flickr
Dave
My photos are at:
Videos are at:
Loving the Island Life
DadofThree is online now
post #7 of 12 (permalink) Old 04-22-2019, 07:35 PM
Avalanche325's Avatar
I used good old Rustolium. I did a primer and then top coat. It has held up great. Front sway bar that gets sandblasted....not good at all. I might try POR for that.
MKIV Roadster....FFR7694
Avalanche325 is offline
post #8 of 12 (permalink) Old 04-23-2019, 12:24 AM
DWIGHT's Avatar
Smile
the part of the axle that is inside the housing will be in oil. Or bathed in oil.
The axle flanges outside can be paint but don't have to. Ford did not paint them.
1966 Ford Fairlane GT 2 door hardtop with 390 5 speed.
DWIGHT is online now
post #9 of 12 (permalink) Old 04-23-2019, 12:37 AM
My axle is definitely not bare metal. It looks like something you'd get OEM. Not glossy, but it does have a coating. I will figure out how to upload pics later to give you a better idea.
flip1216 is offline
post #10 of 12 (permalink) Old 04-23-2019, 08:43 PM
Type 65 Coupe in progress
mcmustang's Avatar
I used a wire brush, the recommended prep solution, and then brush painted mine with POR-15. Be sure to wear a respirator when using the POR-15. The vapors are toxic and liver damage is cumulative.
https://pbase.com/snakeriverscca/image/98408982
https://pbase.com/snakeriverscca/image/98408993
You should have YOUR head examined.
mcmustang is offline
post #11 of 12 (permalink) Old 04-24-2019, 11:07 AM
beeman's Avatar
I used por-15 as well, but my rear end was used and had some surface rust. I think if I had a new rear end I would go with an aerosol spray. Depends if you want more of a painted look (aerosol) or more of a glossy powdercoat look (por-15).
MK3.1 2004 Mach 1 donor. PS, PB, ABS, TC.
GTM #304 525hp LPE LS3
2000 C5 Coupe 489HP LPE LS1
beeman is offline
post #12 of 12 (permalink) Old 04-25-2019, 01:01 AM
Gofastoldguy's Avatar
Rear end vent tube install
I notice my 8.8 does not have a vent...what is the proper location and correct procedure to install w/o adding metal shavings to the rear end?
Sorry, didn't mean to high jack the thread, just noticed a vent on one pic.
Gofastoldguy is offline
Similar Threads
Not much accomplished Rear end inquiry? jhargrove Factory Five Roadsters 5 03-25-2019 01:08 PM
rear end rebuild egchewy Factory Five Roadsters 13 02-14-2019 12:55 AM
Wanted to Buy: 8.8 rear end egchewy Parts For Sale / Wanted 3 02-13-2019 03:18 PM
Bolt In QC Rear End KGB911 Factory Five '33 Hot Rod Forum Sponsored by E/T Wheels 0 10-17-2018 04:29 PM
Need help with my rear end Bilwil Factory Five Roadsters 2 09-18-2018 08:16 PM
