Heater hose connection to water pump - FFCars.com : Factory Five Racing Discussion Forum
 1Thanks
  • 1 Post By MARIAH
post #1 of 9 (permalink) Old 04-15-2019, 01:24 AM Thread Starter
EZ$
Trying to get all my plumbing taken care of before I start the wiring. I ran into a problem hooking up the heater hose to the water pump fitting. The problem is that it comes directly into the alternator, about 3 inches away. the hose will not make that tight a bend without kinking. Is there some way to make this bend that I'm not aware of? Last heater hose connection to make, and I'm snookered.
Rick
MK4 w/ Mr. Bruce FIA body, Levy 331 w/ Speedmaster Stack Injection, IRS, ABS, PS, PB, FAST FI
EZ$ is offline
post #2 of 9 (permalink) Old 04-15-2019, 03:37 AM
Mustang Man's Avatar
You need a molded elbow. Don't get bulk 5/8 heater hose. Look for heater hose with a molded elbow/90-degree end on it...
https://www.summitracing.com/parts/vta-099003
HTH...
FFR5310RD
Mustang Man is offline
post #3 of 9 (permalink) Old 04-15-2019, 04:14 AM Thread Starter
EZ$
Damn, that stuff's not cheap! I wish I had spotted this sooner, and not after I purchased bulk. With the mistakes I keep making, this could be the most expensive, and longest build ever! Thanks for the info Mark.
Rick
EZ$ is offline
post #4 of 9 (permalink) Old 04-15-2019, 11:36 AM
Chepsk8's Avatar
Should be able to find a plastic 90 degree elbow. Just make sure it is not cheap stuff.
Chepsk8 is online now
post #5 of 9 (permalink) Old 04-15-2019, 12:03 PM
MARIAH's Avatar
Just last week I discovered a plastic hose connector was leaking and realized all that heater plumbing was 15 years old.
The Gates 28479 has the built in elbow, clears my Alternator and enough length (40") to reach the heater hose.
You can shorten the elbow to keep it tucked into the intake valley and away from the alternator.
Just needed the 5/8-3/4 connector to finish that effort.
I picked up everything at Oreiliy but others will have it.
$20 Elbow 5/8 & 3/4 ID ~5” long GATES 20662
$23 Waterpump to Heater 3/4 & 3/4 …40” GATES 28479
Bypass Hose .75 & .61” NAPA 7447
Connector 5/8-3/4 Dorman 47080
WIS89 thanked this.
MARIAH is online now
post #6 of 9 (permalink) Old 04-15-2019, 02:48 PM
Derald Rice's Avatar
When I had a heater, I used a trimmed down heater by-pass hose for the elbow. An adapter plus a length of bulk hose completed the line.
FFR 3319. On the road since 2002 with a lot of updates
Derald Rice is online now
post #7 of 9 (permalink) Old 04-15-2019, 04:39 PM Thread Starter
EZ$
Thanks for all the ideas guys. I'll check these out and see which will work best for me.
Rick
EZ$ is offline
post #8 of 9 (permalink) Old 04-15-2019, 11:31 PM
phileas_fogg's Avatar
In addition to a 3/4" to 5/8" 90* hose elbow (https://www.napaonline.com/en/p/NBG10071), I used one of these: https://www.napaonline.com/en/p/NBG9924
IMG_3461 by jhsitton, on Flickr
MK IV Roadster #8631
phileas_fogg is offline
post #9 of 9 (permalink) Old 04-16-2019, 03:07 AM Thread Starter
EZ$
Went to the auto parts today to see what was available. Ran across a counter guy who was really interested in helping. Not only did he find a 36" heater hose with a molded 90 degree bend at one end, he checked his computer, and could not find it in inventory. Long story short, he sold it to me for the price of 36" of regular heater hose. Less than $5 for a $30 part! Once in a while it's nice to get lucky. Should be able to finish this tomorrow and cross it off the list.
Rick
EZ$ is offline
Similar Threads
Ride of shame 2 "Almost" - Fuel pump hanger connection fail CDXXVII Factory Five Roadsters 4 04-16-2019 01:36 AM
Water Pump Recommendations? Bill_VA Factory Five Roadsters 20 04-10-2019 07:58 PM
Leaking Heater Hose Connection At Heater swwebb10 Factory Five Roadsters 5 03-05-2019 04:19 PM
Do I have the correct Water pump rotation? Francky77 Factory Five Roadsters 9 01-16-2019 12:35 AM
Heater Hose Routing - 302 Engine swwebb10 Factory Five Roadsters 9 12-12-2018 11:58 PM
