1994 mustang proportioning valve - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 10 (permalink) Old 04-13-2019, 01:18 PM Thread Starter
I am using front and rear stock disc brake setup from a 1994 mustang gt donor. I installed a 1994 Cobra master cylinder. Would the stock 1994 gt brake distribution block work fine?
strtrdnt is offline
post #2 of 10 (permalink) Old 04-13-2019, 02:07 PM
There is no need to use a proportioning valve, or distribution valve. Plumb the brakes directly to the MC.
rich grsc is online now
post #3 of 10 (permalink) Old 04-13-2019, 09:28 PM
canuck1's Avatar
I agree with Rich. There’s no benefit to using it and your brake line plumbing is cleaner, more simplified without it.
Sean
MK 3.5 (MK IV body retrofit to MK III chassis) 351W stroked & poked to 396 c.i., custom EFI, 4 into 4's, 3link, 3.73, 15" Halibrand replicas, SAI mod, full bumpers, 2 X roll bars, I˛ electronics, hydroboost, 5-lug, GT front, MK VIII/Cobra rear discs, Levy rear LCA's, Forte front bar, VPM rear bar, painted by SRP (again!)
canuck1 is offline
post #4 of 10 (permalink) Old 04-13-2019, 11:15 PM
It's original use in the Mustang was to make sure the rear brakes didn't lock first. When you move all the hardware from a front heavy Mustang to a rear heavy FFR, you need more rear brake rather than less. So ditch the valve.
CraigS is offline
post #5 of 10 (permalink) Old 04-14-2019, 10:57 AM Thread Starter
How will the balance of my brakes probably be without a proportioning valve considering my setup i described
strtrdnt is offline
post #6 of 10 (permalink) Old 04-14-2019, 11:17 AM
If you're like most roadsters running Mustang brakes you'll find that you could use more rear bias. Balance can be improved with more aggressive rear pads.
JKleiner is online now
post #7 of 10 (permalink) Old 04-14-2019, 01:15 PM
steno's Avatar
Ditch the valve and go with more aggressive pads on the rear.
steno is online now
post #8 of 10 (permalink) Old 04-14-2019, 10:50 PM Thread Starter
Sounds good all. Thanks for the advice!
strtrdnt is offline
post #9 of 10 (permalink) Old 04-14-2019, 11:53 PM Thread Starter
Jeff, what brakes do you use if I decided i would need more rear grip?
strtrdnt is offline
post #10 of 10 (permalink) Old 04-16-2019, 12:59 AM
duncalope's Avatar
Hawk has some that grab considerably better. More brake dust in the process though.
duncalope is offline
Similar Threads
Vintage Air Servo Heater Valve Mounting swwebb10 Factory Five Roadsters 10 02-23-2019 03:03 AM
Electric Fuel Shut-off Valve Rotorhead Factory Five '33 Hot Rod Forum Sponsored by E/T Wheels 4 02-03-2019 01:58 PM
For Sale: Tall Aluminum ball milled valve covers with gtaroger Parts For Sale / Wanted 0 12-22-2018 09:42 PM
For Sale: Brake Proportioning valve PaulProe Parts For Sale / Wanted 0 09-21-2018 01:29 AM
New Forte Parts Mike Forte Factory Five Roadsters 11 08-21-2018 06:54 PM
