FFR Ignition Switch - FFCars.com : Factory Five Racing Discussion Forum
post #1 of 8 (permalink) Old 01-29-2019, 04:03 AM Thread Starter
FFR Ignition Switch
Test fitting the MKIV FFR ignition switch on the vinyl dash, and it seems the dash is a bit thick for the switch. The locking ring has a large visible gap. How did you guys take care of this?
FFR MKIV Roadster#9375
Ordered 03-29-18
Delivered 07-6-18
First Start 02-28-19
FFR9375 is offline
post #2 of 8 (permalink) Old 01-29-2019, 10:32 AM
You could relieve the area on the back side of the dash. You might weaken it though. I would just leave it alone.
Michael Everson is offline
post #3 of 8 (permalink) Old 01-29-2019, 01:31 PM
Dave M's Avatar
I'm not familiar with that switch but is it as tight as you can get it? I know most of my dash items have a bit of a dimple around them where they've been tightened and compressed the vinyl and padding enough to not move when actuated. Thats not evident in your pic.
Dave M is online now
post #4 of 8 (permalink) Old 01-29-2019, 02:24 PM
Agree with Dave M. That piece can be a little tighter and probably more acceptable. Although likely the center still won't be flush with the locking ring due to the thickness. Unfortunately, that ring is hard to get a hold of. Here's what I do but only if you're comfortable and do it very carefully. I put several wraps around the ring with Gorilla tape. Then use a pair of tongue-and-groove pliers (e.g. Channellock) on a setting that grips around the ring as much as possible, get a solid grip that's enough to hold without slipping but not enough to do damage, then turn it more than I can do by hand. Works pretty well, but only do it once, e.g. during final assembly.
edwardb is online now
post #5 of 8 (permalink) Old 02-23-2019, 02:46 AM Thread Starter
Took a different route, S2000 push start button & digital guard dawg RFID system.
Ordered 03-29-18
Delivered 07-6-18
FFR9375 is offline
post #6 of 8 (permalink) Old 02-23-2019, 03:06 PM
Man Cave Master Craftsman
Blown 5.0's Avatar
I also went with the Digital Guard Dawn alarm and RFID system but went with the Lexus push start button, awesome system!
As a back up you may also want to consider installing the FFR ignition switch too, I installed mine under the dash where it's not visible but it's still accessible when doing diagnostic work or just in case of failure of the electronic push to start.
Editor's Choice
Go Cart
Best In Show Roadster & Best Paint
HP & Torque
Supercharged Coyote|Traction/Launch Control|PS|PB|ABS|IRS|3.73|TKO 600|Roush|Ford Racing|AEM|VMP|NRG|Speedhut|Ididit|Casey Design|Boyd|Spec|Quicktime|Eaton|Moroso|Mcleod|DSS |Unisteer|Aeromotive|Metco|StainlessHeader|Bowler| Spal|Wilwood|Earl's|Summit Lokar|Forte's|Thompson's|Everson's|Breeze|
Blown 5.0 is offline
post #7 of 8 (permalink) Old 06-17-2019, 09:45 PM
Radar Pete's Avatar
Also tightened up the ring with pliers after protecting the dash. Had to install a large diode between the switch and my powerful radiator cooling fan, as it caused the engine to run-on while spooling down, after turning the switch off.
FMS 302,GT40 Alum heads,Cobra intake,70mm MAS/TB,24lb injtrs, 8.8w/3.55,WC T5,Srt Perf Seats, donor build except eng/tranny, Hummer Yellow w/o stripes
Radar Pete is offline
post #8 of 8 (permalink) Old 06-20-2019, 10:22 PM
Alan_C's Avatar
The foam and vinyl will compress with time. Just wait a few days, tighten a bit more, then repeat.
I made a very thin washer to insulate the vinyl from the nut. The washer prevents the nut from grabbing the vinyl and tearing it so you can tighten the nut more. In hind sight, it is probably best to cut away the foam from the dash around the hole for the ignition switch before applying the vinyl or leather.
MK4 base kit, 2004 Mach 1 donor, 4.6L DOHC, TR-3650 5-speed, narrowed stock axle with 3.55 gears and TruTrac, PS, PB, ABS, 17" Halibrand replica wheels, 255/40-17 F 295/35-17 R Kumho XS, dual roll bars, Kirkey high back seats, paint by Jeff Miller, registered 9/2014, sold 3/1/2018.
Alan_C is offline
