1 or 2 roll bars? - Page 2 - FFCars.com : Factory Five Racing Discussion Forum
 5Thanks
post #31 of 39 (permalink) Old 12-21-2018, 04:07 PM
I did two and used the Breeze. I just like the look and the slight rake back of the breeze bars.
Chuck Krueger
Conesus, NY
MK IV Kit - Picked up 4/5/14
First Start - 7/25/15
Coyote, TKO500, Wilwoods, Solid Rear Axle
ckrueger is offline
post #32 of 39 (permalink) Old 12-21-2018, 10:49 PM Thread Starter
jhargrove's Avatar
Yup I saw this pic before. Awesome
jhargrove is online now
post #33 of 39 (permalink) Old 12-23-2018, 01:16 PM
Originally Posted by David Hodgkins View Post
The bars are easy; I use quick pins instead of nuts and bolts for the legs:
The covers are the time sink, as I DO use nuts an bolts! I need to come up with a better way to secure those covers without using nuts that need to be held in place by hand under the body. Maybe if I epoxy'd them in place?
So at this point it's not trivial to change them out, but with a better securing mechanism for the covers it would be.
HTH,
EDIT: Here's what the back looks like in "roadster mode":
Love the look of the covers and having the option of going barless occasionally. Are the covers you have commercially available?
Mark IV, complete kit, Coyote, Moser, TKO500, PS, Hydro-boost, Hyd Clutch, 17" Halibrands, Color - Leaning towards Lambo Titanium
corvettebert is offline
post #34 of 39 (permalink) Old 12-23-2018, 05:03 PM
MCathcart's Avatar
Cool
Here's my Logic. First I'm surprised that So Many owner/builders said 1! I'm in this Group, 2 Looks about the same as three testicles and is about as useless (IMO). If Safety is your concern, buy a Volvo. I'd be curious about the actual numbers but I only know of one actual Roll Over, Dave Smith. Am I concerned about a Roll Over? Heck No. Know whats area is most likely damaged in accidents with High Performance Cars? The Front-end... YOU NEED GOOD BRAKES (more than a second clothes line pole). Should have seen some of my Near Misses! Look, it's going to Wreck Like a Brick but Safer than a Motorcycle. No Crumple Zones and No Air Bags.
I commend Mark (Breeze) for being a Smart Business Man... I think his Roll Bar look 10x better than the TALL FFR but it's actually fairly easy to Whack of a Couple inches and do it yourself.
I'm Not Married but no woman I ever rode (yes, in the FFR) ever said, "OH, I'm not getting in Cause You Only Have 1 Thing and it's on Your Side". The current GF I can't make SCREAM she only Laughs and whooooo weeee I've made a bunch SCREAM too.
With all that being said, "It's Yours, Build It Like YOU Want It". Good Luck and Congratulations!
davekp thanked this.
MCathcart is offline
post #35 of 39 (permalink) Old 12-23-2018, 08:55 PM Thread Starter
jhargrove's Avatar
I agree. However I went with two anyways. I did not know you had the ability to remove them. I may want to track the car and or change the look from time to time. The cover idea is awesome.
post #36 of 39 (permalink) Old 12-23-2018, 10:58 PM
conger's Avatar
My choice was easy. When I decided to order my kit, my wife said how come there wasn't a roll bar on her side. And there you have it. Decision made for me.
conger is offline
post #37 of 39 (permalink) Old 12-24-2018, 12:57 AM
Administrator
David Hodgkins's Avatar
Naw, just traced them onto some unused .040 aluminum and cut them out with a dremal. A quick polish and they are good to go!
David Hodgkins, AKA CNGreen
FFR 5369 Pin Drive, IRS, Trigos, Torsen, Wilwoods, FMS
Delivered 4/23/06.
. Plates! 1/2010 BatCave! 1/2012.
Featured Roadster, 2012 and 2013 Huntington Beach Cruise-In
David Hodgkins is offline
post #38 of 39 (permalink) Old 01-01-2019, 01:17 AM
I was originally in the one hoop camp because of appearance. In fact, I liked the the appearance the most when the car had no roll bar. But now I realize that all it takes to flip one of these cars is a little sideways slide (very easy to do) and an impact with a standard street curb. Although I drive alone 99% of the time, I could never live with myself if one of my passengers was injured or killed because they had no hoop. Attached is a picture of an accident my son had when driving alone. Thank God it wasn't me driving with my only son as a passenger.
408W, TKO 600, 4 link, Holley 4150 HP 750 CFM Vacuum Secondary, Wilwood 13.25" 4 piston front, Comp Hyd roller, AFR 185 Heads, Truetrac 9" 3.50
Racer50 is offline
post #39 of 39 (permalink) Old 01-14-2019, 08:39 PM
Changed from single to double. Went with Breeze. Able to use existing holes on driver side and replicated on passenger side. Lower, smaller diam with a slight rear slant and no frankenstien bolt to deal with. The type of steel used is also seamless and rated for roll cages I believe. If the y break so will FF5's. I feel they are stronger because of the thicker wall. This is all IMO, have fun and this is no where near the last change.
347, race 650,vic jr heads and intake,gordons nasty cam and M/T radials
HinoonAZ is offline
