More Puzzlement... - Page 2 - FFCars.com : Factory Five Racing Discussion Forum
post #31 of 38 (permalink) Old 06-04-2018, 05:26 PM
gsides9's Avatar
Rick,
Maybe I am over-engineering, but I am surprised that coolant is returning from your recovery tank at all. Vented caps are not designed to seal against the top of the radiator filler neck. Fords in the early 60s used vented caps with those Harrison (De Gas) tanks that had no recovery system. You need a non-vented cap on your system.
Glen
gsides9 is offline
post #32 of 38 (permalink) Old 06-04-2018, 10:20 PM Thread Starter
CRZN 427's Avatar
Possibly...
Originally Posted by gsides9 View Post
Rick,
Glen
...but I'm following a suggestion from Greg_M, a knowledgeable person on the site.
My understanding on the early Ford systems, which I've posted comments on several times, is that the "expansion tank" has a void space for the fluid to go into when the engine is hot. If the normal high temperature is exceeded the excess displaced fluid will spill out the over flow tube and is lost. The system is closed and uses a 16lb cap that is not vented, the expansion tank (actually the whole cooling system) is under pressure any time the engine temperature is up.
Regards, Rick
CRZN 427 is offline
post #33 of 38 (permalink) Old 06-04-2018, 10:35 PM
1st RFM/FFR Legacy Winner
Greg_M's Avatar
Rick,
Glen
This one is.
FFR4373RD MK3, nondonor, DIY options/mods/paint, Lexus indigo/Viper silver, Hydroboost PS&PB/discs/ABS, AC/heat, 3-link/Konis, FMS302E, Holley 600DP/Airgap, 4X4 exhaust, Halibrand deep lip chrome CobraIII, TeamIII spinners, rollbars: chrome full & single
Greg_M is online now
post #34 of 38 (permalink) Old 06-05-2018, 05:57 AM Thread Starter
CRZN 427's Avatar
Same For The One I Got...
Stant 10231 Cap.
https://www.speedwaymotors.com/Stant...iABEgK1iPD_BwE
CRZN 427 is offline
post #35 of 38 (permalink) Old 06-05-2018, 10:42 AM
Greg_M's Avatar
Yep. The only difference is the lever.
post #36 of 38 (permalink) Old 06-05-2018, 01:27 PM
gsides9's Avatar
There is a reason that it says vented.
gsides9 is offline
post #37 of 38 (permalink) Old 06-05-2018, 02:24 PM
Greg_M's Avatar
And the reason is not because it does not seal against the radiator neck or any other place a conventional cap seals at, it's because the vacuum valve remains open to the overflow bottle ALL THE TIME (during heating and cooling) cycles unless the sufficiently coolant rushes past it as in a boil over and closes the vacuum valve, sealing the system as a conventional cap does.
post #38 of 38 (permalink) Old 06-05-2018, 04:14 PM
gsides9's Avatar
Thanks for the explanation. I learned something new today. Back in the day non-vented caps had a brass-looking disc where the cap would seal against the radiator, just looked at one last night. Now I'll be figuring out the advantage of keeping it vented (not building pressure) until the hot antifreeze hits the cap.
Glen
gsides9 is offline
