Exhaust too loud, any suggestions? - Page 6 - FFCars.com : Factory Five Racing Discussion Forum
 3Thanks
post #151 of 154 (permalink) Old 06-09-2011, 09:44 PM
Runner55's Avatar
Quiet Pipes
I tried Oldtops method and it works, but needs repacking ofter at least for me, but still too loud. Went to quiet pipes from Breeze, got them ceramic coated and couldn't be happier.
Nice sound and very operator friendly.
Dlvd. 2.09 On the road 5.10
Runner55 is offline
post #152 of 154 (permalink) Old Today, 06:42 PM
DadofThree's Avatar
Bringing up an old thread, but I'll be trying this soon. I (AND MY WIFE) can certainly tell that my pipes have a different sound than last year. My wife is now asking for ear plugs. 12,000+ miles so far, and I'm willing to try this solution. We like the loudness of the cobra, but there is a new harshness that wasn't there before.
Before you tell me to purchase new ones, I like the look of the surface rust sidepipes on my car, so I don't really want to purchase newer pipes yet. I did reach out to Georgie regarding Gas'N pipes in Carbon Steel, but they don't do it.
Anyway, I'll let you know what I learn.
Originally Posted by Oldtop View Post
You could try this cheap and easy method to extend the glass-pack. It cuts down the noise and does't require taking the exhaust apart. Just add 7-8 inches of fiberglass pipe insulation to the turnout along with a piece of gutter screen and an end cap to hold it all in place. It has held up for over 3,000 miles on our MkIII Roadster.
The gutter screen and pipe insulation are from Home Depot, the end cap is made from a sink strainer model # K5416 found at Lowe's. The outside diameter fits in the exhaust pipe nicely, but be sure to measure before cutting. The center hole is about 2 1/8" .
The material I use is pipe insulation for 2" pipe. It has an I.D. of 2 3/8" and O.D. of 3 1/4". Cut a piece long enough to fit snug between the end cap and the muffler insert. You want the end cap hole a little smaller so the gutter screen won't fall out, say 2 1/8" - 2 1/4". For now I use a single piece of gutter screen 8" x 6" rolled in to a tube to hold the fiberglass in place. It's not a perfect solution but it is cheap. As for leaving the strainer basket on, it cuts the sound a lot, but kills performance.
Just to clarify a question about how to cut and roll the gutter screen...the screen comes in pre-curved 6" wide by 36" long pieces. Flatten it out and roll it along its length. You need 8" of circumference to make a 2.5" diameter "one-piece" tube. If you look closely at this picture you can see which direction the weave goes. Hope this helps.
Originally Posted by mikek View Post
I just tried oldtop's exaust mod and added cobrathegreat's steelwool idea and I can't be happier, the sound is deeper and alot quieter, and for under $40.00 it's perfect. I have noticed a little power loss, but I started with 630hp so I'll be ok. Thanks for the great ideas
guys.
I did use the fiberglass insulation, but I also cut a piece of the gutter guard into a circle and stuffed it into the sink basket, then another circle into the pipe up against the back of the fiberglass and sandwiched a stainless steel pot scrubber in between the two. The pot scrubber is loosely woven unlike a steelwool pad which would be way to much restriction.
Dave
My photos are at:
Videos are at:
Loving the Island Life
DadofThree is online now
post #153 of 154 (permalink) Old Today, 09:04 PM
phileas_fogg's Avatar
Hey Dave,
Be sure to investigate the inserts (https://marineexhaust.ggb.ca) bobl identifies on the other forum (https://thefactoryfiveforum.com/show...s-discontinued). Could be just the ticket for keeping your wife happy.
MK IV Roadster #8631
phileas_fogg is online now
post #154 of 154 (permalink) Old Today, 10:56 PM
DadofThree's Avatar
Originally Posted by phileas_fogg View Post
Hey Dave,
Thanks John. I saw that thread and I went to that location first. But it also got me searching the forum, and I found this method. I think I'll try this low cost method first.
Dave
My photos are at:
Videos are at:
Currently Active Users Viewing This Thread: 9 (5 members and 4 guests)
turbosd , CA Crum , kgkeys , Tuftster , cobrajj
