Exhaust too loud, any suggestions? - Page 3 - FFCars.com : Factory Five Racing Discussion Forum
 3Thanks
post #61 of 154 (permalink) Old 04-12-2010, 02:54 AM
sharp6034's Avatar
Cobra Pack Mufflers
Rare Iron Eric, you have my attention.... What are Cobra Packs and what is the cost?
sharp6034 is offline
post #62 of 154 (permalink) Old 04-12-2010, 09:09 AM
Cone Killer
RedJoker's Avatar
Maybe I missed it but wind wings and visors have GREATLY reduced the wind buffetting for me. I also have lobaks and am very happy.
RedJoker
G3F Build Blog:
RedJoker is offline
post #63 of 154 (permalink) Old 04-18-2010, 10:51 PM
mikek's Avatar
Thankyou oldtop
I just tried oldtop's exaust mod and added cobrathegreat's steelwool idea and I can't be happier, the sound is deeper and alot quieter, and for under $40.00 it's perfect. I have noticed a little power loss, but I started with 630hp so I'll be ok. Thanks for the great ideas
guys.
Without your plumber you would have no place to go...Socrates
mikek is offline
post #64 of 154 (permalink) Old 04-18-2010, 11:02 PM
sharp6034's Avatar
What is the steel wool part??
I'm not sure what the steel whhol part is please explain.
post #65 of 154 (permalink) Old 04-19-2010, 12:40 AM
Sanford's Avatar
I'm guessing he used steel wool instead of fiberglass in Oldtops mod.
Sanford is offline
post #66 of 154 (permalink) Old 04-19-2010, 01:39 AM
mikek's Avatar
I did use the fiberglass insulation, but I also cut a piece of the gutter guard into a circle and stuffed it into the sink basket, then another circle into the pipe up against the back of the fiberglass and sandwiched a stainless steel pot scrubber in between the two. The pot scrubber is loosely woven unlike a steelwool pad which would be way to much restriction.
mikek is offline
post #67 of 154 (permalink) Old 04-19-2010, 04:12 AM
Too much is just enough.
Motorhead's Avatar
Cobra Packs are straight through exhaust inserts made by Classic Chambered: http://www.classicchambered.com/clas...cts.html#cobra.
You have to cut your pipes and then weld in the new mufflers. The pros of this option are: various lengths, you can make your pipes go all the way back to the rear fender now and give it a better look IMO. You can also choose to have the glasspack inserts or not. With glasspacks, I've heard they are similar to Quiet Pipes is dbs. Another pro is that these are designed correctly for exhaust flow. You're engine will perform the best with these pipes. I've seen pictures of the inside of the FFR pipes and at least in those pictures the mufflers were backwards.
The cons of this option are that you have to cut your pipes and weld in the Cobra Packs (including exhaust hangers). Then you have to clean the pipes up and ceramic coat them if you want.
-Joe
"It's loud, smells like gasoline, and shakes, shudders, and bucks. It makes your arms tired and your feet hot. You nearly crash about once every ten minutes. It's so damn wonderful you canít believe it." -Automobile Mag. Oct. '04
"AC Cobra - America's sensational GT car." - Road & Track Road Test Annual '64
Motorhead is offline
post #68 of 154 (permalink) Old 04-19-2010, 04:31 AM
mikiec's Avatar
One thing you might consider is getting a set of motorcycle type headsets with microphones. This way you'll save your ears and still have a converation.
mike
All gave some, Some gave all. Rest peace my brothers
mikiec is offline
post #69 of 154 (permalink) Old 04-21-2010, 09:31 PM
SJDave's Avatar
Zoomie Insert Update
Originally Posted by SJDave View Post
Has anyone tried these inserts inside the Long tube Headers before the side pipes?
Seems like an easy install without cutting those expensive SS pipes.
$199 for a set of 8 inserts.
Car Chemistry does not make the Zoomie inserts to fit 1.5" ID pipes like the BBK's that came with my 3.1 complete kit. I talked to them yesterday and they believe it is possible to do and still achieve 10db sound reduction and minimal HP loss. So I ordered a set of 8 for $199 that will fit the BBK pipes. They will use a 1.2" core with high temp fiberglass packing around them.
I'll post some pictures of them when I get them installed and sound level results before and after.
Dave
SJDave is offline
post #70 of 154 (permalink) Old 04-21-2010, 10:37 PM
hotrodedell's Avatar
I didnt think it was possible to be too loud...lol..Then again I may be half deaf from 26 years of Drumming and Driving open header cars...
hotrodedell is offline
post #71 of 154 (permalink) Old 04-22-2010, 08:14 PM
fat-n-fast's Avatar
too loud
unheard off solution Buick Lucerne:
FFR 6513 408w tko600 3.55 Levi aluminum LCA Whitby power brakes Fortes midshifter
fat-n-fast is offline
post #72 of 154 (permalink) Old 04-22-2010, 08:32 PM
Matstng's Avatar
Nice solutions....
I'm one that thinks these cars can't be too loud
Maybe it's time for a Miata
Happy Wife... Happy Life
MK 3.1, IRS,Koni,Wilwood 4WDB,Wilwood pedals, Quick rel steering wheel, 500HP/427ci(351W)/TKO600 5sp,17" AR Cobra III
Still finishing... but I'm on the road
Currently in the stable:
2005 Mazda 3 hatch
1965 MK 3.1 Roadster (427W/TKO600) Wilwood 4WDB
1968 Mustang conv 302/C4 (bought in 86') Project
1967 Mustang S-code Fastback (1968 GT350 clone)
1967 Mustang coupe FiTech EFI
1948 Dodge truck B1
2001 Paint (1 HP)
Wifes
2001 Porsche 911 (996) conv
2007 Palomino (1 HP)
Matstng is offline
post #73 of 154 (permalink) Old 04-25-2010, 01:17 AM
quatro007's Avatar
You guys who like loud cars would like my pipes then. I really liked the sound at first but then it just sort of got old and isn't a pleasure to drive for more than 5min without earplugs. Now, what DO you guys consider too loud???
This thing runs at around 90db at idle. It's not really the volume that gets to ya, it's the pop they have. The closest thing I can compare it to is a stock car. Watch the vid from my signature and imagine 90+db as you drive. I just want to knock it down just a touch and Oldtop's solution works (still louder than stock FFR exhaust). But, I keep having problems keeping fiberglass packing in the pipe. I tried a one piece section of the gutter guard and by the end of the day it has sucked the guard half way INTO the pipe. The next time I started the car it looked like I sucked a rabbit into the engine (gray fiberglass everywhere). There went the packing. So, I'll try one more time to get this to work then start considering new pipes. Maybe I can find someone local who has an extra set of pipes to borrow so I can hear what normal pipes sound like.
"Cobra Commander"
FFR #6728 Complete kit MK3.1, Delivered 9-27-08, First start 1-25-09, Go Kart 2-21-09, Completed 6-12-09, Graduated 8-25-09
351W (should be ~450hp, still need to dyno), Dart heads, full roller Comp Cam, Carb'd, TKO 500, 3Link,
Paint by Street Rod Painter - Ken Pike (Toyota Phantom Gray Effect/Mercedes Brilliant Silver stripes)
Build photos:
Go-kart video:
quatro007 is offline
post #74 of 154 (permalink) Old 04-25-2010, 04:43 AM
Barn Job's Avatar
Thumbs up Super S pipes
These intrigue me. I think adding a crossover pipe would be a further improvement.
https://www.ffcars.com/forums/showthr...ighlight=pipes
Michael
Barn Job is offline
post #75 of 154 (permalink) Old 04-25-2010, 11:12 AM
DanGurneyForPresident's Avatar
Send a message via AIM to DanGurneyForPresident
Ha: right there with you except only been drumming 12 years.
May 2008 build school
November 2008 - picked up complete roadster # 6829
September 2009 - engine install
November 2009 - first start and go-cart
July 2010 - Painted 1965 Rangoon Red.
August 2010 - Registered and blessed by evil DMV
1965 289 stroked to 331, TKO-600, 3.55s. Powered by Fortes.
DanGurneyForPresident is offline
post #76 of 154 (permalink) Old 04-25-2010, 11:54 AM
tim-in-oakton's Avatar
I found DIY custom plugs for under $15 online and they work GREAT!!!
For anyone interested, it is a two part "silicone epoxy like" approach, just like Epoxy Putty - you knead the two parts together, stick them into your ears, wait 30 mins then take out perfectly custom ear plugs.
My ear canals are too small for the "Normal orange plugs" to fit well (they are a bugger to get in, are painful - wish they came in different sizes!), so these are well worth the $15!!!!
FFR 5736, MKIII, 3 link, PS, PB, 302 w GT40 heads & intake, 3.55, Cobra brakes
tim-in-oakton is offline
post #77 of 154 (permalink) Old 04-25-2010, 12:22 PM
happybigblock's Avatar
Send a message via AIM to happybigblock
I used (borrowed) the two flange cc inserts in the FFR pipes and simply drilled one hole through the inside of the rear pipe(under the car) just behind the rear weld. I was then able to slide the insert in from the opening, line up the hole in the insert flange with the hole I drilled. One sheet metal screw, inserts are in. Much quieter. Passed inspection. I now run Gas N pipes. Deeper, more mellow sound. Not the jack hammer effect of the originals without the inserts. Overall, the best sound abatement we found was the two stage CC inserts but I really like the look of the Gas N pipes now.
HTH.
-Steve
427 FE w/ alum. intake and heads, 8.8 with 3:55s, Graduated 12/29/06, 2008 FFR Open House Best in Show Roadster
happybigblock is offline
post #78 of 154 (permalink) Old 04-25-2010, 12:26 PM
Driver not a Waxer
tx_dajohnson's Avatar
I have a brand new set of the Car Chemistry 3 disk with coated turn out still in the box. When I bought a set of custom new/used pipes from a crazy freind of a freind I knew it would be louder, but freaked when I first started it up. Since then I have grown love that sound and even my wife says it sounds great. my neighbors aren't so sure, bit I am legend. Are your turnouts angled down 45 degrees? That makes a huge difference. And BTW the CC stuff is forsale, best offer...
The whole is more than the sum of the parts, and twice as loud
tx_dajohnson is offline
post #79 of 154 (permalink) Old 04-25-2010, 12:48 PM
Anthony S's Avatar
Try these they work great I usually ware one stops wind noise as well.
http://www.gamaliel.com/cart/product.php?productid=6482
Anthony
Anthony S is offline
post #80 of 154 (permalink) Old 04-25-2010, 02:39 PM
Smile
My original Lone Star side pipes were loud. My motor was a 380 hp 302. At 4000 rpms it sound like a Nascar motor. You could hear me 1 1/2 miles away. Got pulled over by a cop who heard me at 6000 rpms. He was three blocks away. NO ticket. And I do have a pictures to prove it!
Two years ago I stroked the motor to 354 ci and replaced my 24" side pipes, which had a 2 1/2" core with Classic Chambered Cobra 28" pipes with 3" core. Much quieter. Low deep rumble. Very quiet at 60 - 70 miles per hour. Great below 4000 rpms.
If you increase the inside volume of your side pipes they will quiet the exhaust sound.
Dwight
DWIGHT is offline
post #81 of 154 (permalink) Old 04-26-2010, 06:55 PM
quatro007's Avatar
That kind of sounds like mine. I've been heard over 3mi away under full throttle. After looking at the CC website, I'm wondering if my mufflers are without packing. I didn't know that was an option but it would explain the loud raw sound. Does anyone know of a way to tell if I have packing without drilling a hole in the muffler body? I'm starting to lean toward new pipes since I can't seem to keep Oldtop's mod intact, sorry Oldtop. I'll give it one more shot though.
Dwight
"Cobra Commander"
Build photos:
Go-kart video:
post #82 of 154 (permalink) Old 04-26-2010, 07:22 PM
Magnus's Avatar
Send a message via AIM to Magnus
I know I'm late to this party, but having lived in my car for 25,000 miles, often doing several hundred miles in a day, I'd like to add this:
Never forget that we are trying to civilize a wild beast, kind of like pretending that a wolf can be a pet, which is wishful thinking. I have a small 4.6L engine, regular manifolds going into catalytic converters, and FFR sidepipes. Turns about 2,500 on the freeway and is still too loud. Buffetting behind big trucks pounds on the ears.
I always wear earplugs; generally corded ones so I can carry them around my neck when I'm out of the car. The have a little stem for easy insertion. To me it's cheaper and easier than rebuilding the exhaust system.
The original dash-mount mirror is worthless, especially on multilane interstates. I added an 8-inch-wide panoramic mirror and breathe much easier now.
43,000 miles as of 8/15/2013
Magnus is offline
post #83 of 154 (permalink) Old 05-14-2010, 03:49 AM
SJDave's Avatar
Preliminary Sound Level Results - CC Zoomie inserts
[QUOTE=SJDave;2224298]Car Chemistry does not make the Zoomie inserts to fit 1.5" ID pipes like the BBK's that came with my 3.1 complete kit. I talked to them yesterday and they believe it is possible to do and still achieve 10db sound reduction and minimal HP loss. So I ordered a set of 8 for $199 that will fit the BBK pipes. They will use a 1.2" core with high temp fiberglass packing around them.
Installed the inserts this weeks, took about 1 hour to clear out the excess weld material in the BBK pipes so the inserts will slip in. Used a round bastard file and "flap" sander roll in the die grinder.
Mine were a really tight fit so I took alot of measurements and CC will reduce the OD a bit for the next person. I am pretty happy with the initial results, I used a meter held at head level in the driver position...my car is still go-cart stage.
Zoomie Insert 1.5" OD:
Fiberglass wrapping removed:
A look inside:
900 RPM IDLE:
Before - 92 dbA
With Zoomie inserts - 82 dbA
3000 RPM no load:
Before - 103 dbA
After - 95 dbA
For $200 I think it is pretty good gain on sound reduction, I'll see what it does to performance once I get the car licensed and on the road.
Dave
SJDave is offline
post #84 of 154 (permalink) Old 05-14-2010, 01:02 PM
Fred Turton's Avatar
Sound Quality?
I am considering doing the same thing with my 4X4s, SJDave. You note the dB reduction. How would you evaluate the change in quality of the exhaust note with the Zoomie baffles? To me the high-pitched "bark" with the stock pipes is worse than the dB level - although dB reduction is also needed.
Thanks in advance. FET
Fred Turton
2002 Mark II, #2280
Carb'd 351W
IRS
Elwood: It's 106 miles to Chicago, we got a full tank of gas, half a pack of cigarettes, it's dark, and we're wearing sunglasses.
Jake: Hit it!
Fred Turton is offline
post #85 of 154 (permalink) Old 05-14-2010, 02:11 PM
Shade Tree Mechanic
Scalded Dog's Avatar
Originally Posted by 342Stroker View Post
Don't rule out the foam throw away type earplugs. They have one of the highest noise reduction ratings (NRR). Most have an NRR rating of 33. That means when properly inserted (yes this is a proper way to insert them, most don't do it and it affects the rating) they will reduce the noise level by 33db. About the only thing more effective are the molded ones. They cost about a $100 and any place that sells hearing aid can make them up for you. You need to be sure to keep them clean to avoid ear infections. That another advantage of the throw aways. There cheap enough to use them once then throw them away. You can buy them in bulk packs from Grainger or any industrial supply house. Us can get a carton of 100 pairs for about $25-$30. I use them on the motorcycle under my helmet (wind noise on a mc can be >95db), for shooting and will use them in the cobra. And yes you can still hear whats going on around you...it's just muffeled.
Correct me if I'm wrong, the proper way to inset them is to roll them up tightly and insert in ear and let them expand to fill ear canal? I like the loudness of mine. It serves as a warning to dumb-assess on the road. I like to drop down a gear and gun it when I'm next to someone playing crap music or yakking on cell or texting. I'll tell you it get's their attention quickly.
MKIII, 302 FMS Crate, GT40 Heads, Quick Fuel carb, TK0500 Mid-shift, 3-Link, 300 RWHP & Trq. Finally done after two years. I think I will call her Black Betty
"It is only when you see a mosquito landing on your testicles that you come to realize that there can be value in solving problems without using violence.Ē
Scalded Dog is offline
post #86 of 154 (permalink) Old 05-14-2010, 02:23 PM
Magnus's Avatar
Roll them tight as you can and stick 'em im. Over the years I have found that wetting them a bit with some saliva makes it easier to slip them in. Make all the jokes you want--it works. Corded, baffled plugs usually have a rigid center with a piece that allows you to guide the plug in and out as needed. I really like those because you can carry them under you shirt when you are out of the car.
That said, there are some types of plugs that i like and some I can't stand. You just have to find what works for you.
Magnus is offline
post #87 of 154 (permalink) Old 05-14-2010, 02:49 PM
SJDave's Avatar
I was afraid to make this post, as it opened me up to a deluge of sissy boy attacks......but man they are funny! Made me LOL!
I agree, I like the noise and the earplugs are the way to go.....so why do this:
1) The biggest reason I am trying to get the sound down is to keep some peace in the home...mainly when I am tinkering with the car. It makes the dishes rattle in the cabinets so I am now only starting and tuning when she leaves the house....yes I have been a bad dog for a long time and there is not much more Sh*%&t she will tolerate. Now that I think about it, I should probably just attach hoses to the sidepipes, run them into a 30 gallon trash can outside converted to a giant muffler. Hey, I can mount that on the trunk for Autocross days...Sweeeeeeet! Duct Tape it. Improved Braking , i love it.
2) The local Autocross run at Great America has a sound limit of 96 db, these inserts probably aren't going to get me there, so I will need some caps to put in the sidepipe ends also....or the trash can muffler.
3) I'm 60 years old....everyone tells me I have to start acting like it.
QUALITY OF THE SOUND - Much less Bark, more mellow...
SJDave is offline
post #88 of 154 (permalink) Old 05-14-2010, 04:17 PM
Rick Harper's Avatar
For some quantitative sound levels, here is a post I did some time ago.
It is long winded, but I think has some relevant info on different pipes, etc, along with some solid test data on two sets of pipes...
https://www.ffcars.com/forums/showthread.php?t=182840
F5R1004833. IRS, 427W, T56, pin drive.
Rick Harper is offline
post #89 of 154 (permalink) Old 05-14-2010, 05:39 PM
trackzpeed's Avatar
When I bought my car it had baffles in it.....they made this annoying chirp and tweet sound all the time. I pulled them out and to be honest the car is about the same in terms of levels but sounds much nicer........I hate to admit it, but I'm 43 years old and I still chant the montra "If it's to loud you're too old"
TRACKZPEEDS Levy Racing Built FFR MKI
trackzpeed is offline
post #90 of 154 (permalink) Old 05-14-2010, 05:48 PM
larryb's Avatar
I don't know, I'm younger than U and like my undercar exhaust, definetely quieter... )
FFR 6639 3.1 Complete kit received 11/28/08, 1965 289 stroked to 347, custom undercar exhaust inside frame, 3 link, tko-600 , ebrake mod, heater w/fresh air intake, Corbeau LG-1 seats, custom vinyl interior. Registered 6/10, 1st Racetrack 9/29/10 (limerock), first AutoX 10/10/10. Painted Corvette Velocity Yellow 4/11
larryb is offline
