Sorry if this is obvious but what tranny fluid do I use in my TKO 600? I used the search and didn't find the answer. I also looked in my garage for the manual last night but couldn't find it.
GM Syncromesh (so says the Tremec manual) - check Forte and Breeze prices before going to GM dealer. My local GM dealer was almost twice the price per quart.
I called the Tremec tech line a while ago and asked the same question. Their tech guy stated that Dexron III should be used for the first 1000 miles and then you can use the GM synchromesh. The tech guy stated its the same as engine. Would you use synthetic to break in an engine. The answer is "NO" in my book. Pennzoil makes the GM synchromesh. You can find it at AZ and its much cheaper.
What is the proper break-in procedure for a TREMEC TR-3550/TKO 5sp?
A:
Put 3qt of good quality ATF (Auto Transmission Fluid) (Dexron) into the transmission. Pour in through shifter mount, or through one of the top plates. You can use the fill plug on the side of the transmission also (afterall, that's what it's for!). It's just easier to pour it in from the top if you can.
Put car on jacks, run the transmission up and down through all gears repeatedly for 15 minutes. This will allow the gears to break in properly (yes, with the engine running)
After 500-700 miles, drain the ATF, and put in 3qt of the GM Synchromesh fluid, the part number is 12345349. If it's a race car only, then switch to the GM Synchromesh after the initial break-in.
Don't use synthetic lube for 6000-8000 miles. In fact, we don't recommend synthetic, just stick with the GM Synchromesh.
Baby - my quote is direct from the 600 data sheet that arrived with the box this week, same as the one a year ago with the previous 600 - you may rely on a pre 500 or 600 web site, but I will go with factory recomendations................
Well not to be left out, but I think I'll ask the audience, or maybe take the 50/50...no I'll do the mobile shout out.....Yeah Syncromesh says the guy on the sidewalk...final answer!
Related Threads
Factory Five Racing Forum
3.3M posts
50.6K members
Since 2002
