Kit 075 nearing finish - Page 3 - FFCars.com : Factory Five Racing Discussion Forum
Thanks Tree32Thanks
LinkBack Thread Tools
Old 09-15-2018, 12:51 AM   #61 (permalink)
wrp
Amazingly, it seems the last and simplest step, sealing the door windows has been the most challenging. The thinness of the material in the top of the door led us to reinforce it only to discover the strips of window wipes would not fit the reinforced edges. We looked around and while there are a lot of good solutions out there we just did not have the necessary materials or understanding to implement or copy someone else so we just fabricated our own as best we could. The solution, our solution, involves two pieces of angle iron on each side of the slot, glued into place with the felt strips glued to them in a fashion that supports and guides the window. Simple enough but a bitch to execute. Here are some early stages, gluing the angle iron to the door.
wrp is offline   Reply With Quote Quick reply to this message
Old 09-18-2018, 10:02 PM   #62 (permalink)
wrp
Getting closer to finishing the window wipes.
Old 09-19-2018, 02:45 AM   #63 (permalink)
S13
S13's Avatar
Great build, love the interior and the green paint!
Please include lots of pictures and details of how you do the side window seals, thanks!
S13 is offline   Reply With Quote Quick reply to this message
Old 09-20-2018, 01:42 AM   #64 (permalink)
wrp
I am pretty stoked on the way the side windows came out. Once we reinforced the door tops we could not use the FFR furnished whisker strips. The guys fabricated the strips out of angle iron and aftermarket universal whisker strips. Basically an angle on each side with the strips bonded to the vertical run on the angle while the angle attaches to the top of the door bottom with the horizontal side.
Old 09-21-2018, 09:05 PM   #65 (permalink)
wrp
This is exciting
Old 09-22-2018, 02:15 PM   #66 (permalink)
All spiffed up and ready to come home.
wrp thanked this.
Kamp is offline   Reply With Quote Quick reply to this message
Old 09-22-2018, 02:35 PM   #67 (permalink)
Sweet. Can't wait to see it in person.
wrp thanked this.
dallas_ is online now   Reply With Quote Quick reply to this message
Old 09-23-2018, 06:30 PM   #68 (permalink)
wrp
Originally Posted by Paul L View Post
wrp - As others have said, very nice indeed.
Good luck putting it all back together, Paul.
PS
RoadRacer - I think you have been in Texas too long and forgotten how to spell colour.
You never see a Texan in Gaol
Old 09-23-2018, 06:35 PM   #69 (permalink)
wrp
One thing we discovered, well a couple of things. We had to put a stop on the window mechanisms lest they push too far upwards. Also, there is a gap between our whiskers and the edge/bottom of the hardtop. We will figure something out.
Old 09-27-2018, 04:11 AM   #70 (permalink)
wrp
Fun little video of the process of cutting the window slots, reinforcing the door top and trying different solutions over time to the window seals for the doors.
Old 10-06-2018, 09:30 PM   #71 (permalink)
wrp
Touching up the final areas and buffing them out. Also working on the grill. We've decided to go ahead and finish hooking up the HVAC so that should take a little more time.
Old 10-18-2018, 03:18 PM   #72 (permalink)
KGB911's Avatar
Vintage 33
I worked on both #76 & #77 ! those and yours are very early cars with many challenges as those cars were just out of the beta stage as FF skipped some numbers in the 1st hundred as I remember. Geoff would know.
Dr.Ruth
wrp thanked this.
KGB911 is offline   Reply With Quote Quick reply to this message
Old 10-19-2018, 12:08 AM   #73 (permalink)
wrp
Dr.Ruth
Your assistance, articles, posts, and many hours on the phone explaining most of those issues and pitfalls were no small factor in the success. I guess one blessing was the molds were fresh and the car sat with the glass seasoning for a long time.
Thank you.
Old 11-17-2018, 12:49 AM   #74 (permalink)
wrp
So have been working on the HVAC, mocking up the compressor and alternator relocations as well as relocating the overflow and locating and positioning the dryer. Today they mostly finished the hard line installation. We did not initially get the FFR kit, Started with a bargain on an Old Air Under Dash unit and sort of built it out form there.
Old 11-17-2018, 12:52 AM   #75 (permalink)
wrp
Page 2 HVAC
Old 11-17-2018, 12:54 AM   #76 (permalink)
wrp
Page 3 HVAC
Old 11-17-2018, 12:56 AM   #77 (permalink)
wrp
Page 4 HVAC
Old 11-17-2018, 12:57 AM   #78 (permalink)
wrp
Page 5 HVAC
Old 11-18-2018, 02:35 AM   #79 (permalink)
wrp
Interesting thing on the wiper, Kory wanted to avoid wire connections from the removable top to the lower interior body area so he used connectors that match up when the top is installed and provide power to the wiper unit which was essentially a unit from Speedway. There are some better ones out there that are not as large and imposing. I cannot recall the brand just do a search on Hot Rod Wiper Kits. The kit was permanently mounted to the top. There are some great kits that have dual wipers that mount from under the dash. Ours just entailed drilling a hole and running the wiring to the connectors.
Old 11-18-2018, 05:47 PM   #80 (permalink)
wrp
Inside connections for the HVAC
Old 11-19-2018, 01:08 PM   #81 (permalink)
andreast's Avatar
Hey Bill, how did you snake the wiring down from the wipers to the body, getting ready to do the same but with two wipers (required by local authority). Appreciate the insight.
andreast is offline   Reply With Quote Quick reply to this message
Old 11-19-2018, 09:33 PM   #82 (permalink)
wrp
I don't seem to have a picture of the roof connection, here is how we connected the power windows in the doors to the interior of the car.
andreast thanked this.
Old 11-20-2018, 08:22 PM   #83 (permalink)
wrp
Originally Posted by andreast View Post
Could you provide a few pictures of the setup, I was struggling on how to do that and think this would be a great option, details would be appreciated!
You must be getting very anxious to be able to drive away finally!!!
So to mount the wiper kit they had to drill a hole through the top of the cab. The motor had wires coming out of it so they drilled a hole in the inner layer of the roof so they could snug the motor to the roof with the wires inside between the inner and outer layers. They then ran the lines to the driver side window top of the roof between the layers, across the top of the window inside the roof and then down to the connector that is mounted just to the rear of the window opening. That contact rests against another contact on the lower body that is connected to the power source. This way I can remove the roof without unfastening wires.
Old 11-24-2018, 01:51 AM   #84 (permalink)
wrp
Finished up plumbing the engine bay portion of the HVAC tying the compressor together with the dryer and bulkheads. Also tied in the heater hoses. Need to finish the interior runs from the bulkhead to the AC/Heater Unit.
Old 11-24-2018, 01:54 AM   #85 (permalink)
wrp
Also installed the front mounted QA-1 Double Adjustable shocks.
Old 11-27-2018, 11:54 PM   #86 (permalink)
wrp
Sending the Radiator out top get checked, flushed, tested, and if necessary, repaired.
Old 12-01-2018, 01:05 AM   #87 (permalink)
wrp
Radiator passed the test, the cap was bad though. I hit the shroud with some polish to see if that would help.
Old 12-01-2018, 01:08 AM   #88 (permalink)
wrp
We are also trying to see if a stainless steel liner will work on the inside of the side panel covers to help visually with the engine compartment.
Old 12-04-2018, 04:41 AM   #89 (permalink)
wrp
Coming back together
Old 12-04-2018, 11:43 PM   #90 (permalink)
wrp
Continuing reassembly
Insurance
» Premium Vendor Showcase
» Recent Discussions
Mark II
07-17-2019 05:08 AM
Last post by Derald Rice
Today 12:48 AM
21 Replies, 426 Views
Air conditioning advice...
07-10-2019 11:59 AM
Last post by Steven K
Today 12:19 AM
15 Replies, 405 Views
2020 Mid-Engine Vette
Yesterday 10:59 AM
Last post by Jim1855
Today 12:14 AM
5 Replies, 103 Views
Gateway Cobra Club in...
07-18-2019 02:13 PM
Last post by Purple Venom
Yesterday 10:07 PM
2 Replies, 48 Views
J. H. Cobra Build Thread ( 1 2 3 4 5 )
03-08-2019 09:42 PM
Last post by jhargrove
Yesterday 09:26 PM
146 Replies, 5,878 Views
‘95 4.6L intake manifolds
06-27-2019 08:31 PM
by MikeG
Last post by MikeG
Yesterday 08:35 PM
4 Replies, 144 Views
Strange but true
07-18-2019 03:59 PM
by USMC
Yesterday 07:15 PM
6 Replies, 135 Views
Rear discs vs drums
07-17-2019 11:35 PM
Last post by NiceGuyEddie
Yesterday 06:56 PM
8 Replies, 230 Views
Northwest Club Cobra...
03-08-2019 06:23 PM
by bsnyder
Last post by bsnyder
Yesterday 06:38 PM
5 Replies, 486 Views
Uber Fleet Business Ideas
Yesterday 05:34 PM
by moresa3
Last post by moresa3
Yesterday 05:34 PM
0 Replies, 22 Views
GTM Gen1, #105 Fires Up! ( 1 2 3 4 5 ... Last Page)
12-14-2012 05:42 PM
Last post by 00SS_M6LS1
Yesterday 05:32 PM
621 Replies, 58,609 Views
Surfdog57's Gen 3 (#12)... ( 1 2 3 4 5 ... Last Page)
06-05-2015 08:36 PM
Last post by SurfDog57
Yesterday 04:59 PM
403 Replies, 38,967 Views
so what did you do to... ( 1 2 3 4 5 ... Last Page)
12-12-2010 05:53 AM
Last post by egchewy
Yesterday 03:17 PM
2 Replies, 200,497 Views
how old do you have to... ( 1 2 3 )
09-10-2010 09:33 PM
Last post by crash
Yesterday 02:54 PM
63 Replies, 3,726 Views
Creaking sound from toll...
Yesterday 07:47 AM
Last post by Boat737
Yesterday 02:29 PM
4 Replies, 114 Views
2015 Donor Mk4 Roadster... ( 1 2 3 4 5 ... Last Page)
02-11-2019 03:22 AM
by IsaacW
Last post by IsaacW
Yesterday 05:39 AM
264 Replies, 7,796 Views
Hello from LA
07-15-2019 06:27 AM
Last post by David Hodgkins
Yesterday 05:25 AM
3 Replies, 53 Views
Headers, Sidepipes,...
04-25-2019 10:58 PM
Last post by chrisarella
Yesterday 04:44 AM
6 Replies, 838 Views
Road trip to the Cave
07-18-2019 02:37 PM
Last post by silver_pilate
Yesterday 04:39 AM
3 Replies, 158 Views
Hello to all
07-15-2019 11:09 AM
Last post by gtaroger
Yesterday 03:50 AM
1 Replies, 36 Views
