35 Truck - FFCars.com : Factory Five Racing Discussion Forum
'33 Hot Rod Forum sponsored by classic E/T Wheels Call (510) 895-8880
Thanks Tree2Thanks
  • 2 Post By David Hodgkins
LinkBack Thread Tools
Old 10-31-2017, 06:53 AM   #1 (permalink)
j33ptj's Avatar
35 Truck
What do you al think?
For me the bench is a nice feature, but the top is too high, it needs chopping...
Robert
j33ptj is offline   Reply With Quote Quick reply to this message
Old 10-31-2017, 11:59 AM   #2 (permalink)
Wakeboardnsd's Avatar
Robert
Im not sure yet. In my wifes words its cute
Wakeboardnsd is offline   Reply With Quote Quick reply to this message
Old 10-31-2017, 01:47 PM   #3 (permalink)
Barrel's Avatar
[QUOTE=j33ptj;5855226]What do you al think?..
Not impressed at all. A genuine opportunity to correct the short comings of the '33 Hot Rod ignored.
Barrel is offline   Reply With Quote Quick reply to this message
Old 10-31-2017, 02:59 PM   #4 (permalink)
Would you like to elaborate?
TxMike64 is offline   Reply With Quote Quick reply to this message
Old 10-31-2017, 04:19 PM   #5 (permalink)
Banned
It appears that there is a removable dash which remains a major short fall with the '33. That's a positive.
There appears to be no room behind the seats, and a bed that's too shallow to be of any value, so there is no storage. From what I've read the bed is only 9 inches deep, compared to about 17 for the real thing.
The body looks to be as low as the '33, so adding running boards and fenders may reduce the ground clearance so much that the truck is barely practical to drive.
Proper power windows would be a must. FFR has sold over 1000 '33 kits and the power window kit is still inadequate. With framed windows, a precise channel, 5/8 wide by 9/16 deep is needed for a flexible run channel and metal channels inside the door with the same dimensions and enough adjustment so the channels can be aligned the framed area. There also needs to be a 1 inch flange for a sill weatherstrip, like the one sold by Hagan. Without that, water will pour into the door. My '37 fiberglass body came with nothing but a hollow frame area and no channels inside the door. I filled the frame area with bondo glass to create a precise channel. I made my own aluminum channels to fit inside the door, that were secured to the inner door skin, with adjustable threaded rods. You have to figure out how to mount the power window motor and align the window lift, with the window's travel. After the window is operating properly, you can bond a 1" aluminum channel to the door, for the outer sill weatherstrip. It has to held at just the right distance from the window, along it's entire length. I spent about 80 hours per door to get the windows working. There were times when I considered having non-operable windows, glued into place.
I wouldn't use a curved glass windshield in a truck. Custom made curved glass is expensive and if the source dries up, you're in trouble. I also prefer a rubber gasket around the edge of the glass. It makes installation and replacement much easier. Flat laminated safety glass can be cut by a number of sources and it's far less expensive.
Glass Pro Supplies, Universal Moulding
daveS53 is offline   Reply With Quote Quick reply to this message
Old 10-31-2017, 09:12 PM   #6 (permalink)
I like the year, that it is a pickup, otherwise don't get me started on what could have been done better. Not going to go there.
oh btw, the door handles are backwards......really! come on FFR you couldn't get that right....geez!
Vman7 is offline   Reply With Quote Quick reply to this message
Old 11-01-2017, 06:01 PM   #7 (permalink)
andreast's Avatar
All doable!!!
andreast is offline   Reply With Quote Quick reply to this message
Old 11-01-2017, 10:56 PM   #8 (permalink)
When you go to the page that tells you what you get in the kit it says you get a trunk with liner and a pair of black bucket seats, I thought there was a bench seat.
FFR 6760 Mk 3.1 Fortes Dart 427, TKO 600, 3.55 3 Link Solid Axle
BigUgly is offline   Reply With Quote Quick reply to this message
Old 11-01-2017, 11:37 PM   #9 (permalink)
Bench seats in either leather or vinyl are optional with pricing yet to be determined.
JKleiner is online now   Reply With Quote Quick reply to this message
Old 11-02-2017, 08:44 AM   #10 (permalink)
j33ptj's Avatar
Raised the truck bed somewhat...
Seems that must be relatively easy to do....
Old 11-03-2017, 07:18 PM   #11 (permalink)
Jeff, Is there a list of options somewhere that I missed, or did someone at FFR tell you about the bench seat being an option. I'm hoping there are some fenders available, one, because I like fenders and two, because I believe I won't be able to register it in my state unless it has fenders. Thanks
BigUgly
Old 11-03-2017, 07:51 PM   #12 (permalink)
Administrator
David Hodgkins's Avatar
Roll up windows, bench seat and full fenders will be available options.
WIS89 and andreast thanked this.
David Hodgkins, AKA CNGreen
FFR 5369 Pin Drive, IRS, Trigos, Torsen, Wilwoods, FMS
Delivered 4/23/06.
. Plates! 1/2010 BatCave! 1/2012.
Featured Roadster, 2012 and 2013 Huntington Beach Cruise-In
David Hodgkins is offline   Reply With Quote Quick reply to this message
Old 11-03-2017, 10:00 PM   #13 (permalink)
Thanks for that info David. I was hoping the next vehicle released by FFR was a 4 seater so that my wife and I could take our two grandkids along for rides with us. At least with a bench seat I could take the two grandkids in the truck.
BigUgly
Insurance
» Premium Vendor Showcase
» Recent Discussions
J. H. Cobra Build Thread ( 1 2 3 4 5 )
03-08-2019 09:42 PM
Last post by jhargrove
Today 07:51 PM
145 Replies, 5,779 Views
Mark II
07-17-2019 05:08 AM
Last post by [email protected]
Today 07:19 PM
18 Replies, 379 Views
Strange but true
Yesterday 03:59 PM
by USMC
Last post by Derald Rice
Today 07:15 PM
6 Replies, 112 Views
Rear discs vs drums
07-17-2019 11:35 PM
Last post by NiceGuyEddie
Today 06:56 PM
8 Replies, 209 Views
Northwest Club Cobra...
03-08-2019 06:23 PM
by bsnyder
Last post by bsnyder
Today 06:38 PM
5 Replies, 478 Views
‘95 4.6L intake manifolds
06-27-2019 08:31 PM
by MikeG
Last post by TxMike64
Today 05:49 PM
3 Replies, 132 Views
Uber Fleet Business Ideas
Today 05:34 PM
by moresa3
Last post by moresa3
Today 05:34 PM
0 Replies, 12 Views
GTM Gen1, #105 Fires Up! ( 1 2 3 4 5 ... Last Page)
12-14-2012 05:42 PM
Last post by 00SS_M6LS1
Today 05:32 PM
621 Replies, 58,597 Views
2020 Mid-Engine Vette
Today 10:59 AM
Last post by Real time recon
Today 05:20 PM
3 Replies, 77 Views
Surfdog57's Gen 3 (#12)... ( 1 2 3 4 5 ... Last Page)
06-05-2015 08:36 PM
Last post by SurfDog57
Today 04:59 PM
403 Replies, 38,940 Views
so what did you do to... ( 1 2 3 4 5 ... Last Page)
12-12-2010 05:53 AM
Last post by egchewy
Today 03:17 PM
2 Replies, 200,473 Views
how old do you have to... ( 1 2 3 )
09-10-2010 09:33 PM
Last post by crash
Today 02:54 PM
63 Replies, 3,719 Views
Creaking sound from toll...
Today 07:47 AM
Last post by Boat737
Today 02:29 PM
4 Replies, 101 Views
2015 Donor Mk4 Roadster... ( 1 2 3 4 5 ... Last Page)
02-11-2019 03:22 AM
by IsaacW
Last post by IsaacW
Today 05:39 AM
264 Replies, 7,795 Views
Hello from LA
07-15-2019 06:27 AM
Last post by David Hodgkins
Today 05:25 AM
3 Replies, 52 Views
Headers, Sidepipes,...
04-25-2019 10:58 PM
Last post by chrisarella
Today 04:44 AM
6 Replies, 834 Views
Road trip to the Cave
Yesterday 02:37 PM
Last post by silver_pilate
Today 04:39 AM
3 Replies, 148 Views
Hello to all
07-15-2019 11:09 AM
Last post by gtaroger
Today 03:50 AM
1 Replies, 32 Views
Apex Predator
07-11-2019 02:34 AM
Today 03:48 AM
3 Replies, 82 Views
Alignment Tool
07-17-2019 04:43 PM
by dwleo
Last post by emac
Today 02:44 AM
4 Replies, 148 Views
Roadster Forum
4.6L Roadsters
Big Block Roadsters
Non-Ford Powered Roadsters
GTM Forum
GTM Classifieds
GTM FAQ
'33 Hot Rod Forum
Hot Rod Classifieds
Challenge Cars
Road Racing
Autocross / Pro Solo
Drag Racing
Free Photo Hosting
Tires / Wheels
Tops & Tonneaus
Upholstery
Gallery
Audio / Electronics
Car Care
Insurance / Registration
Brakes / Suspension
Ford Big Block Tech
Ford Small Block Tech
Forced Induction / NOS
Fuel Injection Tech
National Events
Southwest
Northwest
NorCal
SoCal
Southcentral
Midwest
Southeast
Northeast
Canada
Off Topic Discussions
Other Car Discussions
Smyth Performance G3F
Parts For Sale / Wanted
Donor Cars For Sale / Wanted
FFCars.com News
Forum Help / Test
