#1001 Build Thread - Page 3 - FFCars.com : Factory Five Racing Discussion Forum
LinkBack Thread Tools
Old 03-11-2019, 03:48 PM   #61 (permalink)
I "2nd" the suggestion to REALLY organize your inventory. I kept mine in all original boxes so as I am going through the build, I can reference the inventory sheet and original box to find the correct parts. If you take things out of the original boxes then all the stuff starts to look the same after a while. My two cents.
racso66 is offline   Reply With Quote Quick reply to this message
Old 03-11-2019, 05:41 PM   #62 (permalink)
andreast's Avatar
AND mark on the outside of the boxes all the part numbers that are contained within them. This way you wont search as much. As soon as I used that item I single lined struck it out that way I knew it was used and I could still read it in case.
andreast is online now   Reply With Quote Quick reply to this message
Old 05-14-2019, 04:10 AM   #63 (permalink)
Lizardskin
Finally finished the body panels. What a bunch of work. I put down POR15, POR15 Primer, Lizard Skin and then lizard skin topcoat. Looks pretty dope. Now to put imitation dynomat down and then start fitting the body.
I hope in a week or two I'll get the body, doors and trunk installed and be able to drive it to a SMOG referee station and do the brake and taillight inspection. I have my SPCN # so I'm very close....
fostia is offline   Reply With Quote Quick reply to this message
Old 05-30-2019, 05:28 PM   #64 (permalink)
Fiberglass panels
And tips or tricks on door and trunk fitment?
My drivers side door pops out about 1/8" in the lower corner. My passenger door does the opposite (which seems to be okay because I can possibly use filler) but popping out is a different story.
Has anyone carefully used a heat gun?
Also, not done with the trunk yet but it does not appear curved enough and the bottom corners will probably pop out somewhat. I've seen some people add braces but that looks like a lot of work? How had other people's fit?
Pictures of my driver's door: https://photos.google.com/u/1/album/...1cNZT8E88chsZP
I have my first kid coming next week (unless he comes early, I know the date as it's a scheduled c-sect) so I'm putting in a ton of hours late into the night in order to get the doors, trunk, waterfall, gauges and roadster windshield installed. After that, I can go to get my emissions and brake and taillight inspection and have a plate for this beast!
Old 05-31-2019, 12:35 PM   #65 (permalink)
andreast's Avatar
The front or back of the door, adjustment will be different dependent on which end. If its the front, I had the same thing, Tony at FFR suggested to use shims to push the top of my door out a 1/16". You will then need to adjust your striker pin to pull the door in a 1/16" further and you should be good. I outlined it on the FFR blog post #205: https://thefactoryfiveforum.com/show...oor#post359320
I would post a pic of where the shim is however this site doesn't cooperate. Basically you place the shim, in your case, above the carriage bolt that connects the bear claw latch to the door swing arm, it really does not take much to get it to work.
Old 05-31-2019, 01:10 PM   #66 (permalink)
My car had the same problem on the drivers door. There were 2 issues - first, check the door frame for flatness. Mine either warped during welding or was just poorly assembled but had almost 1 inch of twist in it. You can twist and or bend it as necessary which should alleviate the need to make a shim. Also, on my car the inner skin of the door contacts the door sill at the lower forward corner. I had to grind some material off the sill area to allow the door to fit flush on the outside.
sread is offline   Reply With Quote Quick reply to this message
Old 06-26-2019, 03:00 AM   #67 (permalink)
Brake and Lamp
After 2 years of having the kit, I finally have my California plate! Spent too much of my life in the DMV of late. They took all my paperwork and gave me a plate today. Anyone know when/how I should get my title?
It's been a trip getting there. When I left this morning to go to the brake and lamp inspection, I forgot to put my gas cap on. It fell through one of the access holes in the trunk and I ran over it. $130 part. Earlier, on my go-cart run, my brake light which was clamped on my rear sheet metal fell off and dragged along the ground. $55 part. So far, with about 25 miles on my car, $185 worth of parts have fallen off my car. I'm an bonehead.
Still have a laundry list of problems. My brakes need better bleeding and are squishy as hell, my engine is leaking oil in at least 3 places (302, front intake manifold, rear intake manifold, and POSSIBLY rear main seal), and the carb needs to be tuned by someone smarter than me badly.
But at least I'm road legal!
Old 06-26-2019, 03:10 PM   #68 (permalink)
I know the pain you went threw . I think it took me 8 or 9 months to get my plate. They will sent you your title in the mail.
Tom
cardifkid is offline   Reply With Quote Quick reply to this message
Insurance
» Premium Vendor Showcase
» Recent Discussions
GTM # 12 gets a new...
09-15-2019 11:38 PM
by sk7500
Last post by sk7500
Today 02:37 PM
5 Replies, 168 Views
Gumball Rally
09-16-2019 11:19 PM
by FFR1668
Last post by happybigblock
Today 02:08 PM
1 Replies, 52 Views
Single best upgrade you... ( 1 2 3 )
08-30-2019 11:06 PM
by FFR3247
Last post by jhargrove
Today 01:52 PM
69 Replies, 3,053 Views
9/28/19 Mohawk Trail/ VT...
Today 01:12 PM
Today 01:12 PM
0 Replies, 9 Views
Another quick paint...
Yesterday 01:04 AM
Last post by Greg_M
Today 01:12 PM
7 Replies, 241 Views
Wipers completed
09-13-2019 09:05 PM
Last post by gsides9
Today 12:02 PM
1 Replies, 61 Views
15” tires question again
09-16-2019 03:38 PM
by FFR3247
Last post by FFR3247
Today 10:44 AM
19 Replies, 489 Views
Tire Size
Today 01:34 AM
Last post by 50Rifleman
Today 01:34 AM
0 Replies, 19 Views
Hello Everyone
Today 01:29 AM
Today 01:29 AM
0 Replies, 17 Views
UP's Big Boy 4014 is...
04-25-2014 09:26 PM
Last post by Big Blocker
Today 12:34 AM
22 Replies, 1,569 Views
Looking for Hillabrandt...
Today 12:31 AM
by Azcats1
Last post by Azcats1
Today 12:31 AM
0 Replies, 20 Views
Clutch Cable adjustment...
09-16-2019 04:35 PM
Last post by teesalmon
Yesterday 11:23 PM
13 Replies, 353 Views
2020 London Cobra Show
09-11-2019 11:30 PM
by R Edgar
Last post by DWIGHT
Yesterday 10:06 PM
9 Replies, 187 Views
CNC Brakes
08-16-2019 03:03 AM
Last post by crash
Yesterday 09:00 PM
11 Replies, 428 Views
Drilling holes made easy
09-14-2019 02:04 PM
by Jaga
Last post by swwebb10
Yesterday 07:39 PM
7 Replies, 481 Views
trailer # 2 just released
09-16-2019 07:36 PM
Last post by Slord
Yesterday 06:50 PM
6 Replies, 205 Views
Drive shaft offset
09-16-2019 01:42 PM
Last post by Bob Cowan
Yesterday 03:11 PM
7 Replies, 309 Views
Self Portrait
08-28-2019 03:44 AM
Last post by Tom Veale
Yesterday 01:44 PM
2 Replies, 175 Views
Want to Display Your GTM...
09-17-2019 02:56 PM
Last post by RE63
Yesterday 01:37 PM
2 Replies, 68 Views
Ff5 daytona coupe
08-14-2019 03:02 PM
Last post by mustangwally
Yesterday 10:00 AM
5 Replies, 615 Views
