On a whim, I used the "Contact Us" at 3M and asked them which adhesive they thought would be best for attaching vinyl w/foam to an aluminum dashboard.
Here is there response, for those interested.
Here's a link to the adhesive he recommended.
http://multimedia.3m.com/mws/mediawebserver?mwsId=SSSSSu7zK1fslxtUnxm9mY_Zev7qe17zHvTSevTSeSSSSSS--
"Thank you for contacting 3M Automotive Aftermarket Division.
I would suggest trying 3M(TM) Super Trim Adhesive, part number 08090 for a
19 oz aerosol can. Do not use 3M(TM) Super 77 Spray Adhesive as this
product does not have sufficient temperature resistance for use inside a
hot car in the summer.
You mentioned that the vinyl is backed with foam. Without knowing what
kind of foam it is, I would suggest testing the product on the foam in a
small area to make sure the solvents in the adhesive do not break down the
foam. 3M(TM) Super Trim Adhesive is fine for most kinds of urethane foam
(this is most likely what you have) but will dissolve Styrofoam on contact.
Regards,
Scott S.
www.3m.com/automotive
1-877-666-2277
IMPORTANT NOTICE: This document is intended to provide basic information
for use in evaluating 3M product(s). The statements, technical information,
and recommendations contained in this document are general or summary in
nature, and believed to be current at the time the document was created.
3M, however,
does not represent that this information will be maintained as current or
updated, and this information should be used accordingly. This document is
not intended to replace the user’s careful evaluation of the 3M product(s)
for its particular use and intended application.
WITH RESPECT TO THE INFORMATION CONTAINED IN THIS DOCUMENT, 3M MAKES NO
WARRANTIES, EXPRESS OR IMPLIED, INCLUDING, BUT NOT LIMITED TO, ANY IMPLIED
WARRANTY OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE, OR OF
NON-INFRINGEMENT OF A THIRD PARTY’S INTELLECTUAL PROPERTY RIGHTS. 3M shall
not be liable for any loss or damages, whether direct, indirect, special,
incidental, or consequential (including, but not limited to, loss of
profits, revenue, business, opportunity, or goodwill) resulting from or in
any way related to the information contained in this document."
Regards,
Scott S.
1-877-666-2277
3M, however,
