Is PCV needed for SB100 registration? - FFCars.com : Factory Five Racing Discussion Forum
Go Back   FFCars.com : Factory Five Racing Discussion Forum > Regional Clubs / Events Discussions > NorCal Region
Old 02-16-2011, 04:26 PM   #1 (permalink)
In the home stretch....
John Card's Avatar
I'd prefer not to have to install a PCV valve, but If I have to I will. Were you able to register without it under SB100? I would think that it may vary depending on where the inspection is done, since the inspectors can have different opinions.
- The Wife
Build photos here:
http://www.flickr.com/photos/1452688...7624113485234/
John Card is offline   Reply With Quote
Old 02-16-2011, 04:38 PM   #2 (permalink)
FFR5452's Avatar
Yes. Also, if you have a breather on the other valve cover, it must vent into the air cleaner.
FFR5452 is offline   Reply With Quote
Old 02-16-2011, 04:44 PM   #3 (permalink)
FFR Craftsman
CobraSnake7's Avatar
Icon18 Sb100
John: When I got my SB100 number, DMV didn't care what I had. All they wanted was the MSO, some receipts (never give them ALL yours), and lots of money. I had my receipts with me, but I only showed them the one for the kit, the tires and wheels, and my engine. The more you show them, the more graft, er tax they suck out of you. When I had my car inspected, I had no windshield wipers, no smog junk, etc. Some places differ, so good luck. Contact Ray on the forum if you want to know more. Or, ask me more questions if you need to. One more thing. I registered my MKIII as a 1965 Cobra replica, and not by the engine year. That is, or was, your choice when getting it inspected at BAR. That way I didn't have to have any smog junk on it. I am not sure if you can still get away with that, or not. HTH, Larry
FFR5505 MKIII Del 6/26/06 Non donor build.First legal drive in primer 1-2-07.429SCJ,4bolt mains,CompCam.585 lift,roller tip rockers,3/8 pushrods,KB pistons,etc.850Barry Grant Mighty Demon DP, ported Torker II intake, Tremic600, 9"Currie with 31 spline axles w/3.00 TrueTrac,3 link,15"Trigo 5 pin,Eagle GTII 235/295,Koni's on all 4, electric water pump,SC dash with Autometer vintage guages,FFR front lower control arms,17 gal alum gas tank,many other options. Painted by me @8-25-07,1998 Rolls Royce Royal Blue Pearl,with white pearl stripes.
CobraSnake7 is offline   Reply With Quote
Old 02-16-2011, 08:21 PM   #4 (permalink)
The Greek
cobrathegreat's Avatar
John, as Jim said, yes you do.
First Start 2/7/08
cobrathegreat is offline   Reply With Quote
Old 02-16-2011, 11:44 PM   #5 (permalink)
ezglider's Avatar
It was the only thing they seemed to check for on mine.
MK III/4.6L DOHC/AOD
ezglider is offline   Reply With Quote
Old 02-18-2011, 03:09 AM   #6 (permalink)
Pcv
Like was stated above, you need the pcv valve and if your other valve cover has a breather it must be vented to the air cleaner with the CORRECT smog emissions type hose. Put the damn things on there, get it inspected, then toss them in the trash. Don't give the BAR any reason to question your build. Smile, agree with them, get your sticker and get out.
Rob
Roadster M3 delivered 10/12/07, first start 2/7/09, go-cart 2/21/09, to paint 8/20/09, back from paint 12/03/09, and finally 3/29/10 licensed and tagged!!! Pin drive, IRS, Trigos, cobra GT brakes, 351W/400HP, T5z. If the car is as fast as I am burning through cash, what a ride!! First one was such a hoot, now building a Type 65 Coupe.
robanno is offline   Reply With Quote
Old 02-18-2011, 05:29 PM   #7 (permalink)
John Card's Avatar
I agree, but I really don't want to drill a hole in my carbon airbox for a breather line if I don't have to - especially if I don't need it later on. I guess I'll see what happens.
- The Wife
Build photos here:
Old 02-18-2011, 06:20 PM   #8 (permalink)
68GT500MAN's Avatar
John, If you are having the inspection done here at the Fresno BAR station, you WILL have to have a PVC valve. I have registered both a roadster and coupe and the ref wanted a PVC valve and the proper (fuel) hose. Neither car had a hose from the otjher breather to the air cleaner, but I have read here that other stations are now requiring one.
FFR 5197 Mark II Roadster 427w Complete 6/28/2006
FFR 0058 33 Hot Rod BOSS 347 w/dual carbs
1968 GT500 4-speed, low miles SOLD 11/11/11
1965 Mustang GT Fastback
2012 BOSS 302
68GT500MAN is offline   Reply With Quote
Old 03-10-2011, 04:52 AM   #9 (permalink)
SJDave's Avatar
Hey John,
Just did mine this week in San Jose at Evergreen college BAR; they did check for pcv from one valve cover to base of carburator and vent hose from other valve cover to base of air cleaner. Looked for "fuel rated hose". That was all they checked.
I registered mine as a 1965 Roadster Body style; since the Levy STage 4 had no serial number on the engine block I got (which they asked for to look it up in a book to see what year the engine block was) I told them it was a seasoned 302 block also from a 1965, so that's what they wrote down. Figured it couldn't hurt to have both 1965.
Took about 15 minutes to complete, went really smooth.
SJDave is offline   Reply With Quote
Old 03-15-2011, 03:05 AM   #10 (permalink)
Dave,
Did they ask for a serial number or a block casting number? I guess they didn't know that Ford 302's did not come out until 1968. It shouldn't have mattered anyway.
Steve1979 is offline   Reply With Quote
Old 03-16-2011, 01:12 PM   #11 (permalink)
SJDave's Avatar
Originally Posted by Steve1979 View Post
Dave,
Serial Number; they were looking on the flat surface just behind the intake manifold. I didn't know it was 1968 either...DOP!
Old 03-16-2011, 03:50 PM   #12 (permalink)
FFR5452's Avatar
New rules at the BAR. PCV valve and a breather that vents to the air cleaner using the properly designated hose are both required (no matter what year the engine was manufactured) for some reason.
Don't buck it! Just get an old air cleaner and plumb a breather hose to the base. After youpass inspection, put the original parts back on and enjoy.
Old 03-16-2011, 04:01 PM   #13 (permalink)
Erik Hansen- 33Machine
ehansen007's Avatar
Will it also work if you have it vented to the base of the carb or does it have to go into the air cleaner? Seems they both go the same spot which is back into the engine. My Holley Street avenger has PCV's on both sides of the base.
Erik Hansen
Car no. 240
www.thefactoryfiveforum.com
Old 03-16-2011, 08:27 PM   #14 (permalink)
FFR Craftsman
289FIA_Cobra's Avatar
The Ford Racing air cleaner has a hole and fitting for this purpose. Got the breather with the nozzle and hooked it in. Had a PCV valve installed and going back to the Carb. BAR had no problems with this setup.
Just "borrow" a set from someone temporarily. If I wasn't so far away, I'd just drop off the pieces to you so you can get past BAR inspection; my engine is on a dolly waiting for a clutch that won't arrive until next week.
Project: SNKVNNM
289FIA_Cobra is offline   Reply With Quote
Old 03-23-2011, 04:17 AM   #15 (permalink)
SJDave's Avatar
Sent my parts to John today.
Herman, I sent my parts to John today....never going to use them again as I am getting some of those fancy new Ford Racing Valve covers you showed me last week!!
Dave
Old 03-23-2011, 04:59 PM   #16 (permalink)
SJDave's Avatar
The vacuum port on the other side is for Vacuum Brake booster set up if you have it. The reason one hose goes inside the air cleaner box is to "draw clean air" into the crankcase to purge the build up blow by gases through the PCV valve to the carburator base, which is relatively high vacuum. I suppose it would work without the vent as blowby gases allow flow to the carburator base, but you would not get the volume of air moving through as you would with the vent to the air cleaner. Blowby gases would then contaminate the oil more.
Old 03-23-2011, 06:52 PM   #17 (permalink)
anyone know what they look at on a EFI car ????????????????????
FFR#6983 ordered 4-15-09 delivered 05-21-09, 96 explorer 302 mustang 5spd, 94 must gt 3:27L rearend
freddiehebert is online now   Reply With Quote
