mk3 roadracing tires - FFCars.com : Factory Five Racing Discussion Forum
Go Back   FFCars.com : Factory Five Racing Discussion Forum > Competition > Road Racing Discussions
Old 09-12-2009, 11:59 PM   #1 (permalink)
vnvjeff's Avatar
Hello. Im new at this, I have mk3 stock 5.0 ffr tube a arms up front 3 link coil overs ,bfg 235 60 15 front 295 50 15 rear. Bilsteen shocks after couple laps tires rub scares the heck out of me. Run 30 psi all way around yesterday at nelson ledges. Will sway bars stop this? From body roll or will i need different rims? 17 inch also i have 4 lug .At mid ohio run posted on u tube under my spin you can hear the tires rub, but dont see marks under fender wells . On way home today drivers side front shock broke in half. Luckey no damage to body. I street car and on open track days as much as possable any help as whats best for me. Thank you Jeff B http://www.youtube.com/watch?v=IJQGnAddjRI
jeff
vnvjeff is offline   Reply With Quote
Old 09-13-2009, 01:16 AM   #2 (permalink)
rlogan's Avatar
Don't mean to be a pain, but reading that post makes me dizzy, a little punctuation goes a long way. Either sway bars/stiffer springs or some combination will remove most body roll, and yes...you might consider getting a set of dedicated 17x9 track wheels/tires. Tire selection is much better for 17" sizes.
Ryan Logan
Texas ST-2 #27
NASA TX Chief Instructor
rlogan is offline   Reply With Quote
Old 09-13-2009, 11:05 PM   #3 (permalink)
Mad Max Builder
johnmdanskin's Avatar
Do you guys run 17x9 all around or go for big rubber in back and live with not getting to rotate your tires?
thanks
john
johnmdanskin is offline   Reply With Quote
Old 09-13-2009, 11:22 PM   #4 (permalink)
cobraless's Avatar
275's all around works great. all 4 being the same size means as they wear you can rotate. the really big 315's on the rear are for show only.
I run 315's on the street but for racing I use 275's.
The 15" tires are junk on the track.....way too much side wall flex. (something you DONT need with these short wheelbase high hp cars)
Dave
No one ... has come up with a drug yet that can match the thrill of driving a race car.
It seems that I run out of driving talent before the cobra runs out of HP!
first start: http://www.youtube.com/watch?v=9s6cA...eature=related
1st time on track sorting it out
http://www.youtube.com/watch?v=ZlIgop1kEnM
cobraless is offline   Reply With Quote
Old 09-14-2009, 01:45 AM   #5 (permalink)
Mad Max Builder
Dave
Thanks Dave. What wheels are people using on track? As far as I can tell people are mostly buying 32 pound replica look wheels. FF5 halibrand weigh 20 pounds. Enkeis weigh 16 which is pretty good, but they are pricey (but not crazy pricey). I was surprised when tirerack came up with nothing at all.
Old 09-14-2009, 10:50 AM   #6 (permalink)
mhoward1's Avatar
Actually the A-tech (MB Motorsport brands) Competition weighs in at 20 lbs with the 17 X9.
They are strong and hold up well. Richard @ Northracecars.com sells them for a good price and he's a site supporter.
I also agree that a square setup (Same size all around) works well. These cars are well balanced and with a squared setup you can get just the right amount of rotation and also conserve a little bit by being able to rotate the tires to any position.
Marty Howard
FFR Challenge #43
2012 NASA SE Champion
2011 NASA SE Champion
Race Team
Become a fan of MH Motorsports
mhoward1 is offline   Reply With Quote
Old 09-16-2009, 04:01 PM   #7 (permalink)
vnvjeff's Avatar
Dave
Thanks for info. Can you be more precise 275x ? x 17 . Would be very helpful thank you jeff
jeff
Old 09-16-2009, 04:10 PM   #8 (permalink)
Chepsk8's Avatar
I keep my 15" for street only!
On the track, Khumo 710's, 275/40, the old spec racer tire. It's FANTASTIC!!! On dedicated track rims too. On the street, my 295/15's rub all the time. No issues.
Up front, I have VPM sway bar, helped a ton too.
Car is stable and responsive, but still comfy on the street.
If you do alot of high speed, front spoiler!!!
Chepsk8 is offline   Reply With Quote
Old 09-16-2009, 06:36 PM   #9 (permalink)
Master?
simpsoncobra25's Avatar
Dave
Not true I did alot of testing with both 275 and 315 on the rear of my roadster. The car is so much faster with the 315s on a 10.5 rim in the back. My car is a track only car and I have never driven it on the street. I have a couple thousand track miles on this set up and it is the best I have found. HTH vnvjeff
Todd S.
challenge kit, 4.6DOHC, Aviaid dry sump, Mezier electric water pump, power steering,ABS
Graduation post:
http://www.ffcars.com/forums/17-factory-five-roadsters/202014-graduation-f5r1005840sr.html
with the FFR 2008 MCSCC A-race champ; CHI region SCCA xp champ
2009 MCSCC A-race champ and Driver of the Year
my Youtube channel lots of in car race footage:
http://www.youtube.com/user/simpsoncobra25
simpsoncobra25 is offline   Reply With Quote
Old 09-17-2009, 07:15 AM   #10 (permalink)
Another option for 275 track tires is to buy used at fossport. They have the hoosier koni challenge dot radials in 275/40R17 for $90.00 each.
https://www.fossport.com/product_view.aspx?cat=9
John Aldrich is offline   Reply With Quote
Old 09-19-2009, 11:30 PM   #11 (permalink)
hohorodshop's Avatar
Kumho 710's are great. Currently running 245/17 front and 275/17 rear.
MKIII# 6064, 3.55-3 link, T&L 347, T5, 95 GT Donor; Start build 6-02-07; Graduated 7-18-08
hohorodshop is offline   Reply With Quote
