Novice needs guidance. - FFCars.com : Factory Five Racing Discussion Forum
Old 09-04-2006, 10:30 PM   #1 (permalink)
Swapping a comp cams hydraulic roller into a 514. I've removed the harmonic balancer, and right behind it is a counter weight on the crank shaft. Do I need a special tool to remove it? It looks like it will be difficult to get a universal puller to work.
Rob
514,Procharger F1R, Levy 5-link,TKO-600, Moser 9\"narrowed 4 in., TeamIII 17\", Ron Davis radiator
ROBH511 is offline
Old 09-05-2006, 03:46 AM   #2 (permalink)
Kiwiracer's Avatar
ttt
Mk II FFR # 3503, 2001 Fuel Injected 302, E-303 Cam, Ford 1.6 roller rockers, GT-40P heads, Rear coil over shocks, 3.55 Richmond gears
Kiwiracer is offline
Old 09-05-2006, 11:10 AM   #3 (permalink)
Not sure there is a speacial puller for that. May want to ask Gordon Levy or one of the other pro builders about this.
Tagged 10/24/06
Graduate 4-07
hind sight is offline
Old 09-05-2006, 11:55 AM   #4 (permalink)
Mike Forte's Avatar
Hi,
That balance sleeve just slips off as I recall. Then removing the timing chain is easy.
Mike Forte
Mike Forte
Forte's Parts Connection
40 Pearl Street
Framingham, Mass. 01702
mikeforte302@gmail.com
508 875 0016
www.fortesparts.com
Mike Forte is offline
Old 09-05-2006, 12:18 PM   #5 (permalink)
Not to hijack, but do you think a 514 with a blower on it will be enough power? [img]smile.gif[/img]
What HP are you expecting with that setup?
6243 is offline
Old 09-05-2006, 08:22 PM   #6 (permalink)
gbranham,
Plan to run 6-8lbs of boost and hope for 700Hp. Changing the cam will probably hurt the power quest.
Mike,
Thanks. It didn't budge when I pulled by hand but I'll get more aggressive with it.
Rob
ROBH511 is offline
Old 09-06-2006, 08:47 PM   #7 (permalink)
Wow, that's an insane amount of power! Do you plan on drag racing your car, or just cruising? I gotta know what compells someone to need 700HP.
6243 is offline
