Deep lip cobra lll wheels and 87 spindles - FFCars.com : Factory Five Racing Discussion Forum
Old 09-03-2006, 12:22 AM   #1 (permalink)
Red face
can you mount this combo along with lincoln m7 rotors with out doing any mods????
MKIII,427w,TKO 600,P/S,Hydroboost,4wheel cobra disc,P/C Narrowed Mach1 rear,Moser axels,3Link,I Squared
Take your time and slice a lime!! :-)
BART A is offline
Old 09-03-2006, 05:05 AM   #2 (permalink)
The Student's Avatar
Well I guess no body has the answer you are looking for. I would sugest getting intoutch with Richard Oben or Gordon Levy (they are both in the "ask an expert" sections of this forum). I am confident that Richard Oben could answer your question and probably Gordon too.
MkII, CHP 331 w/AFR 185\'s, Mass Flo, TKO, IRS, \"deep dish\" Team III\'s.
The Student is offline
Old 09-03-2006, 05:08 AM   #3 (permalink)
I forgot to mention, but unless you are REALLY on a budget then you are better off using some SN95 or newer spindles and brakes. That way you get more brake options and a litte better geometry for suspension and steering (94-95 mustang spindles are best for avoiding bump-steer problems).
Old 09-03-2006, 11:58 AM   #4 (permalink)
THANKS TREVOR I guess I will change out my spindles this week.Im off to a bad start!!!!!!!!!!
BART A is offline
Old 09-03-2006, 02:59 PM   #5 (permalink)
Cannonball Cobra's Avatar
Bart:
I currently have a Fox setup and am able to use the CobraIII deep lip on the same setup you have.
I originally bought the Medium lip for the fronts and was not able to mount them because of interference with the upper ball joint.
With the deep lip I have about 1/4 inch of clearance.The advise to go to SN95 is good ,for all the mentioned benefits plus ,if you want to use the Hallibrand "Spinners"it makes it a snap.With the Fox setup you will have to do some machining to make them work,there isn't enough room around the dust cap area unless you use spacers and use longer wheel studs.
This topic was discussed a few weeks back ,you may want to look it up.
HTH,
Paul
Lexus Blue/silver stripes,351W,GT40EFI,3.55TL IRS,TKO mid-shift,F&R sway bars,carbon fiber dash w/ autometers,first start 12/24/06! Levy's KONIS all around,Graduated 2/15/09,still stuff to do
Cannonball Cobra is offline
