FFR Heater Duct Setup? - FFCars.com : Factory Five Racing Discussion Forum
Old 09-04-2006, 05:47 PM   #1 (permalink)
What is the best way to route the hose to both sides?
Can it be successfully tee'd into Cobra Earl's duct work?
TIA,
Martin
FFR 4799 Donor 302/EFI, Flaming River Steering, IFS/3-link, 3.55/8.8, Halibrands, Autometer/VDO gauges. Started 01-04 - Finished 06-07. YEEHAH!
marting is offline
Old 09-04-2006, 09:01 PM   #2 (permalink)
I bought some 2" flexible duct hose and some nice round air vents. I mounted them under the dash on driver and pass side. They are the type that swivel 360 degrees and you can aim them into your lap or onto your feet. Feels real nice in the winter. If the FFR heater only has one outlet, just buy a tee and run both lines off of it. I know some people have linked them to the fresh air vents but unless you still put some vents that allow you to aim the air, I don't think it would work as well.
Raul
FFR4356, 351W stroked to 393, Carb,Tremec TKO midshift,IRS, PinDrive,3.55s,FR 15:1,PBR Brakes,Team III Wheels - Paint by NCPainter
Just_Bitten is offline
Old 09-05-2006, 03:38 AM   #3 (permalink)
sflaten's Avatar
look at north race cars site (on fourum) as they have a plenum that goes under the dash. I think this would make the install very clean if you used the trtap door on the heater dor defrost and the two pieces of tubing for heat to each side. That's if I could do it over.
FFR4429K 302 EFI +.030, E303, Cobra Intake, 75mm tb and MAF, 4x4 pipes, 3.55 gears, 5 lug with all disk brakes.
sflaten is offline
Old 09-05-2006, 10:06 AM   #4 (permalink)
Thanks guys.
Martin
marting is offline
