Ford Performance Parts Crate Engine - FFCars.com : Factory Five Racing Discussion Forum
Old 07-31-2006, 10:13 PM   #1 (permalink)
Jetheft's Avatar
I am planning on using a Ford Performance Parts M-607-XE3M 345h.p. motor. Any issues going with the stock 5.0 fuel injection, oil pan etc? Looking for words of wisdom from someone that has already been down this road.
Beef
Joel "Beef" Heft LIFE'S JOURNEY is not to arrive at the grave safely, in a well preserved body, but rather to skid in sideways, totally worn out, shouting "Holy Shi*, what a ride!"
Jetheft is online now
Old 07-31-2006, 10:19 PM   #2 (permalink)
section 8
bigger pump and bigger injectors, I'm sure there's more, others will help soon Bob
Bob Taylor is offline
Old 07-31-2006, 10:39 PM   #3 (permalink)
Mustang Medic's Avatar
Beef,
The stock oil pan and water pump work fine. The stock intake manifold and injectors are too small for this combo. You might want to use 24# injectors and an Eldebrock intake (these are nicely finished-made in USA). The Ford Racing "Cobra" intake is made in China, now!!!
Also use a 65MM throttle body-BBK, Eldebrock and Holley make these.
Best regards,
Chuck
FFR5106K 5.0L,GT40P,E303,GT40 INTAKE, Cobra T5-Graduated 4/21/06 2005 Mustang Legend Lime Paint by SRP-Sold 4/8/07
Mustang Medic is offline
Old 08-01-2006, 01:36 AM   #4 (permalink)
The branch of chemistry that deals with fermentation processes, as in brewing.
zymurgy's Avatar
The stock oil pan has absolutely no baffling. You may want to change this out if you're into "spirited" driving.
FFR5325 - Non-donor build,396hp 302 crate, T-5Z, 8.8 3.55 rear, 3-link
\"Back in Black\" On the road and legal 8/10/06. SOLD 6/26/08.
zymurgy is offline
Old 08-02-2006, 12:20 AM   #5 (permalink)
Another Kevin's Avatar
I have the same crate engine and am planning to go with Mass-Flo with 24Lb injectors. I think the stock fuel lines will be good, but am planning to get a bigger fuel pump.
MkIII, 345 HP crate 302, Mass-Flo EFI, 3-link, hydraboost, T-5Z, 3.55, non-donor
Another Kevin is offline
Old 08-02-2006, 03:02 AM   #6 (permalink)
Jetheft's Avatar
Thanks guys.
I am just trying to get good info and all the correct parts lined up and payed for.
Appreciate all your inputs and help!
Beef
