will bbk headers work - FFCars.com : Factory Five Racing Discussion Forum
Old 10-30-2006, 10:45 AM   #1 (permalink)
FFR Master Builder
jammin1's Avatar
i have set of bbk headers and want to know if anyone has used them in a cobra. i have done searches and they have not come up in any searches. this is going ona 5.0 engine in a MKII
jammin1 is offline
Old 10-30-2006, 10:59 AM   #2 (permalink)
I have them in my MKII with the 5.0 engine. They are a good choice.
cardinalflyer is offline
Old 10-30-2006, 11:07 AM   #3 (permalink)
Charlie M's Avatar
I have them on my 5.0 in a mkII. One tube was a little close to the driver's side footbox. I pushed the footbox wall in about 1/4" and they fit fine.
Charlie
FFR 3323 - Sold!
New Projects:
- SBF Powered "Monster" Miata
- Scratch-built GT40 MkI
Charlie M is offline
Old 10-30-2006, 11:10 AM   #4 (permalink)
MKII with a 5.0. I don't have the body on yet but they seem to fit just fine so far.
MK II, 5.0 EFI, 3-link, Brodix heads. Picked up Aug \'04, completion TBD.
gumbo al is offline
Old 10-30-2006, 05:22 PM   #5 (permalink)
Cannonball Cobra's Avatar
I had the BBK headers, fits OK on a 5.0, won't work with 351W, no clearance on the driver's side.
Paul M.
Lexus Blue/silver stripes,351W,GT40EFI,3.55TL IRS,TKO mid-shift,F&R sway bars,carbon fiber dash w/ autometers,first start 12/24/06! Levy's KONIS all around,Graduated 2/15/09,still stuff to do
Cannonball Cobra is offline
Old 10-30-2006, 05:48 PM   #6 (permalink)
bill32's Avatar
#2 cylinder tube has clearance issues with the 45 degree spark plug boots, so use spark plug wire set with 90 degree plug boots. On the Mark II, you will need to dimple the driver's footbox a little as cylinder #8 tube hits it.
There are Ford Motorsport headers that do fit better and dont' have above problems, but they are expensive (about $350).
Roadster #3358K, Spec Racer #2889 SP, Daytona Sypder GT #4569GT (#8 of 39).
bill32 is offline
Old 10-30-2006, 05:51 PM   #7 (permalink)
2savage's Avatar
If you are talking about unequal length then you may get some interference on the driver side on #8 cylinder where it just kisses the aluminum. I fixed this by inserting a piece of 3/4 chassis square tube lower down to spring the aluminum away from the exhaust.
2savage is offline
Old 10-30-2006, 05:58 PM   #8 (permalink)
sgspeed's Avatar
I have the equal length bbk's and there is a slight interferance with the drivers side engine mount. I just dimpled the header a little. Comes close to the footbox, but does not touch.
Shep
Qualified old guy. Dad of Willspeed. 89 Donor.Mk. III IRS, 302,equal length headers, 65 mm throttle body 77 mm MAF,Kenne Bell Supercharger,Levy bump steer kit & Koni Shocks.Finish line nudge bars, Cobra Earl Trunk, FFMetal batbox and footbox,APE hardtop, Vintage A/C, Lucas windscreen washer. Detailed, painted, graduated. Driving, adding stuff.
sgspeed is offline
Old 10-30-2006, 06:49 PM   #9 (permalink)
Big-Foot's Avatar
Same headers here except I modified the motor mount (Energy Suspension brand) by cuttnig off the top of the clam-shell where the bolt goes through and welded it back together.
Also - I wrap my headers with DEI header tape and use 90 degree boots.
Regards - Randy Orbs
Racecar Fab/Support
69 Camaro SS 4spd
Big-Foot is offline
Old 10-30-2006, 07:26 PM   #10 (permalink)
Don't think it will be an issue for you. I'm using BBK equal length headers in my MK III.
I modified my mounts the same as Randy, above, and was able to undertake a MASSIVE passenger footbox expansion with no interference. You can check out the pics in this thread:
http://www.ffcars.com/ubb/ultimatebb...25.html#000000
-SB
SportyBry is offline
Old 10-31-2006, 05:35 PM   #11 (permalink)
Mustang Medic's Avatar
BBKS won't work with GT40P heads. All but #2 plug clears.
Best regards,
Chuck
FFR5106K 5.0L,GT40P,E303,GT40 INTAKE, Cobra T5-Graduated 4/21/06 2005 Mustang Legend Lime Paint by SRP-Sold 4/8/07
Mustang Medic is offline
