Brake cooling hose - FFCars.com : Factory Five Racing Discussion Forum
Old 01-25-2006, 02:25 PM   #1 (permalink)
We are also adding brake cooling ducts for the front disks and am looking for a source on high-temp 3" diameter hose. I've seen the double walled orange silicone stuff used but it's pricey.... has anyone ever used high-temp aluminum dryer hose with any success? We are also planning on running in-line marine blowers with these hoses to keep the brakes as cool as possible.
Chris
GATOR427SC is offline
Old 01-25-2006, 03:19 PM   #2 (permalink)
Administrator
Larry N. Johnson's Avatar
why high temp? Seems the air inside would be cool air.
Larry N. Johnson is offline
Old 01-25-2006, 03:25 PM   #3 (permalink)
FFCobra Captain
Dan Babb's Avatar
Some of the black plastic drain hose from home depot should work fine...the stuff they sell in the area where the pvc pipe is.
Do you really need blowers? The brakes would only heat up when your moving and you'll have air flowing through the hose just from moving.
My Current Car
FFR5857
Dan Babb is offline
Old 01-25-2006, 03:35 PM   #4 (permalink)
Big-Foot's Avatar
Chris
Chris - I've used the exact plan you have with the aluminum 3" hose and blowers and it worked great. The only caveat is that the aluminum hose is not very resilient when it comes to any sort of impact. It dents and then comes apart after a while. The high-temp silicone hose is the best but very pricey. You can get it from almost any racing supply house. Check with your local circle-track folks or check with Pegasus Racing online.
To Dan's point about the blowers.
If you check the nose of any Nextel Cup car that is setup to run at Martinsville You will find as many as 8 blowers for the front brakes alone. The blowers do help even when you're moving..
Regards - Randy Orbs
Racecar Fab/Support
69 Camaro SS 4spd
Big-Foot is offline
Old 01-25-2006, 03:35 PM   #5 (permalink)
Supermoderator
oldguy668's Avatar
You're building a car, for Pete's sake, and probably a nice one. Why the heck do you want plumbing parts from Home Cheapo? Go to Aircraft Spruce and get some SCAT ducting. Yes, it'll probably cost $25 for the front brakes, but it's made for the purpose.
Mark Twain
oldguy668 is online now
Old 01-25-2006, 05:20 PM   #6 (permalink)
Larry,
High temp due to it's proximity to the rotor which gets nice and toasty.
Joe,
The car is a dedicated track car so as long as it works, is not a safety issue and can last a dozen track day events per year then I'm good with that. I'll check out your link. Thanks.
The design will probably have the main hose feed the center of the rotor thru a mounted backing plate. We are also looking at adding a second hose to feed air right onto just the caliper to keep fluid temps down. Overkil? Probably, but the last thing I want on track is faded brakes.
Chris
Old 01-25-2006, 05:26 PM   #7 (permalink)
Administrator
Chris,
Got it, thanks.
LNJ
Old 01-25-2006, 05:29 PM   #8 (permalink)
jimgood's Avatar
Here are some sources I've used:
http://www.rfrraceparts.com/Shop/Cat...?CategoryID=32
http://www.blrmotorsports.com/supplies.htm
http://www.stockcarproducts.com/brkduct.htm
http://www.pitstopusa.com/searchresu...CategoryID=547
"Lotta people go through life doing things badly. Racing's important to men who do it well. When you're racing, it's life. Anything that happens before or after is just waiting." - 1971, Steve McQueen, Le Mans
jimgood is offline
Old 01-25-2006, 07:11 PM   #9 (permalink)
Rapscallion
Roscoe's Avatar
You don't need high temp hose. The disks are never close enough to influence the material of your ductwork. I used shop vacuum hose several years ago and it's fine. A fraction of the cost of "racing hose."
\"Crisis occurs when women and cattle get excited\"...James Thurber
Roscoe is offline
