Fire Snake.....I ran into the same delema. I saw in the book that the rear spring perch shows one way,,but if you do it that way the perches do not line up with the frame rail. I put the perch tward the rear, basically on the otherside of the vertical pc of steel. At that location it lined up snug. I am past that stage now and the difference is only about 1/8th inch. The perch was bolted in, the horizontal (2) and the 2 vertical(drilled). Make sure you use washers. the inside ones are trickey. oh by the way ,,I am taking it for granted you were using the solid axle,,go luck,,steve
If you haven\'t seen the future yet, than you haven\'t driven fast enough....
99 f350 dually 76 Cosworth Vega 00 SVT contour
