unlevel engine - FFCars.com : Factory Five Racing Discussion Forum
Old 09-01-2006, 07:50 PM   #1 (permalink)
pkunda's Avatar
It has been brought to my attention that my motor is sitting unlevel. It is off my almost an inch (on its sides). Anyone have any experience with this? What kind of problems wiill this create?
Preston
Miranda: I love you and miss you, Daddy.
FFR: DSS 331, IRS, lots of goodies. Painted Princess Pink for my little girl. www.mirandafaith.com
2002 Hot Rod Magazine Camaro, 7 of 36, 380 HP.
pkunda is offline
Old 09-01-2006, 08:15 PM   #2 (permalink)
RJG
Make sure the pins are in the holes on the frame for the motor mounts. If one of these don't seat, the engine will be un level side to side.
Everyone should learn to drive a Stick. Automatic transmissions allow to many people to drive that should never be behind the wheel!
RJG is offline
Old 09-01-2006, 08:54 PM   #3 (permalink)
Radar Pete's Avatar
One of the more immediate problems that I can think of will be that your side pipes might be waay off. Pete
FMS 302,GT40 Alum heads,Cobra intake,70mm MAS/TB,24lb injtrs, 8.8w/3.55,WC T5,Srt Perf Seats, donor build except eng/tranny, Hummer Yellow w/o stripes
Radar Pete is offline
Old 09-01-2006, 09:02 PM   #4 (permalink)
Supermoderator
oldguy668's Avatar
Sidepipe alignment is more important. If you have FFR headers and you like the way the pipes fit, try not to think about the engine. If you don't have your body on yet, don't worry about the engine until you adjust the pipes.
Mark Twain
oldguy668 is online now
Old 09-01-2006, 09:20 PM   #5 (permalink)
Yup: I didnt find that out untill I mounted both side pipes.. The motor is just sitting in the mount and the bolts just started (didnt want to lose them).So I giggled the motor so both sides are equal . I think the tranny looks more off then the motor does It sort of leans to the driver side... I guess that is the fine tuning you go through....steve
If you haven\'t seen the future yet, than you haven\'t driven fast enough....
99 f350 dually
76 Cosworth Vega
00 SVT contour
STEVO is offline
Old 09-01-2006, 09:25 PM   #6 (permalink)
Mumblerone's Avatar
I had the aluminum 'ear' on the transmission hitting on the E-brake bracket. It has been removed (the ear). You also get an indication on how the motor sets by the way the transmission mount is parallel with the ground. [img]graemlins/silver.gif[/img]
FFR #4971 5.0 HO EFI (.040"), T-5z, FFR heater/wipers, heated seats, KONI coil-overs F/R, and a few other things. Fun work; always in progress.
WHEN YOU TURN ON YOUR CAR...DOES IT RETURN THE FAVOR?
Mumblerone is offline
Old 09-01-2006, 09:36 PM   #7 (permalink)
pkunda's Avatar
Aligning the sidepipes is what brought it to our attention. They're significantly off. Your comments and suggestions are welcomed.
pkunda is offline
Old 09-01-2006, 10:17 PM   #8 (permalink)
Supermoderator
oldguy668's Avatar
You have to be more specific than "significantly off". What exactly do you mean?
Mark Twain
Old 09-01-2006, 11:27 PM   #9 (permalink)
pkunda's Avatar
From the body shop:
Drivers chassis.. 6.5 inches at the bottom
drivers header 13.75 inches at the top flange
passenger header 13.00 inches at the top flange
passenger chassis 6.5 inches at the bottom bar
pkunda is offline
Old 09-02-2006, 12:09 AM   #10 (permalink)
Supermoderator
oldguy668's Avatar
So you need to roll the engine a smidgen in the mounts. Really easier than it sounds, since there's alot of slop around the locator dowels and bolt holes on the mount pads. You need 3/8" (half of 3/4") to make the pipes perfect, and that's maybe 1 or 2 degrees of engine rotation. You're close, just loosen up the 2 bolts on the mount pads and use a bar.
Mark Twain
Old 09-02-2006, 01:26 PM   #11 (permalink)
NCPainter's Avatar
Joe,,, Great idea. I think in this case it's a little of both. headers may be bent a little wrong and motor may need to be tweaked just a little. I'm sure we can get 3/8" in there somewhere.
NCP
www.worshiponeinc.com
NCPainter is offline
Old 09-02-2006, 03:31 PM   #12 (permalink)
Big-Foot's Avatar
The other thing you can do if you need just a touch more movement is to put a couple of washers between the engine block and motor mounts.
Regards - Randy Orbs
Racecar Fab/Support
69 Camaro SS 4spd
Big-Foot is offline
