Almost done with carpeting... and a queston (pic) - FFCars.com : Factory Five Racing Discussion Forum
Old 08-01-2006, 06:11 AM   #1 (permalink)
FFR Craftsman
289FIA_Cobra's Avatar
For the last week I've put down a panel a day of either insulation or carpet or both. I'm down to just one main carpet section: driver/passenger side tranny panels with verticle tunnel bridging both pieces (under the dash).
What I have left after that are the under sides of the doors. I did not align the aluminum under the doors when I had the body on but given that SRP will mount and align the body on the chassis soon, I suspect I must wait until the body is on so I can align the aluminum and rivet it down before I can carpet over it. Is that correct or should I rivet it down now???
Project: SNKVNNM
289FIA_Cobra is offline
Old 08-01-2006, 06:19 AM   #2 (permalink)
Paul Westerbeck's Avatar
Hold off on the under door aluminum until you have the body on. Leave that piece of carpet off also.
MkIII, 4.6 DOHC, Aluminum block with forged internals, Ported heads, comp 106-400 cams, DSS level 5 axles, Champ Pan, IRS, 30 Series Konis, VPM Sway Bars, Cobra brakes, ABS, Hydroboost, PS and Paint Jeff Miller
Paul Westerbeck is offline
Old 08-01-2006, 11:04 AM   #3 (permalink)
Cobra Crazy
Lowcountry's Avatar
I am a little lost. On the MK III the v-shaped panel under the door follows the contour of the side impact brace. Since you can't adjust the brace because it's part of the frame, what are you aligning. If the aluminum follows the bracing then it should fit and can't be adjusted. I must be missing something. Help me out, I don't understand.
FFR# 4909 with Ford FE, SpeedPro forged pistons, Eagle H-beam Rods, Elderbrock Alumin Heads, Comp solid roller cam, Comp roller rockers, 750 CFM Mighty Demon on a 428 PI alumin intake, TKO 600, IRS and pin drive wheels.
Lowcountry is offline
Old 08-01-2006, 11:18 AM   #4 (permalink)
John Shumaker's Avatar
Low Country,
There's another piece that lies horizontally on top of the piece your talking about. It gets a weatherstripping on on the outside edge and seals against the body. hth
'02 GT donor, 4.6 sohc, Received #5488 on 5/29/06. 3-link, ps, pb, Roger's wire diet
John Shumaker is offline
Old 08-01-2006, 11:54 AM   #5 (permalink)
Cobra Crazy
Lowcountry's Avatar
Thanks, Now I understand.
Old 08-02-2006, 08:06 PM   #6 (permalink)
We're at the same stage, with the body going on this weekend (final assembly). Does anyone have a pic of this installation ?
lakeshore is offline
Old 08-02-2006, 08:50 PM   #7 (permalink)
.......I mean a photo of that particular piece that John S. has eluded to
Old 08-02-2006, 09:49 PM   #8 (permalink)
Jay Bird's Avatar
Here is a link to a photo of mine. I didn't like the FFR piece so I made one (two pieces actually).
http://www.ffcars.com/cgi-bin/ultima...1.html?#000015
Jay
MKIII, 3link, Tan leather, 351w/400hp,TKO 600,4 wheel discs, 3.55Gears, Non-Donor, Mazda Redfire w/Honda White Pearl Stripes
Jay Bird is offline
Old 08-02-2006, 10:04 PM   #9 (permalink)
Brian F's Avatar
FFR now sells and includes the underdoor aluminum that Jay Bird has pictured in his link. They started doing this on 1/1/06, I believe. My kit came with the flat section that was supposed to recieve bulb seal. I ended up calling FFR and purchasing the new/revised underdoor aluminum, more than worth the money and really finishes of that area. It also worked with the supplied carpet.
Non-Donor MKIII Delivered Oct. 18, 2005
Complete June 21, 2006
351w 400hp, T5, 3-link, 3:55
My Picture Site
Brian F is online now
Old 08-03-2006, 12:46 PM   #10 (permalink)
Thanks Jay and Brian
Exactly the answers 289FIA and I needed
Old 08-03-2006, 03:13 PM   #11 (permalink)
FFR Craftsman
Yes, thanks for the answer. Actually, I received the under car aluminum on the MKIII from my October/November order last year so these pieces were available in late 2005.
Yesterday, I installed the machine screws for both the shifter trim and handbrake trim. With the driver seat installed, I'm tempted for another clandestine go-kart run today!!!!
Gotta get a hold of Ken Pike to see what the progress report is on my body. If he's on schedule, my car should be in the booth right about now... [img]smile.gif[/img]
Project: SNKVNNM
Old 08-04-2006, 02:08 PM   #12 (permalink)
Woah !
Whereja' get that fantastic e-brake bezel
did you fab it yourself ?
Old 08-04-2006, 02:14 PM   #13 (permalink)
FFR Craftsman
Um, that's the one supplied by Factory Five Racing in the MkIII kit.
Project: SNKVNNM
Old 08-08-2006, 01:32 PM   #14 (permalink)
Ah-Hah !
That must be a 'yet to be discovered item' in one of those boxes down stairs - we'll do a search tonight !
Old 08-08-2006, 02:17 PM   #15 (permalink)
jbammann's Avatar
The timing of this thread is perfect, I'm installing the trim under the doors tonight. You guys are great.
FFR 4617, MK III, 3-Link, 351W, Halibrand Cobra III, Dual Rollbars, 4-wheel disc, 255/315, Delivered 2/05, completed 8/06
jbammann is offline
